	' -----[ Program Description ]---------------------------------------
' Name: WVL Vdrive_03		File write test
' Program stores two 8-bit readings to USB thumb drive using a Vdrive2
' Vdrive jumper in UART MODE (UART/SPI pulled up datasheet V.99 is correct)
' Pin        Name    Description
' 1          GND     5V common
' 2          RTS     Request to Send
' 3          Vdd     Connects to +5V
' 4          RXD     Receive Data
' 5          TXD     Transmit Data
' 6          CTS     Clear to Send (connect to common or make low)
' 7          NC      No Connection
' 8          RI      Ring Indicator (not used)
' PIC18F8722 on BIGPIC5
' DEBUG used for PC comms and SERIN/SEROUT for VDrive2 comms all at 9600 Baud
' -----[ DEFINES ]---------------------------------------------------
clear
DEFINE OSC 40						' Compile as HS
DEFINE LCD_DREG	PORTD	    ' Define PIC port used for LCD Data lines
DEFINE LCD_DBIT	4		    ' Define first pin of data nibble
DEFINE LCD_RSREG PORTD	    ' Define PIC port used for R/S line
DEFINE LCD_RSBIT 2		    ' Define Portb pin used for R/S
DEFINE LCD_EREG	PORTD   	' Define PIC prot used for E line
DEFINE LCD_EBIT	3		    ' Define PortB pin used for E connection
DEFINE LCD_BITS	4		    ' Define the 4 bit communication mode
DEFINE LCD_LINES 4		    ' Define using a 2 line LCD
DEFINE LCD_COMMANDUS 1500	' Define delay time between sending commands
DEFINE LCD_DATAUS 45	    ' Define delay time between data sent
lcdout $fe,$1
pause 2000
FLAGS=0
INCLUDE "modedefs.bas"				' Include serial modes
DEFINE DEBUG_REG  PORTC
DEFINE DEBUG_BIT  6
DEFINE DEBUG_BAUD 9600				' VDrive2 default speed
DEFINE DEBUG_MODE 0
DEFINE DEBUGIN_REG  PORTC
DEFINE DEBUGIN_BIT  7
DEFINE DEBUGIN_BAUD 9600
DEFINE DEBUGIN_MODE 0
define	ADC_BITS 8
' -----[ VARIABLES ]-----------------------------------------------------------
X			VAR	byte
Y           var	byte
Z			var	byte
A			var	byte
B			var	byte
C			var	byte
D			var	byte
E			var	byte
F			var	byte
G			var	word
DataIn		var	byte[50]
Echo		var	byte
Rx          VAR PORTC.0		' Data in from VDrive	[Yellow]
Tx          VAR PORTC.1 	' Data out to VDrive	[Orange]
Heartbeat	var	PORTD.0
Number		VAR	BYTE[10]
' -----[ INITIALISE ]----------------------------------------------------------
ADCON1 	= %00001111			' All digital
TRISA	= %00000011			' A0 and A1 inputs
TRISB	= %00000000
TRISC	= %00000001			' C0 is data in, C1 is data out
TRISD	= %00000000
TRISE	= %00000000
TRISF	= %00000000
TRISG	= %00000000
TRISH	= %00000000
TRISJ	= %00000000
' -----[ IDENTIFY ]------------------------------------------------------------
	lcdout $fe,$80, "WVL Vdrive_03"
	lcdout $fe,$c0, "PIC18F8722"
	pause 3000
	lcdout $fe,1
' *                         ESTABLISH COMMS WITH VDRIVE                       *
Begin:
	Debug "VDrive2 Starting",13
	Pause 200
	Debug "Attempting synchronisation:"
Syncro:
	Pause 200
	toggle Heartbeat
	X=X+1
	debug " ",dec3 X
	SerOut2 TX,84,["E",13]    			' Send sync command folowed by CR
    SerIn2 RX,84,200,Toolong,[Echo]		' Wait 200mS for reply 'E'
	if Echo = "E" then Comms_Good
Toolong:
	GoTo Syncro
Comms_Good:
	Debug 13,"Disk synchronised",10,13	   	' Show SUD has been sent
' *                             M A I N  C O D E                              *
	gosub Check_disk
	gosub Get_version
	gosub File_list
	gosub File_name_size						' File size & name before FOR...NEXT loop
	gosub Free_space
	gosub File_delete
	gosub File_open								' Create the file   "TestFile.csv" (XL type)
												' When read becomes "TESTFILE.CSV"
	for X=1 to 17
		toggle Heartbeat
		debug "Writing to file X: ",dec3 X,13
		SerOut2 TX,84,["WRF ",0,0,0,4,13]		' 32 bit number of bytes
		serout2 Tx,84,[dec3 x,10,13]			' Number of bytes must be exact
	next X										' Additional CR puts XL numbers into a column
	gosub File_close
	gosub File_size								' File size after FOR...NEXT loop
												' Read the file size and send first byte to LCD
	serout2 Tx,84,["IPA",13]					' Switch to ASCII characters for display of HEX digits
	pause 100									' Essential to wait after o/p switch
	serout2 Tx,84,["DIR TestFile.csv",13]		' Issue the command
	serin2  Rx,84,[Wait ("TESTFILE.CSV $"),_
		hex2 A,skip 2,hex2 B,skip 2,hex2 C,skip 2,hex2 D]
	lcdout $fe,$80, "$: ",hex2 A," ",HEX2 B," ",HEX2 C," ",HEX2 D
	debug "All done",10,13
' *                         S U B R O U T I N E S                             *
Check_disk:
	for X=0 to 49 : DataIn[X]=0 : NEXT X		' Clear the array
	serout2 tx,84,[13]							' Issue the command. "D"= Disk Ok, "N"=no disk
	serin2  Rx,84,[str DataIn\1]				' Read  1 character
	If DataIn[0] = "N" then
		debug "No disk detected "
		goto Check_disk
		debug "Disk found OK",10,13
	pause 100									' These pauses are essential
Get_version:
	debug "Firmware version:"
	serout2 tx,84,["FWV",13]					' Issue the command
	serin2  Rx,84,[str DataIn\50\">"]			' Read characters until ">" is found
	debug str DataIn\50							' Send data to the PC
File_list:
	debug 13,10,10,"List all files:"
	serout2 Tx,84,["DIR",13]					' Issue the command
	serin2  Rx,84,[str DataIn\50\">"]			' Read up to max of 50 chrs
	debug str DataIn\50
File_name_size:
	debug 13,10,10,"File name & size:"
	pause 10									' Essential to wait after o/p switch
	serin2  Rx,84,2000,Jump2,[str DataIn\50\">"]' Read up to max of 50 chrs
Jump2:											' Needed in case there is no file on the drive
	debug str DataIn\50
File_size:
	debug 13,10,10,"File size:",13
	serin2  Rx,84,2000,Jump3,[Wait ("TESTFILE.CSV "), str DataIn\50\">"]
Jump3:											' Needed in case there is no file on the drive
	debug str DataIn\50,10,13
	serout2 Tx,84,["IPH",13]					' Switch to HEX characters
Free_space
	debug 13,10,10,"Free space:",13
	serout2 Tx,84,["FS",13]						' Return 4 bytes
	debug str DataIn\50
File_open:
	debug "Opening file",10,13
	serout2 Tx,84,["OPW TestFile.csv",13]		' Issue the command
File_close:
	debug 10,"Closing file",10,13
	SerOut2 TX,84,["CLF TestFile.csv",13]		' Issue the command
File_delete:
	debug 13,10,10,"Deleting file",10,13
	serout2 tx,84,["DLF TestFile.csv",13]		' Issue the command
