Hot Servos
Results 1 to 38 of 38
Thread: Hot Servos
    Lightbulb
    So ... let's resume.
    IF those 3 wonderful servos are " so good " ... why not test their behaviour into the skull, with a so simple 555 based servo driver ( 10 components is a maximum ) that will produce neat-known signals ...
    here is one of them:
    http://www.hvlabs.com/555servo.html
    would certainly save time to everyone and, may be money to you ...
    Jun 2007
    Mansfield, UK
    Ok, sounds like a good idea. Ill try and make a 555 circuit tonight. Im pretty confident the signal from my circuit is fine now (it works on the digital servo and the old Sanwa). Im all for saving money though so ill see how the 555 goes.
    Jun 2007
    Mansfield, UK
    Unfortunately the 555 has the same results. Again the scope shows quite a good signal. There are very slight variations in the line but they are present even when nothing is connected to the scope. They definately wont cause this problem. Ive zoomed right in and measured the pulses and they are identical width.
    I accidentally extended the pause time through my PIC circuit to 30ms and they were twitching even more. I would expect that from analog servos but it seems that if i gradually decrease the pause time they gradually become more stable but 6ms is the shortest i can go to and at that they are back to buzzing and only moving very slightly. Its like the pause time the servos require has become shorter
    I see that servos have an input voltage range of 4.8VDC to 6VDC. If that power is not clean could it cause the jitter? Are servos ratiometric, so to speak?
    Tim Barr
    Jun 2007
    Mansfield, UK
    The slight variations on my scope are background noise. We are talking like 2mV. Im pretty confident that the supply and signal are both cleaner than my scope is showing and theres no way i could get it any cleaner.
    Quote Originally Posted by falingtrea View Post
    Hi, Tim
    servos are Theoretically not supply sensitive , actually it is very, very, un noticeable.
    This, Halas, is the new proof those hum... servos are to avoid ...
    reducing the pause between two pulses only increases the energy given to hold the position ...
    what confirms the steady position behaviour is very very bad ... see my #23 post ...
    No other solution than select good ones instead of those ...
    or try to modify the servo amp gain and dead band ( 10% success ... no more, and 90% risk of oscillating around the position.)
    One certitude: amplifier parameters have not been optimised ( often seen for Hitech servos ... )
    Jun 2007
    Mansfield, UK
    I think im going to try to avoid analog servos all together from now on. Digital servos seem to work way better.
    Thanks for all your help anyway. I will get some new digital ones and see if i can return these.
    Post
    Quote Originally Posted by The Master View Post
    It's not a digital or analogic servos problem, but a quality problem ...
    try to choose ones from well known brands ( Futaba, JR, Graupner ...) and of course, not the " first prices " ones , the price won't be so much higher ...
    Chinese or Corean brands still are " no so reliable ", may be one day they'll become ... may be.
