Hot Servos
Results 1 to 38 of 38
Thread: Hot Servos
    Sep 2007
    USA, CA
    Friction can contribute to servo heat. If the mechanism can't easily and smoothly move one servo step, then it can oscillate.
    For this type of app, I've used digital servos. They have several benefits... the first of which is no heat when they are not moving. They are easier on the PIC mcu program, too, because you can give them a single pulse and they'll remember the target--instead of a continual string of pulses.
    Jun 2007
    Mansfield, UK
    The regulators are hot but they arnt incredibly hot. Like it said, ive got another circuit where the regulator is running even hotter without any problems.
    The servos im using are 3 X Hitec HS-645 MG and 1 X Hitec HS-5645 MG Digital.
    Ive tried unplugging all but one servo then connecting a capacitor to it. There is no change at all.
    There is almost no restriction at all in the mechanism. I can move it freely with my hand when the power is off. The servos only have to move the weight of the skull. (The mechanism)
    Ive just done a test that i should have tried ages ago. I unplugged my PIC and powered up the circuit. All of the servos jumped to a random position (as they always do with no signal) then they stopped. No twitching or buzzing. The servos and the regulators are all remaining very cool. Im going to do some more maths and see if i can make my program a bit better
    Jun 2007
    Mansfield, UK
    On the 20ms pause. Ive read that it should be on for 1-2ms then off for about 18ms. How sensitive are servos to that gap? My understanding is that the length of time the pin goes high for is the most important. The pause in my program will vary depending on how long the pins are on for. That has been fine in the past with a similar type of servo
    Sep 2007
    USA, CA
    Sounds like a code issue. Have you looked at the output pulses on a scope? If the signal pulses vary at all, that can drain the batteries.
    The 18mS isn't critical with the digital servos, but the analog servos are all different; some could just power down, and some could cause more drain.
    Jun 2007
    Mansfield, UK
    Ive taken a look at the signal with my scope. At first it was showing a 1.4ms pulse with a 6ms gap. I found out that i hadnt cleared the Timer3 interrupt flag. Ive updated my code and now im seeing a 1.4ms pulse with a 19.2ms gap but its now worse than it was before. Originally the servos were constantly buzzing but now they are visibly moving constantly.
    While ive been messing about with it ive been testing the digital servo on its own and it seems that it holds its position silently no matter how big or small the gap is. Its the 3 standard servos that are causing all the buzzing. I even plugged one of the standard servos into the socket for the digital servo just to be sure but i still had the problem
    Sep 2007
    USA, CA
    I've seen old servos do that. Do you have another signal generator (or rc tx) that you can test them with?)
    Jun 2007
    Mansfield, UK
    Unfortunately i dont. The only other thing is a special servo tester from Hitec but that went pop about a week ago
    Red face
    Quote Originally Posted by The Master View Post
    Bad news ...
    The HS645 are rated 1 Amp each ... but their real problem is a very poor position holding caracteristics .
    This servo is well known for its lack of precision AND its Hysteresis ...
    That explains what you get as a behaviour.
    Only solution is to change them ...
    Try some old Futaba S9402 ( good discounts ... VERY good servos )
    AND try to forget about Hitech products ... you'll really save your $$$ !!!
    Jun 2007
    Mansfield, UK
    All of these servos worked fine when i was using the Hitec servo tester. I would have thought the digital servo would be the first to complain if there were any problems but thats the only one working.
    The Futaba S9402 is £65.50. I need 3 of those so its a bit expensive. Ive been looking at some Hitec HS-5625MG digital servos. They are very slightly better than the analog ones im currently using but they are digital so i shouldnt have a problem with them. They are only £35.99 each which is still gonna be expensive but not as much.
    I would like to know what went wrong though. I cant believe that 3 perfectly good servos would suddenly mess up at the same time like this. They were holding their positions very well when i was first testing them. There was no buzzing and they wernt struggling to move the skull at all.
    By the way, i have completely removed one of the analog servos from the skull and powered it up. Its still twitching. I think its even worse than when its in the skull
    Jun 2007
    Mansfield, UK
    I just remembered that i had an old Sanwa SRM-102 servo laying around. I tried plugging that in and it holds its position very well. It is a little jumpy if i try to turn the arm but this servo has always been like that.
    I cant believe that 3 perfectly good servos ...
    This is waaayyyy optimistic !!!
    the test has been made by very serious guys with a high level servo tester ...
    that wasn't MY experience but the ( very bad ) results of tests ...
    ALL Those results have been published as a program called "Servormances" ... only available in French, halas.
    Here you can get it ...
    http://www.teaser.fr/~osegouin/aeromode/servos.phtml
    You ALSO can ask P. Cesarrato a "kit" of his servo tester ... he sells it @ " friend price " ( no much more than the components price ...)
    I join some description of the used tester manual ...
    Add to that I have been dealing with R/C stuff for ... over 40 years. If I tell you to forget about Hitech products, It's ALSO because I personnaly have tested, repaired ... and thrown their products to the Wastebox !!!
    Want some copies of the ( constructive ...) mails I've sent to and received from their technical staff ???
    They even do agree their servos are " not so good " ... and , of course, always promise they will correct them !!!
    Talking price ...
    you can get much, much better prices ( ~ half what you tell !!! )... but may be NOT from your local reseller or any " robotics shop " !!!
    Also have a look to Futaba S3302 ...
    Jun 2007
    Mansfield, UK
    So far i have got my old Sanwas from www.rapidonline.co.uk and my new Hitec servos from www.servoshop.co.uk. There isnt a local place i can go to and buy any but if you can recommend a website (preferably in the UK) then i will have a look.
    Jun 2007
    Mansfield, UK
    Hmm, Even if these servos arnt very good i still dont believe that 3 brand new ones would suddenly fail in the same way at the same time. There must be some reason behind it. My biggest worry is that i spend yet more money on more expensive servos and only get the same problem
