SPWM and DEBUG
Results 1 to 3 of 3
Thread: SPWM and DEBUG
    Unhappy SPWM and DEBUG
    Hi all
    Is there some problem in using the SPWM code and "debug" together? I use debug with
    a VFD display for trouble shooting but have not been able to get it to work when the SPWM technique is used.
    Below is a stripped down version of the demo which runs (osc 20) but does not register on the display.
    I can use the same hardware setup (16f628a) with different code (no SPWM) and use the display (osc 20) without a problem.
    Thanks in advance
    'SPWM code
    DEFINE OSC 20
    CLEAR
    CMCON = 7
    Define DEBUG_REG PORTA ' Debug PORT
    Define DEBUG_BIT 0 ' *** Debug pin Bit-0 ***
    Define DEBUG_BAUD 9600 ' *** Debug Baud Rate ***
    Define DEBUG_MODE 0 ' Set Serial Mode to Inverted
    Define DEBUG_PACING 200 ' Delay 'in Us' between characters sent
    Debug $0E 'Clr
    Debug $0D 'CR
    INCLUDE "SPWM_INT.bas" ; Software PWM module
    DEFINE SPWM_FREQ 40 ; SPWM Frequency
    DEFINE SPWM_RES 256 ; SPWM Resolution
    DutyVars VAR BYTE[3] ; DutyCycle Variables
    DutyVar1 VAR DutyVars[0] ; group them in an array for easy access
    DutyVar2 VAR DutyVars[1] ; with FOR loops etc.
    DutyVar3 VAR DutyVars[2]
    SPWM_LIST macro ; Define PIN's to use for SPWM
    SPWM_PIN PORTB, 0, _DutyVar1
    SPWM_PIN PORTB, 1, _DutyVar2
    SPWM_PIN PORTB, 2, _DutyVar3
    SPWM_INIT SPWM_LIST ; Initialize the Pins
    INT_Handler TMR1_INT, SPWMhandler, ASM, yes
    @ INT_ENABLE TMR1_INT ; enable Timer 1 interrupts
    ;_________________________________________________ ____________________________
    LoopCount VAR WORD
    Main: ; Simple Demo to fade/flash some LED's
    loop:
    FOR LoopCount = 1 TO 4 ; Reapeat 4 times
    FOR DutyVar1 = 5 TO 255 step 1
    pause 10
    next
    Debug $0D 'CR ;display
    Debug, dec2 loopcount
    FOR DutyVar1 = 255 TO 5 step -1
    pause 10
    next
    next loopcount
    GOTO loop
    Homerclese
    DEBUG uses software delays to bitbang the serial stream out. When using interrupts they will disturb the timing of the bitbanged serial stream. It's not specific to the SPWM routines you're using. Either use a PIC with an USART and use HSEROUT instead of DEBUG or you need to temporarily disable the interrupts while sending your data with DEBUG.
    Smile Hserout
    Hello,
    I added these lines and the display is alive and well.
    Define HSER_TXSTA 20h ' OUTPUT B2 PIN 8 16f628a
    Define HSER_BAUD 9600
    HSEROUT[ $0D ] 'CR
    HSEROUT[ dec2 loopcount]
    Homerclese
