reset and interrupt vectors
Results 1 to 3 of 3
    dtoohey's Avatar
    dtoohey Guest
    Default reset and interrupt vectors
    Hello,
    I'm kinda new at this stuff.. I'm hoping to find out how to adjust the reset and interrupt vectors from their default settings. I understand that the reset is normally at 0x000, with interrupt vectors at 0x008 and 0x018. I need to insert an 0x200 offset for them all (reset at 0x200, interrupts at 0x208 and 0x218). This is a requirement for the EZ-controller (www.EZ-devices.com), which uses a PIC18F252...
    Is this something that can be done with PBP, or does the compiler require the reset vector to remain at 0x000? I'm hoping that all it would take is a little assembly language added to the top of my code, but before I buy PBP, I want to make sure.
    Damian
    Hi Damian,
    This DEFINE will do what your looking for.
    Define RESET_ORG 200h
    HTH,
       Darrel
    dtoohey's Avatar
    dtoohey Guest
    Easy enough, thanks.
  1. 16F876A CCP1 Capture/Interrupt Question
    By TDonBass in forum mel PIC BASIC Pro
    Last Post: - 17th January 2008, 04:25
  2. Interrupt Problem
    Last Post: - 16th November 2005, 21:58
  3. Interrupt stack overflow problem with Resume {label}
    By Yuantu Huang in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2005, 02:17
  4. Software Driven Reset Routine
    Last Post: - 11th April 2005, 01:53
  5. Multi Interrupt How To ?
    By capitano in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2005, 15:48
