With one USART and DT interrupt and using a RS485 ring, you can connect several devices at a pretty high speed. Look the data sheet for 75176 (there are several others, but I use this one) for more detail.
Al.
Al.
Hi Al,
Yes, that's possible, as long as you have control over the transmitting devices or if you don't care if you miss some data by cycling thru the devices listening to one device at a time. If they are self contained units sending data on their own, at will, then it's going to be tricky. If I've missed your point please enlighten me :-)
Now, the OP doesn't say how the transmitting devices works and/or if he has "control" over how they works. Hopefully a multidrop network can be implemented in which case one USART would be enough.
Yes, Henrik the control is necessary, devices must tx only on request, without it the OP will not achieve much.Yes, that's possible, as long as you have control over the transmitting devices
Al.
Thanks for the info! This particular application is a polled system, and my local PIC needs to process data and format the output into a predefined 'message'. Then when I am polled, I need to forward the data on to the host. I think ARRAYWRITE is the way to go. I was thinking about using an eeprom, but this is definately faster. I am not sure of the time between the polls yet though, and am concerned my data will back up, so need some message buffer space. Thanks very much for your help.
One interesting thing...
It seems that ARRAYWRITE does not work with indexed variables.
ARRAYWRITE MSG ["VALUE: ",DEC TMR[X]]
I'm just copying the value of TMR[X] to another variable first for now. Is this a bug, or just not accounted for or ??? Great command nonetheless.
Sorry, I was 'winging it' by memory from work. The comma was there, and still no go. I'll keep trying things as I'd really like to use this command.![]()
