Enabling weak internal pull up resistors on port B
Results 1 to 9 of 9
    Jul 2010
    Ok, So let's say for some reason the OPTION_REG is getting reset. What syntax do I use in PicBasic Pro to set it again?
    Nov 2007
    West Covina, CA
    Quote Originally Posted by dbodenheimer View Post
    ok, so let's say for some reason the option_reg is getting reset. What syntax do i use in picbasic pro to set it again?
    option_reg.7=0
    Louie
    malc-c's Avatar
    malc-c Guest
    I've often found internal pull-ups troublesome and simply use small external resistors between 4.7K and 10K depending on the input device
    Oct 2010
    In that thought process, it appears option_reg.7 = 0 sets all 4 port B pull ups on an 16F88. Can one of those pins then be used as a serial output? I don't see where you can set individual pins.......
    Mar 2009
    Quote Originally Posted by Plcguy View Post
    On a 16f690, I do this to get the weak pullups working...
    option_reg.7=0 ' Enable WPUs by individual pin
    WPUB = %11110000  'enable weak pullups on RB7, RB6, RB5 & RB4
    It all works weally weakpullup-tastically (but disable any other PIC stuff that maybe sharing those ports...and make sure they're all set as inputs)
