Enabling weak internal pull up resistors on port B
Results 1 to 9 of 9
    Jul 2010
    Default Enabling weak internal pull up resistors on port B
    I have some switches that I need to install on my system. I have 4 of them and I currently have them hooked to PortB.4-7. I understand that there are internal pull up resistors that can be enabled for this port. It's my understanding that they are disabled after a power on reset.
    Can someone tell me how to enable these resistors from PICBasic Pro?
    Jul 2010
    I should have mentioned that I'm using a 16F876 PIC and it does have the internal resistors.
    Nov 2007
    West Covina, CA
    Setting your configs at the top of your program will ensure that the internal pull ups are always enabled from the beginning even when power is interrupted because that's where it will start anyways.
    I suppose if you enable the internal pull ups in a subroutine that is called after certain conditions, then yes, you can lose that setup until that condition is called again after a power reset.
    The bit has to be cleared per data sheet so: OPTION_REG.7=0
    Louie
    Dec 2009
    Kalamazoo
    datasheet says that they are controlled by OPTION_REG , bit 7 (RPBU). (pg. 45)
    same page indicates that on reset, this register value defaults to all bits being set, (1111 1111),
    so, hook up your switches, dont change nothin' and switch away
    NAG CON WIFE!
    WIFE VAR MOOD
    Jul 2010
    Ok, So let's say for some reason the OPTION_REG is getting reset. What syntax do I use in PicBasic Pro to set it again?
    Nov 2007
    West Covina, CA
    Quote Originally Posted by dbodenheimer View Post
    ok, so let's say for some reason the option_reg is getting reset. What syntax do i use in picbasic pro to set it again?
    option_reg.7=0
    Louie
    malc-c's Avatar
    malc-c Guest
    I've often found internal pull-ups troublesome and simply use small external resistors between 4.7K and 10K depending on the input device
