how do I get a byte out of two 6 bit wide ports.
Results 1 to 2 of 2
    kitcat's Avatar
    kitcat Guest
    Default how do I get a byte out of two 6 bit wide ports.
    Hi.
    I am about to use a PIC16F688 which is a 14 pin package. Porta and Portc are only 6 bits wide. I want to count pulses on a pin (such as porta.0) and send the result to portc. Unfortunately the number is goign to end up at about 100 so I need a 7 bit wide port. I also want to use another pin to toggle to signify that a count has taken place (simply changing the state high or low on each count command).
    So how do I combine two ports to write out a byte?
    MyByte = 255
    PORTC = Mybyte
    PORTA.0 = MyByte.6
    PORTA.1 = MyByte.7
    Last Post: - 14th June 2016, 08:55
  2. LCD freeze
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 5th October 2009, 09:01
  3. byte compression
    By Norbert in forum mel PIC BASIC Pro
    Last Post: - 16th June 2007, 19:04
  5. 16F877 RAM Question
    By Art in forum mel PIC BASIC Pro
    Last Post: - 6th August 2005, 12:47
