Hi, Ive got 2 circuits and each has a PIC chip on it. The circuits need to communicate using only standard IO pins. I have 10K resistors between them.
The chip work fine when both circuits are powered but if i turn one circuit off then the power coming into the input pin from the other circuit keeps the chip powered. Sometimes it just keeps an LED on another pin lit but very dim. Sometimes the chip will keep executing code. Is there a proper way to connect PICs accross multiple circuits? Would a different resistor solve the problem or do i need to use optos?
Im hoping for a small solution like a different resistor since ive already made the PCBs![]()
