• May be used with character LCD‘s with up to 4 lines.
• Up to 20 characters per line are available.
• Easy to use - simple Decimal commands.
• Only 3 lines needed - 5V power, ground and signal input.
• Compact size - 1.78in long by 0.98in wide.
• Turn display ON/OFF remotely.
• Automatic baud rate selection from 1,200 to 57,600. Standard RS-232 or TTL level signals.
• Software controlled LED backlight, 255 brightness levels.
You can download a data/instruction sheet here:
http://home.earthlink.net/~rmteo/sit...les/dx-lcd.pdf
I will be giving away 10 of these to members of this forum. You just have to pay for priority shipping (US$7 for USA, US$15 for International addresses).
To qualify (and to avoid any confusion), you will have to do this:
1. Send me a PM to say that you are interested. Also, please state whether you want 2x8 or 1x16 header on the board. I will reply with my PayPal info.
2. Post a reply here with your name stating that you are interested and have sent me the PM.
The first 10 names to post here will be receive the board. Good luck and thanks for your interest.
