I am stumped!!!
Results 1 to 20 of 20
Thread: I am stumped!!!
    Make sure you have the watchdog timer disabled when using the assembler @ SLEEP command.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Ok, I didn't know about that...Thank you.
    Sorry. My fault for not mentioning this. The @ SLEEP instruction puts it to sleep forever until a watchdog timeout, or an interrupt wakes it up.
    When it wakes up due to watchdog timer timeout, it executes the instruction immediately after the @ SLEEP, and lands on your goto cycle.
    Any time you use the assembler version @ SLEEP you'll need to make sure you have WDT disabled unless you want it to wake up with the watchdog timer timeout.
    -Bruce
    tech at rentron.com
    Taz,
    Try this version with the nop just after @ SLEEP and see if this helps.
    CMCON=%00000111
    VRCON = 0
    PAUSEus 10
    TRISA = %00000110
    TRISB = %11110000   ' using upper 4-bits for interrupt
    PORTA = %00000000
    PORTB = %00000001
    OPTION_REG.7 = 0
    OPTION_REG.6 = 0
    led var portA.3
    INCLUDE "ReEnterPBP.bas" ; Include if using PBP interrupts
        INT_Handler RBC_INT, _check, PBP, yes
        INT_CREATE
    @ INT_ENABLE RBC_INT
    cycle:
        HIGH led
        LOW led
        @ Sleep
        @ NOP
        goto cycle
    check:
        WHILE (portb >> 4) != 15
          PAUSE 10
        WEND
        @ INT_RETURN
    -Bruce
    tech at rentron.com
