I am stumped!!!
Results 1 to 20 of 20
Thread: I am stumped!!!
    Try this;
    CMCON=%00000111
    VRCON = 0
    PAUSEus 10
    TRISA = %00000110
    TRISB = %11110000   ' using upper 4-bits for interrupt
    PORTA = %00000000
    PORTB = %00000001
    OPTION_REG.7 = 0
    OPTION_REG.6 = 0
    led var portA.3
    INCLUDE "ReEnterPBP.bas" ; Include if using PBP interrupts
        INT_Handler RBC_INT, _check, PBP, yes
        INT_CREATE
    @ INT_ENABLE RBC_INT
    cycle:
        HIGH led
        LOW led
        @ Sleep
        goto cycle
    check:
        WHILE (portb >> 4) != 15
          PAUSE 10
        WEND
        @ INT_RETURN
    The purpose of WHILE (portb >> 4) != 15 is to wait until a button that generated the interrupt is released. It also reads the port, which is required before DT_INTs can clear the interrupt flag.
    To clear the interrupt-on-change flag bit you first have to read the port, then clear the flag. If you read the port while a button is still pressed, then clear the flag, another interrupt will be generated once the button is released.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Thanks a million Bruce, I will try that now.
    P.S. I about fell on the floor laughing when I refreshed the page and say the crayon
    It took me a while to find one the color of my truck..;o)
    Experiment with this one too. You can have it wake from sleep without an interrupt handler.
    CMCON=%00000111
    VRCON = 0
    PAUSEus 10
    TRISA = %00000110
    PORTA = %00000000
    PORTB = %00000001
    OPTION_REG.7 = 0
    OPTION_REG.6 = 0
    led var portA.3
        INTCON = %00001000  ' int-on-change enabled. RBIE=1, RBIF=0
    cycle:
        HIGH led
        LOW led
        @ Sleep                 ' sleep until button press
        WHILE (portB >> 4) !=15 ' wait for button release
          PAUSE 10              ' and read port so RBIF can
        WEND                    ' be cleared below.
        INTCON.0=0              ' now clear RBIF int flag
        goto cycle
    Global interrupts are disabled. Just enabled the int-on-change by setting RBIE, clearing RBIF, and it sleeps until a button is pressed.
    DT_INTs is more fun, but you can wake one up without an interrupt handler.
    -Bruce
    tech at rentron.com
    I compiled the code as shown, when powered up the led continues to blink but when I press a button on the keypad which would cause (PORTB >> 4) != 15 it still blinks.....
    I have even tried it with the following changes with same response:
    cycle:
    gosub checkstate
    HIGH led
    LOW led
    @ Sleep
    goto cycle
    checkstate:
    while (PORTB >> 4) != 15
    pause 20
    wend
    its almost like it never see an interrupt to get out of cycle. I also confirmed on PortB by checking with my meter on switch closure. With a switch closed and the bit I checked was PortB.4 I measured it at 2.192Vrms, switch open 4.99Vrms.
    Thanks for hanging around
    Bruce, just wanted to mention we must have posted about the same time the code that I just tried was the crayon version, I am about to try your latest.
    Again, Thank you.
    Make sure you have the watchdog timer disabled when using the assembler @ SLEEP command.
    -Bruce
    tech at rentron.com
    Ok, I didn't know about that...Thank you.
    Sorry. My fault for not mentioning this. The @ SLEEP instruction puts it to sleep forever until a watchdog timeout, or an interrupt wakes it up.
    When it wakes up due to watchdog timer timeout, it executes the instruction immediately after the @ SLEEP, and lands on your goto cycle.
    Any time you use the assembler version @ SLEEP you'll need to make sure you have WDT disabled unless you want it to wake up with the watchdog timer timeout.
    -Bruce
    tech at rentron.com
