I am stumped!!!
Results 1 to 20 of 20
Thread: I am stumped!!!
    Thanks for the drawing, that is how this is connected, yes I am aware of "scanning the keypads" Bruce has been a great help, but I am just narrowing it down to pressing on button, pins 1-3 low, and pin 0 high just to see how interrupt's work. I am looking to use the interrupt to sleep all the time, detect when key is pressed, wake up, set PORTB.0, and 4-7 as inputs, bits 1-3 as out, pause about 50, then began scanning keypad something like this:
    recycle:
    @ Sleep
    @ NOP
    @ NOP
    goto recycle
    ' my Interrupt handler
    search:
    PORTB = 0
    TRISB = $f1
    PAUSEUS 10
    keypadscan:
    FOR row = 1 TO 3
    PORTB = 0
    TRISB = (DCD row) ^ $fe
    col = PORTB >> 4
    IF col != $f THEN keypressed
    NEXT row
    GOTO recycle
    Haven't got all this worked out yet, but thats another day
    I'm just stumped with the original code above why am I already in the interrupt when I power up, just to confirm that I changed the INT handler to:
    '---[INT - interrupt handler]---------------------------------------------------
    ToggleLED1:
    TOGGLE LED
    pause 50
    @ INT_RETURN
    and sure enough the led is flashing...
    By the way, what program are you using to upload your schematic?
    Hmmm, came back here today to focus on the post here from Bruce but it seems to have vanished, or am I losing my mind? Maybe its both
    Anyhow, it was mentioned that so to speak that I should take a snapshot of PortB, I am so lost. If on power up PortB.0 is high and pullups are enabled, on the rest of the pins: TRISB = %11111110 PortB = %00000001 then with my meter focusing on pins 4-7 shows 5VDC or logic HIGH, should I do this:
    WHILE (portb >> 4) != 15
    pause 20
    wend
    INTCON.0 = 0
    or substitute 15 for a 0?
    Seems it would be 15 but with that I apparently staying in my interrupt routine.
    I've been experimenting with ON INTERRUPT and Darryl Taylor's Instant Interrupts:
    CMCON=%00000111
    VRCON = 0
    PAUSEus 10
    TRISA = %00000110
    TRISB = %11111110
    PORTA = %00000000
    PORTB = %00000001
    OPTION_REG.7 = 0
    OPTION_REG.6 = 0
    INTCON = %00001000
    led var portA.3
    INCLUDE "ReEnterPBP.bas" ; Include if using PBP interrupts
    INT_Handler RBC_INT, _check, PBP, yes
    INT_CREATE
    @ INT_ENABLE RBC_INT
    PAUSE 50
    cycle:
    gosub readportb
    HIGH led
    LOW led
    @ Sleep
    @ Nop
    @ Nop
    goto cycle
    readportb:
    PAUSE 20
    WEND
    INTCON.0 = 0
    check:
    PAUSE 250
    PAUSE 20
    WEND
    @ INT_RETURN
    Any Suggestion, preferably in Crayola so its clear?
    Try this;
    CMCON=%00000111
    VRCON = 0
    PAUSEus 10
    TRISA = %00000110
    TRISB = %11110000   ' using upper 4-bits for interrupt
    PORTA = %00000000
    PORTB = %00000001
    OPTION_REG.7 = 0
    OPTION_REG.6 = 0
    led var portA.3
        INT_CREATE
    cycle:
        HIGH led
        LOW led
        @ Sleep
        goto cycle
    check:
          PAUSE 10
        WEND
        @ INT_RETURN
    The purpose of WHILE (portb >> 4) != 15 is to wait until a button that generated the interrupt is released. It also reads the port, which is required before DT_INTs can clear the interrupt flag.
    To clear the interrupt-on-change flag bit you first have to read the port, then clear the flag. If you read the port while a button is still pressed, then clear the flag, another interrupt will be generated once the button is released.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Thanks a million Bruce, I will try that now.
    P.S. I about fell on the floor laughing when I refreshed the page and say the crayon
    It took me a while to find one the color of my truck..;o)
    Experiment with this one too. You can have it wake from sleep without an interrupt handler.
    CMCON=%00000111
    VRCON = 0
    PAUSEus 10
    TRISA = %00000110
    PORTA = %00000000
    PORTB = %00000001
    OPTION_REG.7 = 0
    OPTION_REG.6 = 0
    led var portA.3
        INTCON = %00001000  ' int-on-change enabled. RBIE=1, RBIF=0
    cycle:
        HIGH led
        LOW led
        @ Sleep                 ' sleep until button press
        WHILE (portB >> 4) !=15 ' wait for button release
          PAUSE 10              ' and read port so RBIF can
        WEND                    ' be cleared below.
        INTCON.0=0              ' now clear RBIF int flag
        goto cycle
    Global interrupts are disabled. Just enabled the int-on-change by setting RBIE, clearing RBIF, and it sleeps until a button is pressed.
    DT_INTs is more fun, but you can wake one up without an interrupt handler.
    -Bruce
    tech at rentron.com
    I compiled the code as shown, when powered up the led continues to blink but when I press a button on the keypad which would cause (PORTB >> 4) != 15 it still blinks.....
    I have even tried it with the following changes with same response:
    cycle:
    gosub checkstate
    HIGH led
    LOW led
    @ Sleep
    goto cycle
    checkstate:
    while (PORTB >> 4) != 15
    pause 20
    wend
    its almost like it never see an interrupt to get out of cycle. I also confirmed on PortB by checking with my meter on switch closure. With a switch closed and the bit I checked was PortB.4 I measured it at 2.192Vrms, switch open 4.99Vrms.
    Thanks for hanging around
    Bruce, just wanted to mention we must have posted about the same time the code that I just tried was the crayon version, I am about to try your latest.
    Again, Thank you.
