I am stumped!!!
Results 1 to 20 of 20
Thread: I am stumped!!!
    Default I am stumped!!!
    I am using a PIC 16F628A processor, and am trying to learn how to use DT's Interrupts but here is my problem:
    If TRISB = %11111110 and PORTB %00000001 that should mean that bit 0 of PORTB is an ouput all others are input and with PORTB = %00000001 that means bit 1 is equal to one meaning high 5v and all others low, CORRECT???? Well, after check with my meter PORTB 0-7 are high or shall I say 5v, running the code below, I am experimenting with Interrupts on PORTB 4-7 wanting to detect when bits 4-7 go low and with keypad connected to PORTB 1-7, Bit 0 is an output set high going through forward through diode anode to pins 4-7 when button is pressed that particular bit is pulled low....
    CMCON = 7
    VRCON = 0
    pauseus 10
    TRISA = %00000110
    TRISB = %11111110
    PORTA = %00000000
    PORTB = %00000001
    OPTION_REG.7 = 0 'enable pullups
    OPTION_REG.6 = 0 'trigger on falling edge
    led var portA.3
    INCLUDE "ReEnterPBP.bas" ; Include if using PBP interrupts
    INT_Handler RBC_INT, _ToggleLED1, PBP, yes
    @ INT_ENABLE RBC_INT ; enable external (INT) interrupts
    PAUSE 1
    GOTO Main
    ToggleLED1:
    TOGGLE LED
    PAUSE 50
    @ INT_RETURN
    My explanation my seem confusing but it is early and I haven't had my COFFEE!!!!
    May 2008
    Italy
    This is correct! You set portB.0 to be an output all remaining to be inputs, but you also have activated the internal pullup so, all inputs are high waiting your command (short to ground) while your instruction "PORTB %00000001" will have effect only on portB.0.
    Al.
    Thank you for clarifying that, I've spent all of Saturday trying to figure this out. Have you time for another question? If so, with the above setup why upon startup does my led blink?
    May 2008
    Italy
    Cannot answer without the schematic. Post how you wired your system, and I will try to give you an answer.
    Al.
    I have a keypad, 3 rows, 4 columns, my rows are connected to PortB bits 1-3, the columns are connected to PortB bits 4-7. I set PortB.0 to 1 (high) feeding four 1n4148 diodes anode to PortB.0 cathodes to bit 4-7. When a button is pressed on the keypad it pulls whichever pin 4-7 low. I have OPTION_REG.6 = 0 to trigger on the falling edge.
    keypad ohms out good, brand new actually, but as I mentioned before PortB.1-3 are my rows and 4-7 are my columns with the above code, pressing a button on the keypad does not pull any pin low.
    May 2008
    Italy
    I don't know how you want to connect your 3x4 keypad but the way you did explain is not going to work.
    See the attached schematic. You have to put portB.1 to portB.3 (one at the time) to be an output and set it to low.
    If you push one key of your keypad then the interrupt will detect the change (portB.4/7 going low) and will jump in the interrupt subroutine where you will decode the key, knowing which portB.1/3 was active low and which portB.4/7 was activated.
    Al.
    I changed TRISB = %11111110 to TRISB = %11110000 now pressing keypad the selected PORTB 4-7 pulls low to 2.2VDC, by the way PORTB.0 is connect first in series with a 330 ohm resistor, then to the four 1N4148's. I thought limiting the current to 15mA would be easier on the internal pull-ups.
    Thanks for the drawing, that is how this is connected, yes I am aware of "scanning the keypads" Bruce has been a great help, but I am just narrowing it down to pressing on button, pins 1-3 low, and pin 0 high just to see how interrupt's work. I am looking to use the interrupt to sleep all the time, detect when key is pressed, wake up, set PORTB.0, and 4-7 as inputs, bits 1-3 as out, pause about 50, then began scanning keypad something like this:
    recycle:
    @ Sleep
    @ NOP
    @ NOP
    goto recycle
    ' my Interrupt handler
    search:
    PORTB = 0
    TRISB = $f1
    PAUSEUS 10
    keypadscan:
    FOR row = 1 TO 3
    PORTB = 0
    TRISB = (DCD row) ^ $fe
    col = PORTB >> 4
    IF col != $f THEN keypressed
    NEXT row
    GOTO recycle
    Haven't got all this worked out yet, but thats another day
    I'm just stumped with the original code above why am I already in the interrupt when I power up, just to confirm that I changed the INT handler to:
    ToggleLED1:
    TOGGLE LED
    pause 50
    @ INT_RETURN
    and sure enough the led is flashing...
    By the way, what program are you using to upload your schematic?
    Hmmm, came back here today to focus on the post here from Bruce but it seems to have vanished, or am I losing my mind? Maybe its both
    Anyhow, it was mentioned that so to speak that I should take a snapshot of PortB, I am so lost. If on power up PortB.0 is high and pullups are enabled, on the rest of the pins: TRISB = %11111110 PortB = %00000001 then with my meter focusing on pins 4-7 shows 5VDC or logic HIGH, should I do this:
    WHILE (portb >> 4) != 15
    pause 20
    wend
    INTCON.0 = 0
    or substitute 15 for a 0?
    Seems it would be 15 but with that I apparently staying in my interrupt routine.
    I've been experimenting with ON INTERRUPT and Darryl Taylor's Instant Interrupts:
    CMCON=%00000111
    VRCON = 0
    PAUSEus 10
    TRISA = %00000110
    TRISB = %11111110
    PORTA = %00000000
    PORTB = %00000001
    OPTION_REG.7 = 0
    OPTION_REG.6 = 0
    INTCON = %00001000
    led var portA.3
    INT_Handler RBC_INT, _check, PBP, yes
    INT_CREATE
    PAUSE 50
    cycle:
    gosub readportb
    HIGH led
    LOW led
    @ Sleep
    @ Nop
    @ Nop
    goto cycle
    readportb:
    PAUSE 20
    WEND
    INTCON.0 = 0
    check:
    PAUSE 250
    PAUSE 20
    WEND
    @ INT_RETURN
    Any Suggestion, preferably in Crayola so its clear?
    Try this;
    CMCON=%00000111
    VRCON = 0
    PAUSEus 10
    TRISA = %00000110
    TRISB = %11110000   ' using upper 4-bits for interrupt
    PORTA = %00000000
    PORTB = %00000001
    OPTION_REG.7 = 0
    OPTION_REG.6 = 0
    led var portA.3
        INT_CREATE
    cycle:
        HIGH led
        LOW led
        @ Sleep
        goto cycle
    check:
          PAUSE 10
        WEND
        @ INT_RETURN
    The purpose of WHILE (portb >> 4) != 15 is to wait until a button that generated the interrupt is released. It also reads the port, which is required before DT_INTs can clear the interrupt flag.
    To clear the interrupt-on-change flag bit you first have to read the port, then clear the flag. If you read the port while a button is still pressed, then clear the flag, another interrupt will be generated once the button is released.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Thanks a million Bruce, I will try that now.
    P.S. I about fell on the floor laughing when I refreshed the page and say the crayon
    It took me a while to find one the color of my truck..;o)
    Experiment with this one too. You can have it wake from sleep without an interrupt handler.
    CMCON=%00000111
    VRCON = 0
    PAUSEus 10
    TRISA = %00000110
    PORTA = %00000000
    PORTB = %00000001
    OPTION_REG.7 = 0
    OPTION_REG.6 = 0
    led var portA.3
        INTCON = %00001000  ' int-on-change enabled. RBIE=1, RBIF=0
    cycle:
        HIGH led
        LOW led
        @ Sleep                 ' sleep until button press
        WHILE (portB >> 4) !=15 ' wait for button release
          PAUSE 10              ' and read port so RBIF can
        WEND                    ' be cleared below.
        INTCON.0=0              ' now clear RBIF int flag
        goto cycle
    Global interrupts are disabled. Just enabled the int-on-change by setting RBIE, clearing RBIF, and it sleeps until a button is pressed.
    DT_INTs is more fun, but you can wake one up without an interrupt handler.
    -Bruce
    tech at rentron.com
    I compiled the code as shown, when powered up the led continues to blink but when I press a button on the keypad which would cause (PORTB >> 4) != 15 it still blinks.....
    I have even tried it with the following changes with same response:
    cycle:
    gosub checkstate
    HIGH led
    LOW led
    @ Sleep
    goto cycle
    checkstate:
    while (PORTB >> 4) != 15
    pause 20
    wend
    its almost like it never see an interrupt to get out of cycle. I also confirmed on PortB by checking with my meter on switch closure. With a switch closed and the bit I checked was PortB.4 I measured it at 2.192Vrms, switch open 4.99Vrms.
    Thanks for hanging around
    Bruce, just wanted to mention we must have posted about the same time the code that I just tried was the crayon version, I am about to try your latest.
    Again, Thank you.
    Make sure you have the watchdog timer disabled when using the assembler @ SLEEP command.
    -Bruce
    tech at rentron.com
    Ok, I didn't know about that...Thank you.
    Sorry. My fault for not mentioning this. The @ SLEEP instruction puts it to sleep forever until a watchdog timeout, or an interrupt wakes it up.
    When it wakes up due to watchdog timer timeout, it executes the instruction immediately after the @ SLEEP, and lands on your goto cycle.
    Any time you use the assembler version @ SLEEP you'll need to make sure you have WDT disabled unless you want it to wake up with the watchdog timer timeout.
    -Bruce
    tech at rentron.com
    Taz,
    Try this version with the nop just after @ SLEEP and see if this helps.
    CMCON=%00000111
    VRCON = 0
    PAUSEus 10
    TRISA = %00000110
    PORTA = %00000000
    PORTB = %00000001
    OPTION_REG.7 = 0
    OPTION_REG.6 = 0
    led var portA.3
        INT_CREATE
    cycle:
        HIGH led
        LOW led
        @ Sleep
        @ NOP
        goto cycle
    check:
          PAUSE 10
        WEND
        @ INT_RETURN
    -Bruce
    tech at rentron.com
