debouncing switches with a timer interrupt?
Results 1 to 28 of 28
    Dec 2009
    Kalamazoo
    that is just great. thanks for pointing me to the right direction, Mr Mike. its all fixed now.
    cheers
    NAG CON WIFE!
    WIFE VAR MOOD
    Aug 2005
    Michigan, USA
    Quote Originally Posted by DDDvvv View Post
    cheers
    You're very welcome Sir.
    Please note that the previous example can be optimized a bit. Since you're using the "new press" state as the action state in your program you don't need the "newlo" variable and its assignment statement. You can also retask the "swnew" variable and eliminate the "newhi" variable. Some XOR trickery is used to update the "swold" switch state latch to the new PortB pattern.
    '  swnew  ____-----_____-----_____   new switch sample (positive logic)
    '  swold  _____-----_____-----____   switch state latch
    '  swnew  ____-____-____-____-____   changes, press or release
    '  swnew  ____-_________-_________   new press bits
        swnew = PortB                  ' sample active hi switches
        swnew = swnew ^ swold          ' changes, press or release
        swold = swold ^ swnew          ' update switch state latch (swold = new PortB)
        swnew = swnew & swold          ' get "new press" bits
        IF swnew.4 = 1 THEN            ' if RB4 "new press"
          BTN_PLUS = 1                 ' set flag for main
    With your 1-msec interrupt intervals you might consider adding a piezo speaker and code for "new press" beeps;
    '  beep task (32-msec 500-Hz beep using 1-msec interrupts)
        IF beepctr > 0 THEN            ' if beep task running
          PortB = PortB ^ spkrpinmask  ' toggle piezo speaker pin
          beepctr = beepctr - 1        ' decrement beep msec counter
          BTN_PLUS = 1                 ' set flag for main and
          beepctr = 32                 ' task a new press beep
    If you experience bounce problems with a 1-msec sampling interval you might consider adding a counter and executing the switch sample code at some interval between 16 and 32 msecs.
    BTW, assembly language "parallel switch state logic" is incredibly efficient (6 or 8 words);
    ;  wreg  ___-----_____-----____   new switch sample (positive logic)
    ; swold  ____-----_____-----___   switch state latch
    ;  wreg  ___-____-____-____-___   changes, press or release
    ;  wreg  ___-_________-________   filter out new release bits
    ; flags  ___-----------________   toggle sw flags for main
            comf    PORTB,W         ; sample active lo switches
    ;       movf    PORTB,W         ; sample active hi switches
            andlw   b'11110000'     ; on RB7..RB4 pins
            xorwf   swold,W         ; changes, press or release
            xorwf   swold,F         ; update switch state latch
            andwf   swold,W         ; filter out "new release" bits
            skpz                    ; new press? no, skip, else
            bsf     beepctr,5       ; task a "new press" beep
            xorwf   flags,F         ; toggle sw flags for main
    Cheerful regards, Mike
