debouncing switches with a timer interrupt?
Results 1 to 28 of 28
    Sep 2005
    Campbell, CA
    The code below was written to use a momentary pushbutton switch as an ON/OFF control.
    It is written to be used in a Timer interrupt routine.
    PowerOnDelayTimer is the number of interrupts that the button must be held before turning ON the unit.
    PowerOFFDelayTimer is the number of interrupts that the button must be held before turning OFF the unit
    SwitchUpDelayTimer is the number of interrupts that must expire before the button can be pushed again (useful when you don't want someone rapidly turning ON and OFF a piece of hardware).
                IF !EnableSw THEN     ; Aliased pin, goes low when button pushed.
                     IF SwitchFlag THEN ; Switch has been pushed, but prevously released.
                       IF PowerSwitchCounter < 250 THEN
                               PowerSwitchCounter = PowerSwitchCounter + 1  ; don't let it overflow
                       IF PowerONstate = 0 THEN  ; Currently OFF
                           If PowerSwitchCounter >= PowerOnDelayTimer then           ; Turn on or off
                              Gosub PowerOn
                              SwitchFlag = 0
                              SwitchUpCounter = 0
                        ELSE      ; Currently OFF
                           If PowerSwitchCounter >= PowerOffDelayTimer then
                             GOSUB PowerOff
                              SwitchFlag = 0
                              SwitchUpCounter = 0
                    IF SwitchUpCounter < 250 THEN
                          SwitchUpCounter = SwitchUpCounter + 1
                    IF SwitchUpCounter > SwitchUpDelayTimer THEN
                         SwitchFlag = 1          ; Switch has been released
                         PowerSwitchCounter = 0
    Charles Linquist
    Sep 2005
    Campbell, CA
    I should state that SwitchFlag must be initialized to a non-zero value at the top of the program.
    Charles Linquist
    Aug 2005
    Michigan, USA
    I'd like to supplement Charles' fine example with an interrupt driven version of the "parallel switch state logic" example I posted earlier.
    This example uses a 1-msec timer driven interrupt "heart beat" which is perfect for toggling a piezo speaker at 500-Hz and it uses a simple counter to produce a 32-msec debounce/sample interval.
    Using a momentary switch to emulate a "toggle" switch (press to toggle from on-to-off or from off-to-on) can be accomplished directly by the driver by exclusive-or'ing the debounced "new press" bits with the "flags" switch flag bits variable. Main should test the switch flag bit and then clear it for "momentary" switches or simply test the switch flag bit for an emulated "toggle" switch.
    void interrupt()                // 1-msec Timer 2 interrupts
      pir1.TMR2IF = 0;              // clear TMR2 interrupt flag
    //  beep task (32-msec 500-Hz tone using 1-msec interrupts)
      if(beep)                      // if beep task running
      { spkrpin ^= 1;               // toggle speaker pin and
        beep--;                     // decrement beep msec counter
    //  switch state management (multi-switch "parallel" logic)
      if(--dbcount == 0)            // if 32-msec debounce interval
      { dbcount = 32;               // reset debounce timer and
        swnew = ~porta;             // sample active low switches
        swnew &= 0x0F;              // on RA3..RA0 pins
        swnew ^= swold;             // changes, press or release
        swold ^= swnew;             // update switch state latch
        swnew &= swold;             // filter out "new release" bits
        flags ^= swnew;             // toggle flag bits for 'main'
        if(swnew)                   // if any "new press" bits
          beep = 32;                // task a "new press" beep
    //  in "main"
      while(flags.0)                // while sw0 (RA0) "on" (toggle), do this block
      {                             // until new sw0 press toggles flags.0 to "off"
        if(flags.1)                 // if sw1 (RA1) "new press" (momentary)
        { flags.1 = 0;              // turn off flag and
          ...                       // do something
    Can you post the code you're having problems with? I suspect there's a very simple solution.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Dec 2009
    Kalamazoo
    thanks for all the replies guys. ive been away for the weekend, with no computer access. here's the code, fresh from the menubuilder application.
    its a gadget that im making, to keep track/records of my workout sessions. it will also have a realtime clock/stopwatch, all displayed on a 20x2 lcd with 4 menu buttons (next, previous, up down.)
    even with the "pause 200" debouncing, (default) everytime i try to cycle through menu items, with the push of a button, it skips three to six items. (same goes when you try to change a variable) at first, i thought that proteus simulation on my pentium 4 was slow (always bitching about "simulation not running in real time because of excessive cpu load" ) so i transferred the simulation to my intel i7 laptop, and proteus is not complaining any more. still having the same skipping items problem.
    ill try mr Arrati's snipet again, but meanwhile, here's the code.
            clear
    define OSC 16                                ;40 MHZ HS CRYSTAL
    OSCCON = %01110000
    ADCON0= %00000000                         ;PORT A ALL DIGITAL
    ANSEL0= %00000000                         ;PORT A ALL DIGITAL
    TRISA = %00000000                         ;
    TRISB = %11111100                         ;
    TRISC = %10111000                         ;
    LATA = %00000000                          ;
    LATB = %00000000                          ;
    LATC = %00000000                          ;
    'VARIABLE DECLARATION
    bMenuPos    var Byte     'Main menu position
    bSubMenuPos var Byte     'Sub menu position
    BTN_NEXT    var PORTB.4  'Next button
    BTN_PREV    var PORTB.5  'Previous button
    BTN_PLUS    var PORTB.6  'Plus button
    BTN_MINUS   var PORTB.7  'Minus button
    SQUATS_WT  VAR  Byte
    SQUATS_RP  VAR  Byte
    PULLDOWN_WT  VAR  Byte
    PULLDOWN_RP  VAR  Byte
    LATRAISE_WT  VAR  Byte
    LATRAISE_RP  VAR  Byte
    OVHEADPRESS_WT  VAR  Byte
    OVHEADPRESS_RP  VAR  Byte
    PREACHERCURL_WT  VAR  Byte
    PREACHERCURL_RP  VAR  Byte
    PUSHDOWN_WT  VAR  Byte
    PUSHDOWN_RP  VAR  Byte
    PECDECK_WT  VAR  Byte
    PECDECK_RP  VAR  Byte
    CABLESHRUG_WT  VAR  Byte
    CABLESHRUG_RP  VAR  Byte
    CALFRAISES_WT  VAR  Byte
    CALFRAISES_RP  VAR  Byte
    DBWRISTCURL_WT  VAR  Byte
    DBWRISTCURL_RP  VAR  Byte
    DECLINESITUP_WT  VAR  Byte
    DECLINESITUP_RP  VAR  Byte
    'END OF VARIABLE DECLARATION
    DEFINE LCD_DREG PORTA
    DEFINE LCD_DBIT 0
    DEFINE LCD_BITS 4
    DEFINE LCD_RSREG PORTC
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTC
    DEFINE LCD_EBIT 1
    PAUSE 500
    LCDOUT $FE, $01
    LCDOUT $FE, $80, " FITNESS GYM ASSIST"
    LCDOUT $FE, $C0, " COPYRIGHT DAVID M"
    PAUSE 1000
    MAIN
    GOSUB DisplayMainMenu
    GOTO MAIN
    'SUB ROUTINES
    'ROUTINE DisplayMainMenu
    'This routine handles the display of the main menu choices
    'All you need is to call from your main program this routine,
    'and have the button ports setup,
    DisplayMainMenu:
       bMenuPos=1   'This is the default menu option
    DisplayMainMenuLoop:
       IF bMenuPos=1 THEN
          LCDOUT $FE,1,"SQUATS WT"
       IF bMenuPos=2 THEN
          LCDOUT $FE,1,"SQUATS RP"
       IF bMenuPos=3 THEN
          LCDOUT $FE,1,"PULLDOWN WT"
       IF bMenuPos=4 THEN
          LCDOUT $FE,1,"PULLDOWN RP"
       IF bMenuPos=5 THEN
          LCDOUT $FE,1,"LAT RAISE WT"
       IF bMenuPos=6 THEN
          LCDOUT $FE,1,"LAT RAISE RP"
       IF bMenuPos=7 THEN
          LCDOUT $FE,1,"OVHEAD PRESS WT"
       IF bMenuPos=8 THEN
          LCDOUT $FE,1,"OVHEAD PRESS RP"
       IF bMenuPos=9 THEN
          LCDOUT $FE,1,"PREACHER CURL WT"
       IF bMenuPos=10 THEN
          LCDOUT $FE,1,"PREACHER CURL RP"
       IF bMenuPos=11 THEN
          LCDOUT $FE,1,"PUSHDOWN WT"
       IF bMenuPos=12 THEN
          LCDOUT $FE,1,"PUSHDOWN RP"
       IF bMenuPos=13 THEN
          LCDOUT $FE,1,"PEC DECK WT"
       IF bMenuPos=14 THEN
          LCDOUT $FE,1,"PEC DECK RP"
       IF bMenuPos=15 THEN
          LCDOUT $FE,1,"CABLE SHRUG WT"
       IF bMenuPos=16 THEN
          LCDOUT $FE,1,"CABLE SHRUG RP"
       IF bMenuPos=17 THEN
          LCDOUT $FE,1,"CALF RAISES WT"
       IF bMenuPos=18 THEN
          LCDOUT $FE,1,"CALF RAISES RP"
       IF bMenuPos=19 THEN
          LCDOUT $FE,1,"DBWRIST CURL WT"
       IF bMenuPos=20 THEN
          LCDOUT $FE,1,"DBWRIST CURL RP"
       IF bMenuPos=21 THEN
          LCDOUT $FE,1,"DECLINE SITUP WT"
       IF bMenuPos=22 THEN
          LCDOUT $FE,1,"DECLINE SITUP RP"
    RB_MainMenuLoop:
    ' BTN_PLUS is the Next Choice button
       IF BTN_PLUS=0 THEN
          PAUSE 200
          bMenuPos=bMenuPos+1
          IF bMenuPos>22 THEN
             bMenuPos=1
          Goto DisplayMainMenuLoop:
    ' BTN_PREV is the Exit button
       IF BTN_PREV=0 THEN
          PAUSE 200
    ' BTN_NEXT is the Goto SubMenu Choice button
       IF BTN_NEXT=0 THEN
          PAUSE 200
          GoSub DisplaySubMenu
    Goto RB_MainMenuLoop:
    'ROUTINE DisplaySubMenu
    'This routine handles the display of the sub menu choices
    DisplaySubMenu:
       bSubMenuPos=1   'This is the default menu option
    DisplaySubMenuLoop:
       IF bMenuPos=1 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"SQUATS WT ADJ"
       IF bMenuPos=2 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"SQUATS RP ADJ"
       IF bMenuPos=3 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"PULLDOWN WT ADJ"
       IF bMenuPos=4 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"PULLDOWN RP ADJ"
       IF bMenuPos=5 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"LAT RAISE WT ADJ"
       IF bMenuPos=6 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"LAT RAISE RP ADJ"
       IF bMenuPos=7 AND bSubMenuPos=1 THEN
       IF bMenuPos=8 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"OVHEAD PRESS RP ADJ"
       IF bMenuPos=9 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"PREACHER CURL WT ADJ"
       IF bMenuPos=10 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"PREACHER CURL RP ADJ"
       IF bMenuPos=11 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"PUSHDOWN WT ADJ"
       IF bMenuPos=12 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"PUSHDOWN RP ADJ"
       IF bMenuPos=13 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"PEC DECK WT ADJ"
       IF bMenuPos=14 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"PEC DECK RP ADJ"
       IF bMenuPos=15 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"CABLE SHRUG WT ADJ"
       IF bMenuPos=16 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"CABLE SHRUG RP ADJ"
       IF bMenuPos=17 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"CALF RAISES WT ADJ"
       IF bMenuPos=18 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"CALF RAISES RP ADJ"
       IF bMenuPos=19 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"DBWRIST CURL WT ADJ"
       IF bMenuPos=20 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"DBWRIST CURL RP ADJ"
       IF bMenuPos=21 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"DECLINE SITUP WT ADJ"
       IF bMenuPos=22 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"DECLINE SITUP RP ADJ"
    RB_SUBMenuLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 200
          bSubMenuPos=bSubMenuPos+1
          IF bMenuPos=1 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=2 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=3 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=4 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=5 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=6 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=7 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=8 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=9 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=10 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=11 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=12 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=13 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=14 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=15 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=16 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=17 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=18 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=19 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=20 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=21 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=22 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          GoTo DisplaySubMenuLoop
       IF BTN_PREV=0 THEN
          PAUSE 200
       IF BTN_NEXT=0 THEN
          PAUSE 200
             GoSub SUB_1_1
             GoSub SUB_2_1
             GoSub SUB_3_1
             GoSub SUB_4_1
             GoSub SUB_5_1
             GoSub SUB_6_1
             GoSub SUB_7_1
             GoSub SUB_8_1
             GoSub SUB_9_1
             GoSub SUB_10_1
             GoSub SUB_11_1
             GoSub SUB_12_1
             GoSub SUB_13_1
             GoSub SUB_14_1
             GoSub SUB_15_1
             GoSub SUB_16_1
             GoSub SUB_17_1
             GoSub SUB_18_1
             GoSub SUB_19_1
             GoSub SUB_20_1
             GoSub SUB_21_1
             GoSub SUB_22_1
    GoTo RB_SUBMenuLoop
    '*************** SUB SUB_1_1*********
    SUB_1_1:
    'First read the variables from eprom
       READ 1,SQUATS_WT
    SUB_1_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC SQUATS_WT
    SUB_1_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF SQUATS_WT>=255 THEN
             SQUATS_WT=0
             SQUATS_WT=SQUATS_WT+1
          GoTo SUB_1_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF SQUATS_WT<=0 THEN
             SQUATS_WT=255
             SQUATS_WT=SQUATS_WT-1
          GoTo SUB_1_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 1,SQUATS_WT
    GoTo SUB_1_1MLoop
    '*************** SUB SUB_2_1*********
    SUB_2_1:
       READ 2,SQUATS_RP
    SUB_2_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC SQUATS_RP
    SUB_2_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF SQUATS_RP>=255 THEN
             SQUATS_RP=0
             SQUATS_RP=SQUATS_RP+1
          GoTo SUB_2_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF SQUATS_RP<=0 THEN
             SQUATS_RP=255
             SQUATS_RP=SQUATS_RP-1
          GoTo SUB_2_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 2,SQUATS_RP
    GoTo SUB_2_1MLoop
    '*************** SUB SUB_3_1*********
    SUB_3_1:
       READ 3,PULLDOWN_WT
    SUB_3_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC PULLDOWN_WT
    SUB_3_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF PULLDOWN_WT>=255 THEN
             PULLDOWN_WT=0
             PULLDOWN_WT=PULLDOWN_WT+1
          GoTo SUB_3_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF PULLDOWN_WT<=0 THEN
             PULLDOWN_WT=255
             PULLDOWN_WT=PULLDOWN_WT-1
          GoTo SUB_3_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 3,PULLDOWN_WT
    GoTo SUB_3_1MLoop
    '*************** SUB SUB_4_1*********
    SUB_4_1:
       READ 4,PULLDOWN_RP
    SUB_4_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC PULLDOWN_RP
    SUB_4_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF PULLDOWN_RP>=255 THEN
             PULLDOWN_RP=0
             PULLDOWN_RP=PULLDOWN_RP+1
          GoTo SUB_4_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF PULLDOWN_RP<=0 THEN
             PULLDOWN_RP=255
             PULLDOWN_RP=PULLDOWN_RP-1
          GoTo SUB_4_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 4,PULLDOWN_RP
    GoTo SUB_4_1MLoop
    '*************** SUB SUB_5_1*********
    SUB_5_1:
       READ 5,LATRAISE_WT
    SUB_5_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC LATRAISE_WT
    SUB_5_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF LATRAISE_WT>=255 THEN
             LATRAISE_WT=0
             LATRAISE_WT=LATRAISE_WT+1
          GoTo SUB_5_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF LATRAISE_WT<=0 THEN
             LATRAISE_WT=255
             LATRAISE_WT=LATRAISE_WT-1
          GoTo SUB_5_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 5,LATRAISE_WT
    GoTo SUB_5_1MLoop
    '*************** SUB SUB_6_1*********
    SUB_6_1:
       READ 6,LATRAISE_RP
    SUB_6_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC LATRAISE_RP
    SUB_6_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF LATRAISE_RP>=255 THEN
             LATRAISE_RP=0
             LATRAISE_RP=LATRAISE_RP+1
          GoTo SUB_6_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF LATRAISE_RP<=0 THEN
             LATRAISE_RP=255
             LATRAISE_RP=LATRAISE_RP-1
          GoTo SUB_6_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 6,LATRAISE_RP
    GoTo SUB_6_1MLoop
    '*************** SUB SUB_7_1*********
    SUB_7_1:
       READ 7,OVHEADPRESS_WT
    SUB_7_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC OVHEADPRESS_WT
    SUB_7_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF OVHEADPRESS_WT>=255 THEN
             OVHEADPRESS_WT=0
             OVHEADPRESS_WT=OVHEADPRESS_WT+1
          GoTo SUB_7_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF OVHEADPRESS_WT<=0 THEN
             OVHEADPRESS_WT=255
             OVHEADPRESS_WT=OVHEADPRESS_WT-1
          GoTo SUB_7_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 7,OVHEADPRESS_WT
    GoTo SUB_7_1MLoop
    '*************** SUB SUB_8_1*********
    SUB_8_1:
       READ 8,OVHEADPRESS_RP
    SUB_8_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC OVHEADPRESS_RP
    SUB_8_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF OVHEADPRESS_RP>=255 THEN
             OVHEADPRESS_RP=0
             OVHEADPRESS_RP=OVHEADPRESS_RP+1
          GoTo SUB_8_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF OVHEADPRESS_RP<=0 THEN
             OVHEADPRESS_RP=255
             OVHEADPRESS_RP=OVHEADPRESS_RP-1
          GoTo SUB_8_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 8,OVHEADPRESS_RP
    GoTo SUB_8_1MLoop
    '*************** SUB SUB_9_1*********
    SUB_9_1:
       READ 9,PREACHERCURL_WT
    SUB_9_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC PREACHERCURL_WT
    SUB_9_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF PREACHERCURL_WT>=255 THEN
             PREACHERCURL_WT=0
             PREACHERCURL_WT=PREACHERCURL_WT+1
          GoTo SUB_9_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF PREACHERCURL_WT<=0 THEN
             PREACHERCURL_WT=255
             PREACHERCURL_WT=PREACHERCURL_WT-1
          GoTo SUB_9_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 9,PREACHERCURL_WT
    GoTo SUB_9_1MLoop
    '*************** SUB SUB_10_1*********
    SUB_10_1:
       READ 10,PREACHERCURL_RP
    SUB_10_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC PREACHERCURL_RP
    SUB_10_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF PREACHERCURL_RP>=255 THEN
             PREACHERCURL_RP=0
             PREACHERCURL_RP=PREACHERCURL_RP+1
          GoTo SUB_10_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF PREACHERCURL_RP<=0 THEN
             PREACHERCURL_RP=255
             PREACHERCURL_RP=PREACHERCURL_RP-1
          GoTo SUB_10_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 10,PREACHERCURL_RP
    GoTo SUB_10_1MLoop
    '*************** SUB SUB_11_1*********
    SUB_11_1:
       READ 11,PUSHDOWN_WT
    SUB_11_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC PUSHDOWN_WT
    SUB_11_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF PUSHDOWN_WT>=255 THEN
             PUSHDOWN_WT=0
             PUSHDOWN_WT=PUSHDOWN_WT+1
          GoTo SUB_11_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF PUSHDOWN_WT<=0 THEN
             PUSHDOWN_WT=255
             PUSHDOWN_WT=PUSHDOWN_WT-1
          GoTo SUB_11_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 11,PUSHDOWN_WT
    GoTo SUB_11_1MLoop
    '*************** SUB SUB_12_1*********
    SUB_12_1:
       READ 12,PUSHDOWN_RP
    SUB_12_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC PUSHDOWN_RP
    SUB_12_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF PUSHDOWN_RP>=255 THEN
             PUSHDOWN_RP=0
             PUSHDOWN_RP=PUSHDOWN_RP+1
          GoTo SUB_12_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF PUSHDOWN_RP<=0 THEN
             PUSHDOWN_RP=255
             PUSHDOWN_RP=PUSHDOWN_RP-1
          GoTo SUB_12_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 12,PUSHDOWN_RP
    GoTo SUB_12_1MLoop
    '*************** SUB SUB_13_1*********
    SUB_13_1:
       READ 13,PECDECK_WT
    SUB_13_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC PECDECK_WT
    SUB_13_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF PECDECK_WT>=255 THEN
             PECDECK_WT=0
             PECDECK_WT=PECDECK_WT+1
          GoTo SUB_13_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF PECDECK_WT<=0 THEN
             PECDECK_WT=255
             PECDECK_WT=PECDECK_WT-1
          GoTo SUB_13_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 13,PECDECK_WT
    GoTo SUB_13_1MLoop
    '*************** SUB SUB_14_1*********
    SUB_14_1:
       READ 14,PECDECK_RP
    SUB_14_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC PECDECK_RP
    SUB_14_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF PECDECK_RP>=255 THEN
             PECDECK_RP=0
             PECDECK_RP=PECDECK_RP+1
          GoTo SUB_14_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF PECDECK_RP<=0 THEN
             PECDECK_RP=255
             PECDECK_RP=PECDECK_RP-1
          GoTo SUB_14_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 14,PECDECK_RP
    GoTo SUB_14_1MLoop
    '*************** SUB SUB_15_1*********
    SUB_15_1:
       READ 15,CABLESHRUG_WT
    SUB_15_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC CABLESHRUG_WT
    SUB_15_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF CABLESHRUG_WT>=255 THEN
             CABLESHRUG_WT=0
             CABLESHRUG_WT=CABLESHRUG_WT+1
          GoTo SUB_15_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF CABLESHRUG_WT<=0 THEN
             CABLESHRUG_WT=255
             CABLESHRUG_WT=CABLESHRUG_WT-1
          GoTo SUB_15_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 15,CABLESHRUG_WT
    GoTo SUB_15_1MLoop
    '*************** SUB SUB_16_1*********
    SUB_16_1:
       READ 16,CABLESHRUG_RP
    SUB_16_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC CABLESHRUG_RP
    SUB_16_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF CABLESHRUG_RP>=255 THEN
             CABLESHRUG_RP=0
             CABLESHRUG_RP=CABLESHRUG_RP+1
          GoTo SUB_16_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF CABLESHRUG_RP<=0 THEN
             CABLESHRUG_RP=255
             CABLESHRUG_RP=CABLESHRUG_RP-1
          GoTo SUB_16_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 16,CABLESHRUG_RP
    GoTo SUB_16_1MLoop
    '*************** SUB SUB_17_1*********
    SUB_17_1:
       READ 17,CALFRAISES_WT
    SUB_17_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC CALFRAISES_WT
    SUB_17_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF CALFRAISES_WT>=255 THEN
             CALFRAISES_WT=0
             CALFRAISES_WT=CALFRAISES_WT+1
          GoTo SUB_17_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF CALFRAISES_WT<=0 THEN
             CALFRAISES_WT=255
             CALFRAISES_WT=CALFRAISES_WT-1
          GoTo SUB_17_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 17,CALFRAISES_WT
    GoTo SUB_17_1MLoop
    '*************** SUB SUB_18_1*********
    SUB_18_1:
       READ 18,CALFRAISES_RP
    SUB_18_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC CALFRAISES_RP
    SUB_18_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF CALFRAISES_RP>=255 THEN
             CALFRAISES_RP=0
             CALFRAISES_RP=CALFRAISES_RP+1
          GoTo SUB_18_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF CALFRAISES_RP<=0 THEN
             CALFRAISES_RP=255
             CALFRAISES_RP=CALFRAISES_RP-1
          GoTo SUB_18_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 18,CALFRAISES_RP
    GoTo SUB_18_1MLoop
    '*************** SUB SUB_19_1*********
    SUB_19_1:
       READ 19,DBWRISTCURL_WT
    SUB_19_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC DBWRISTCURL_WT
    SUB_19_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF DBWRISTCURL_WT>=255 THEN
             DBWRISTCURL_WT=0
             DBWRISTCURL_WT=DBWRISTCURL_WT+1
          GoTo SUB_19_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF DBWRISTCURL_WT<=0 THEN
             DBWRISTCURL_WT=255
             DBWRISTCURL_WT=DBWRISTCURL_WT-1
          GoTo SUB_19_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 19,DBWRISTCURL_WT
    GoTo SUB_19_1MLoop
    '*************** SUB SUB_20_1*********
    SUB_20_1:
       READ 20,DBWRISTCURL_RP
    SUB_20_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC DBWRISTCURL_RP
    SUB_20_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF DBWRISTCURL_RP>=255 THEN
             DBWRISTCURL_RP=0
             DBWRISTCURL_RP=DBWRISTCURL_RP+1
          GoTo SUB_20_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF DBWRISTCURL_RP<=0 THEN
             DBWRISTCURL_RP=255
             DBWRISTCURL_RP=DBWRISTCURL_RP-1
          GoTo SUB_20_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 20,DBWRISTCURL_RP
    GoTo SUB_20_1MLoop
    '*************** SUB SUB_21_1*********
    SUB_21_1:
       READ 21,DECLINESITUP_WT
    SUB_21_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC DECLINESITUP_WT
    SUB_21_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF DECLINESITUP_WT>=255 THEN
             DECLINESITUP_WT=0
             DECLINESITUP_WT=DECLINESITUP_WT+1
          GoTo SUB_21_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF DECLINESITUP_WT<=0 THEN
             DECLINESITUP_WT=255
             DECLINESITUP_WT=DECLINESITUP_WT-1
          GoTo SUB_21_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 21,DECLINESITUP_WT
    GoTo SUB_21_1MLoop
    '*************** SUB SUB_22_1*********
    SUB_22_1:
       READ 22,DECLINESITUP_RP
    SUB_22_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC DECLINESITUP_RP
    SUB_22_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF DECLINESITUP_RP>=255 THEN
             DECLINESITUP_RP=0
             DECLINESITUP_RP=DECLINESITUP_RP+1
          GoTo SUB_22_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF DECLINESITUP_RP<=0 THEN
             DECLINESITUP_RP=255
             DECLINESITUP_RP=DECLINESITUP_RP-1
          GoTo SUB_22_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 22,DECLINESITUP_RP
    GoTo SUB_22_1MLoop
    NAG CON WIFE!
    WIFE VAR MOOD
    Instead of a pause after any button press try using WHILE WEND to wait for it to be released.
    IF BTN_PLUS=0 THEN
        WHILE BTN_PLUS = 0
        WEND
    Also - you have a ton of RETURN statements after GOTOs' so it never lands on these. I haven't followed your code all the way through, but if it needs to land on the returns, that could be another problem.
    See if the attached works without skipping menu options.
    -Bruce
    tech at rentron.com
    Aug 2005
    Michigan, USA
    That's the easy fix but I cringe every time someone suggests waiting for a switch release.
    Since you'll probably be using interrupts eventually to support an RTC or Timer function, I would suggest delegating switch debounce/management to the ISR. Then you're working with fully debounced real-time "new press" flag bits. Your program would need the ISR and a couple subtle changes;
    SWNEW       var Byte     '
    SWOLD       var Byte     ' switch state latch
    FLAGS       var Byte     ' switch flag bits
    BTN_NEXT    var FLAGS.4  'Next button
    BTN_PREV    var FLAGS.5  'Previous button
    BTN_PLUS    var FLAGS.6  'Plus button
    BTN_MINUS   var FLAGS.7  'Minus button
    Changes to your main program include testing for a '1' instead of a '0' and clearing the flag bit when you use it.
    RB_SUBMenuLoop:
       IF BTN_PLUS=1 THEN
          BTN_PLUS=0
       IF BTN_PREV=1 THEN
          BTN_PREV=0
       IF BTN_NEXT=1 THEN
          BTN_NEXT=0
    GoTo RB_SUBMenuLoop
    If you're interested, you might consider trying out a non-interrupt version by adding a sample/debounce subroutine to your program;
    '  I need help with PBP commands for a "delay" and for "compliment"
    SUB_SWITCHES                    '
      delay_ms(16)                  ' 16-msec debounce interval  ??? how
      SWNEW = ~PORTB                ' sample active lo switches  ??? how
      SWNEW = SWNEW AND 0xF0        ' on RB7..RB4 pins
      SWNEW = SWNEW XOR SWOLD       ' changes, press or release
      SWOLD = SWOLD XOR SWNEW       ' update switch state latch
      SWNEW = SWNEW AND SWOLD       ' filter out "new release" bits
      FLAGS = FLAGS XOR SWNEW       ' toggle switch flag bits
    Then you would need to call the subroutine at the top of each of your switch test loops (forgive me for shortening your program and for any PBP syntax errors);
    RB_SUBMenuLoop:
      GoSub SUB_SWITCHES                    ' sample switches
       IF BTN_PLUS=1 THEN
          BTN_PLUS=0
          IF bSubMenuPos>1 THEN
             bSubMenuPos=1
       IF BTN_PREV=1 THEN
          BTN_PREV=0
       IF BTN_NEXT=1 THEN
          BTN_NEXT=0
          IF bSubMenuPos=1 THEN
             GoSub SUB_ADJ
    GoTo RB_SUBMenuLoop
    '   adjust EEPROM value indexed by 'bMenuPos' variable (1..22)
    '   1 SQUATS_WT          9 PREACHER CURL WT  17 CALF RAISES WT
    '   2 SQUATS_RP         10 PREACHER CURL RP  18 CALF RAISES RP
    '   3 PULLDOWN WT       11 PUSHDOWN WT       19 DBWRIST CURL WT
    '   4 PULLDOWN RP       12 PUSHDOWN RP       20 DBWRIST CURL RP
    '   5 LAT RAISE WT      13 PEC DECK WT       21 DECLINE SITUP WT
    '   6 LAT RAISE RP      14 PEC DECK RP       22 DECLINE SITUP RP
    '   7 OVHEAD PRESS WT   15 CABLE SHRUG WT
    '   8 OVHEAD PRESS RP   16 CABLE SHRUG RP
    SUB_ADJ:                        '
      READ bMenuPos,COUNTER         ' read EEPROM location 1..22
    SUB_ADJ_1MDLoop:                '
      LCDOUT $FE,192,"                "
      LCDOUT $FE,192,DEC COUNTER    '
    SUB_ADJ_1MLoop:                 '
      IF BTN_PLUS = 1 THEN          ' if BTN_PLUS press
        BTN_PLUS = 0                ' clear switch flag
        IF COUNTER>=255 THEN        '
          COUNTER=0                 '
        ELSE                        '
          COUNTER=COUNTER+1         '
        ENDIF                       '
        GoTo SUB_ADJ_1MDLoop        ' refresh displayed count
      ENDIF                         '
      IF BTN_MINUS=1 THEN           ' if BTN_MINUS press
        BTN_MINUS=0                 ' clear switch flag
        IF COUNTER<=0 THEN          '
          COUNTER=255               '
        ELSE                        '
          COUNTER=COUNTER-1         '
        ENDIF                       '
      ENDIF                         '
      IF BTN_PREV=1 THEN            ' if BTN_PREV press
        BTN_PREV=0                  ' clear switch flag
        WRITE bMenuPos,COUNTER      ' update EEPROM
        RETURN                      ' exit
      ENDIF                         '
      GoTo SUB_X_1MLoop             ' loop (for key press)
    RETURN                          '
    Have fun. Cheerful regards, Mike
    Mike,
    With his switch inputs on RB7-RB4, how would you go about that without waiting for a switch release, and then clearing the int-on-change flag bit?
    Wouldn't releasing the switch re-trigger the interrupt?
    -Bruce
    tech at rentron.com
