debouncing switches with a timer interrupt?
Results 1 to 28 of 28
    Dec 2009
    Kalamazoo
    thanks guys.
    i tried the capacitor method, and that did not work well. still skipping menu items.
    im using proteus simulation, and i tried every value of cap, 1000uf to 0.000001 uf., and everything in between.
    ill try integrate the software flag idea into the problem, and hope that it fixes it. thanks
    NAG CON WIFE!
    WIFE VAR MOOD
    Dec 2009
    Kalamazoo
    Default still not functioning
    hi all
    i tried to implement the flag idea, but still the same result. menu item cycles through 3 to 6 items with one push of a button. here's the code snippet
    RB_MainMenuLoop:
    ' BTN_PLUS is the Next Choice button
        PAUSE 1
          IF BTN_PLUS=0 THEN
          ;PAUSE 200
          IF FLAG_PLUS = 0 THEN
          bMenuPos=bMenuPos+1
          FLAG_PLUS = 1
          FLAG_PLUS = 0
          IF BTN_PLUS = 0 THEN FLAG_PLUS = 1
          ;ENDIF
          IF bMenuPos>22 THEN
             bMenuPos=1
          Goto DisplayMainMenuLoop:
    im beginning to think that debouncing is not the problem. is there any other way to skin this cat?
    NAG CON WIFE!
    WIFE VAR MOOD
    May 2008
    Italy
    Counter Var Byte
    RB_MainMenuLoop:
    PAUSE 1
    IF BTN_PLUS=0 THEN
    bMenuPos = bMenuPos + 1
    FLAG_PLUS = 1
    Counter = 0
    Pause = 10
    Counter = Counter + 1
    IF Counter > 50 THEN FLAG_PLUS = 0 : Counter = 0
    IF bMenuPos>22 THEN
    bMenuPos=1
    Try this snippet and see how it works. You can tune the PAUSE 10 and Counter > 5, to better values to suite your need.
    Al.
    Quote Originally Posted by DDDvvv View Post
    hi all
    You should understand debouncing NEED time, where ever this time comes from ( capacitor, timer ...)
    the idea of debouncing is :
    " Does the electrical state of pin still changes afer X milliseconds ??? "
    so, you can't get a correct answer before X milliseconds !!! - Obvious -
    But 200 ms is debouncing time for really poor quality switches, 20 ms can be obtained easily.
    note also switches " bounce " when closing its contact ... not when opening it !!!
    so, ... is it here THE good idea ???
    Further, May I tell you a real time timer might not be disturbed by a keypress ... - or your program is " not so good " ...
    the delay needed by the RTC to be updated is so far smaller than a key press action ...
    Aug 2005
    Michigan, USA
    Consider using a switch state latch and relatively simple logic to sample your switches and detect the "new press" state while ignoring the other switch states. Here are the switch states;
    swnew swold  switch state
      1     0    a "new press"
      1     1    still pressed
      0     1    a "new release"
      0     0    still released
    Sample the switches at a decent debounce interval (16 to 25 msecs) either in your main program loop or in a timer based interrupt service routine. You only need a few lines of code to implement the switch state logic for multiple switches (perhaps one of the PBP gurus can interpret the C code? Sorry!);
    //  swnew  ____---____-----_____   new switch sample
    //  swold  _____---____-----____   switch state latch
    //  delta  ____-__-___-____-____   changes, press or release
    //  newhi  ____-______-_________   filter out release bits
    while(1)                  //
      delay_ms(24)            // 24-msec debounce interval
      swnew = ~porta;         // sample active-lo switches
      swnew &= 0x0F;          // on RA3..RA0 pins
      swnew ^= swold;         // changes, press or release
      swold ^= swnew;         // update switch state latch
      swnew &= swold;         // filter out "new release" bits
      if(swnew)               // if any "new press" bits
      { beep();               // task a "new press" beep
      if(swnew.0)             // if RB0 "new press"
      if(swnew.1)             // if RB1 "new press"
    If you implement the method in an ISR you'll need to inclusive-or "swnew" with a "flags" register for your main program.
    Kind regards, Mike
    Sep 2005
    Campbell, CA
    The code below was written to use a momentary pushbutton switch as an ON/OFF control.
    It is written to be used in a Timer interrupt routine.
    PowerOnDelayTimer is the number of interrupts that the button must be held before turning ON the unit.
    PowerOFFDelayTimer is the number of interrupts that the button must be held before turning OFF the unit
    SwitchUpDelayTimer is the number of interrupts that must expire before the button can be pushed again (useful when you don't want someone rapidly turning ON and OFF a piece of hardware).
                IF !EnableSw THEN     ; Aliased pin, goes low when button pushed.
                     IF SwitchFlag THEN ; Switch has been pushed, but prevously released.
                       IF PowerSwitchCounter < 250 THEN
                               PowerSwitchCounter = PowerSwitchCounter + 1  ; don't let it overflow
                       IF PowerONstate = 0 THEN  ; Currently OFF
                           If PowerSwitchCounter >= PowerOnDelayTimer then           ; Turn on or off
                              Gosub PowerOn
                              SwitchFlag = 0
                              SwitchUpCounter = 0
                        ELSE      ; Currently OFF
                           If PowerSwitchCounter >= PowerOffDelayTimer then
                             GOSUB PowerOff
                              SwitchFlag = 0
                              SwitchUpCounter = 0
                    IF SwitchUpCounter < 250 THEN
                          SwitchUpCounter = SwitchUpCounter + 1
                    IF SwitchUpCounter > SwitchUpDelayTimer THEN
                         SwitchFlag = 1          ; Switch has been released
                         PowerSwitchCounter = 0
    Charles Linquist
    Sep 2005
    Campbell, CA
    I should state that SwitchFlag must be initialized to a non-zero value at the top of the program.
    Charles Linquist
    Aug 2005
    Michigan, USA
    I'd like to supplement Charles' fine example with an interrupt driven version of the "parallel switch state logic" example I posted earlier.
    This example uses a 1-msec timer driven interrupt "heart beat" which is perfect for toggling a piezo speaker at 500-Hz and it uses a simple counter to produce a 32-msec debounce/sample interval.
    Using a momentary switch to emulate a "toggle" switch (press to toggle from on-to-off or from off-to-on) can be accomplished directly by the driver by exclusive-or'ing the debounced "new press" bits with the "flags" switch flag bits variable. Main should test the switch flag bit and then clear it for "momentary" switches or simply test the switch flag bit for an emulated "toggle" switch.
    void interrupt()                // 1-msec Timer 2 interrupts
      pir1.TMR2IF = 0;              // clear TMR2 interrupt flag
    //  beep task (32-msec 500-Hz tone using 1-msec interrupts)
      if(beep)                      // if beep task running
      { spkrpin ^= 1;               // toggle speaker pin and
        beep--;                     // decrement beep msec counter
    //  switch state management (multi-switch "parallel" logic)
      if(--dbcount == 0)            // if 32-msec debounce interval
      { dbcount = 32;               // reset debounce timer and
        swnew = ~porta;             // sample active low switches
        flags ^= swnew;             // toggle flag bits for 'main'
          beep = 32;                // task a "new press" beep
    //  in "main"
      while(flags.0)                // while sw0 (RA0) "on" (toggle), do this block
      {                             // until new sw0 press toggles flags.0 to "off"
        if(flags.1)                 // if sw1 (RA1) "new press" (momentary)
        { flags.1 = 0;              // turn off flag and
          ...                       // do something
    Can you post the code you're having problems with? I suspect there's a very simple solution.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
