Time comparison
Results 1 to 21 of 21
Thread: Time comparison
    malc-c's Avatar
    malc-c Guest
    Darrel,
    Changed the code and it's still not functioning right.
    If I set the on time as 15:00 and off time as 15:01 the led comes on at 15:01 and stays on... well past the programmed stop time... any ideas ?
    CheckTimes:
    TimeCmpFlags = 0  ; clear flags first
         ; if the Start and Stop times are the same, then Always OFF
      if (lightsetHR[fn]=timeH) AND _
         (lightsetMN[fn]=timeM) then AlwaysOFF
         ; is it past the Start time?
      if (timeH>lightsetHR[fn]) OR _
         (timeH=lightsetHR[fn] AND timeM >= lightsetMN[fn])then PastStart=1
         ; is it past the Stop time?
      if (timeH>lightoffHR[fn]) OR _
         (timeH=lightoffHR[fn] AND timeM >= lightoffMN[fn])then PastStop=1
         ; does the period end the following day?
      if (lightoffHR[fn]< lightsetHR[fn]) OR _
         (lightoffHR[fn]=lightsetHR[fn] AND lightoffMN[fn] < lightsetMN[fn]) then NextDay=1
      if !NextDay then                               ; same day, use AND
          if PastStart AND !PastStop then ProgON = 1
      else                                           ; next day, use OR
          IF PastStart OR !PastStop then ProgON = 1
    AlwaysOFF:
    malc-c's Avatar
    malc-c Guest
    Default back to the drawing board
    OK something has really got screwed up....
    Here's the menu routine which is used to set the times for the lighting
    Lighting:
    Lighton:
    Lcdout $FE,2
    LCDOUT $FE,$80,"Set On Time For "
        IF H_butt = 0 THEN GOSUB IncHours
        IF M_butt = 0 THEN GOSUB IncMinutes
        lightsetHR[fn]=Hours
        lightsetMN[fn]=Minutes
        if viv >=2 then viv =2
        LCDOUT $FE,$C0,"Light Circuit ",#viv
        lcdout $FE,$94,#lightsetHR[fn] DIG 1,#lightsetHR[fn] DIG 0,":",#lightsetMN[fn] DIG 1,#lightsetMN[fn] DIG 0
    pause 200
    If S_butt = 0 then
    pause 250
    fn = fn +1
    viv = viv+1
    hours = 0
    minutes = 0
    If fn > 1 then
    LCDOUT $FE,1
    viv=1
    fn=0
    goto lightoff
    goto lighton
    lightoff:
    Lcdout $FE,2
    LCDOUT $FE,$80,"Set Off Time For "
        lightoffHR[fn] = Hours
        lightoffMN[fn] = Minutes
        lcdout $FE,$94,#lightoffHR[fn] DIG 1,#lightoffHR[fn] DIG 0,":",#lightoffMN[fn] DIG 1,#lightoffMN[fn] DIG 0
    pause 200
    If !S_butt then
    pause 250
    fn = fn +1
    viv = viv +1
    hours = 0
    minutes = 0
    If fn >=2 then
    LCDOUT $FE,1
    goto mainmenu
    goto lightoff
    so I added the following lines to display the times on the LCD when the program is running
    lcdout $FE,$D4+8,#lightsetHR[fn] DIG 1,#lightsetHR[fn] DIG 0,":",#lightsetMN[fn] DIG 1,#lightsetMN[fn] DIG 0
    lcdout $FE,$D4+14,#lightoffHR[fn] DIG 1,#lightoffHR[fn] DIG 0,":",#lightoffMN[fn] DIG 1,#lightoffMN[fn] DIG 0
    setting the time on to 00:00 and the off time to 00:01 the LCD displays 00:50 and 01:00 respectively. So obviously DT's routine will never match the times set..... I don't know why this has happened because in the original code it matched perfectly....
    malc-c's Avatar
    malc-c Guest
    Default pulling my hair out
    OK as I couldn't figure the above out I started from scratch (again) and tried this:
    For fn = 0 to 1
    If lightsetHR[fn]<timeH or lightsetHR[fn]>timeH and lightsetMN[fn]<timeM or lightsetMN[fn]>timeM and lightoffHR[fn]<timeH OR lightoffHR[fn]>timeH and lightoffMN[fn]<timeM OR lightoffMN[fn]>timeM Then
            LCDOut $FE, $94+9,"          "
            if fn=0 then Lights1 = 0
            if fn=1 then Lights2 = 0
    If lightsetHR[fn]=timeH and lightsetMN[fn]=timeM then         'compare value of each set time to current time and if matches
        if fn=0 then Lights1 = 1
        if fn=1 then Lights2 = 1                              'turn on those light
        LCDOut $FE, $94+9,"Lights ON"
    next
    fOR fn=0 to 3
    If StartHour[fn]<timeH or StartHour[fn]>timeH and StartMin[fn]<timeM or StartMin[fn]>timeM and StopHour[fn]<timeH OR StopHour[fn]>timeH and StopMin[fn]<timeM OR StopMin[fn]>timeM then          'compare value of each start time to current time and if matches
       LCDOut $FE, $94,"       "
       SetPoints[fn]=normtemp[fn]
    If StartHour[fn]=timeH and StartMin[fn]=timeM then         'compare value of each start time to current time and if matches
       SetPoints[fn]=Droptemp[fn]                              'change the corresponding set point to the drop temperature
       LCDOut $FE, $94,"Night"
    if StopHour[fn]=timeH and StopMin[fn]=timeM then           'compare value of each stop time to current time and if matches
       LCDOut $FE, $94,"       "
       SetPoints[fn]=normtemp[fn]                             'change value back to normal temperature
    Endif
    next fn
    Which works, apart from the original problem, in that at midnight the lights come on and stay on, and the temperatures drop to the default drop temperature. My guess is that as both start times and stop times = 00:00 this is what's causing the issue.
    Anyone able to help come up with a suitable working snippet of code, or tell me why it doesn't work correctly when using DTs code ?
    If everything is working except midnight add a
    if midnight skip
    this
    that
    and the other thing
    Back to the drawing board??
    I don't know Malc.
    In post #14, you found out that the Start and Stop times were not being stored correctly from your button input routines, or they are getting changed somewhere else in the program.
    And I agree, the routines I showed won't work if the preset times are wrong.
    So why did you scrap the CheckTimes routine?
    That isn't changing your start/stop times.
    The latest code you showed would not compile.
    Missing = signs for one (lightsetHR[fn]timeH).
    malc-c's Avatar
    malc-c Guest
    Default thanks
    Guys,
    Thanks for the replies... I should be resting (been unwell recently) and not really spending all day on this ! maybe that's why my brain hurts !! - but I think I've found what is causing the problem...
    On the easyPIC5 board, I noticed that when the time reached 00:00, LEDs on B5 - B7 seemed to strobe, and then stop at 00:01 - this was also observed on the version in the prototype, as the lights flashed at midnight today ! - this seems to put the PIC in some limbo / reset state... ?
    I've managed to get something working that sets the night time drops and turns on the lights if set before the activation time... I'm going to look at either Daves suggestion of a skip midnight routine, or take a fresh look at Darrel's routines and see if I can get that working... would love to know why the PIC is behaving so strange at midnight
