Time comparison
Results 1 to 21 of 21
Thread: Time comparison
    malc-c's Avatar
    malc-c Guest
    Default Time comparison
    Hi guys and gals,
    Can someone offer some suggestions as to how to determine if when setting the on / off times for some lights, the lights should be on at the time of applying the settings.
    I'm using a 1307 RTC and have the following within the code
    If lightsetHR[fn]=timeH and lightsetMN[fn]=timeM then         'compare value of each set time to current time and if matches
       if fn=0 then Lights1 = 1
       if fn=1 then Lights2 = 1                              'turn on those light
       LCDOut $FE, $94+9,"Lights ON"
    If lightoffHR[fn]=timeH and lightoffMN[fn]=timeM then         'compare value of each start time to current time and if matches
       if fn=0 then Lights1 = 0
       if fn=1 then Lights2 = 0                            'turn off the light
       if lights1 = 0 and lights2 = 0 then
       LCDOut $FE, $94+9,"          "
    If the current time is say 12:15 and I set the lights to come on at say 12:20 and then go off at 12:25 it works perfectly, however, if the current time is 12:22 and I try to set the time the lights remain off... presumably until 12:20 the next day. I'm looking for a simple way for the code to work out if the time of setting the lighting period whether or not the lights should be on or not.
    Here is the section where the user sets the on/off times
    Lighting:
    Lighton:
    Lcdout $FE,2
    LCDOUT $FE,$80,"Set On Time For "
        IF H_butt = 0 THEN GOSUB IncHours
        IF M_butt = 0 THEN GOSUB IncMinutes
        lightsetHR[fn]=Hours
        lightsetMN[fn]=Minutes
        if viv >=2 then viv =2
        LCDOUT $FE,$C0,"Light Circuit ",#viv
        lcdout $FE,$94,#lightsetHR[fn] DIG 1,#lightsetHR[fn] DIG 0,":",#lightsetMN[fn] DIG 1,#lightsetMN[fn] DIG 0
    pause 200
    If S_butt = 0 then
    pause 250
    fn = fn +1
    viv = viv+1
    hours = 0
    minutes = 0
    If fn > 1 then
    LCDOUT $FE,1
    viv=1
    fn=0
    goto lightoff
    goto lighton
    lightoff:
    Lcdout $FE,2
    LCDOUT $FE,$80,"Set Off Time For "
        lightoffHR[fn] = Hours
        lightoffMN[fn] = Minutes
        lcdout $FE,$94,#lightoffHR[fn] DIG 1,#lightoffHR[fn] DIG 0,":",#lightoffMN[fn] DIG 1,#lightoffMN[fn] DIG 0
    pause 200
    If !S_butt then
    pause 250
    fn = fn +1
    viv = viv +1
    hours = 0
    minutes = 0
    If fn >=2 then
    LCDOUT $FE,1
    goto mainmenu
    goto lightoff
    What about
    If lightsetHR[fn] >= timeH and lightsetMN[fn] >= timeM then
    Or am I missing something??
    malc-c's Avatar
    malc-c Guest
    Hi Dave,
    That's what I thought.. but it doesn't work because of the checking of the minutes. For example, if the current time is 18:07 and I want to set the on time to 16:45 then I tried
    If lightsetHR[fn] <= timeH and lightsetMN[fn] <= timeM then
    I used < because in this case lightsetHR = 16 and timeH=18. But as lightsetMN = 45 and timeM is 07 the condition is not matched. If used as per your example,
    lightsetHR =16 which isn't > than timeH which is 18 so again the condition would not be matched
    Does that make sense ?
    I still think this rountine is your best bet.
    http://www.picbasic.co.uk/forum/show...8913#post58913
    It takes a Start Time (H:M:S) and End Time, then tells you if it's within that time period or not. Even if the period ends the following day.
    malc-c's Avatar
    malc-c Guest
    Default Thanks
    Hi Darrel,
    I've not had chance to test this yet, but here's how I've adapted the code
    TimeCmpFlags = 0  ; clear flags first
         ; if the Start and Stop times are the same, then Always OFF
      if (lightsetHR[fn]=timeH) AND _
         (lightsetMN[fn]=timeM) then AlwaysOFF
         ; is it past the Start time?
      if (timeH>lightsetHR[fn]) OR _
         (timeH=lightsetHR[fn] AND timeM>lightsetMN[fn])then PastStart=1
         ; is it past the Stop time?
      if (timeH>lightoffHR[fn]) OR _
         (timeH=lightoffHR[fn] AND timeM>lightoffMN[fn])then PastStop=1
         ; does the period end the following day?
      if (lightoffHR[fn]< lightsetHR[fn]) OR _
         (lightoffHR[fn]=lightsetHR[fn] AND lightoffMN[fn] < lightsetMN[fn]) then NextDay=1
    ' endif
      if !NextDay then                               ; same day, use AND
          if PastStart AND !PastStop then ProgON = 1
      else                                           ; next day, use OR
          IF PastStart OR !PastStop then ProgON = 1
    AlwaysOFF:
       Lights1 = 0
    The one thing I'm not too clear on, given that I have two sets of start times and end times for the two lighting circuits, do I need to change the PastStop and Paststart to something like PastStop[fn] and PastStart[fn] to match the same lightoff[nf] etc ?
    malc-c's Avatar
    malc-c Guest
    Default Not able to test -
    The following compiles, but I'm not able to test yet as I'm waiting for a 20 x 4 LCD
         (timeH=lightsetHR[fn] AND timeM>lightsetMN[fn])then PastStart[fn]=1
         (timeH=lightoffHR[fn] AND timeM>lightoffMN[fn])then PastStop[fn]=1
         (lightoffHR[fn]=lightsetHR[fn] AND lightoffMN[fn] < lightsetMN[fn]) then NextDay[fn]=1
    ' endif
          if PastStart[fn] AND !PastStop[fn] then ProgON = 1
          IF PastStart[fn] OR !PastStop[fn] then ProgON = 1
    if fn=0 and ProgON=1 then Lights1 = 1
    if fn=1 and ProgOn=1 then Lights2 = 1                              'turn on those light
    AlwaysOFF:
       Lights1 = 0
    I must be having one of those days...
    I still do not get why something like this will not work.
    If current time is equal to or greater than set start time then on.
    If current time is equal to or greater than set stop time then off.
    Add some vars here and there for two lights...
    Use if/then s. Case while/wend ....
    That looks pretty good Malc.
    And nope, you don't need arrays for the flag bits.
    I don't think you should have anything in the AlwaysOFF section, since the CheckTimes routine just determines if it's inside the program period or not.
    With multiple time periods, whatever is in AlwaysOFF would happen to both periods if only triggered in one of them.
    Any actions can be done after returning from the subroutine.
    Something like this in the main loop maybe.
        fn = 0                              ; select the first Lights
        GOSUB CheckTimes                    ; compare the programed period
        IF ProgON THEN                      ; If in the program period
            IF Lights1 = 0 THEN Lights1 = 1 ; Turn light on (if off)
            IF Lights1 = 1 THEN Lights1 = 0
        fn = 1                              ; select the second Lights
        IF ProgON THEN
            IF Lights2 = 0 THEN Lights2 = 1
            IF Lights2 = 1 THEN Lights2 = 0
    malc-c's Avatar
    malc-c Guest
    Thanks Darrel,
    Hopefully the LCD will arrive soon and I'll be able to test this on the development board
    malc-c's Avatar
    malc-c Guest
        IF ProgON THEN
    Darrel,
    Just ripped the LCD out of the unit so I could test this. So far it seems to work apart from one strange thing, the timings are a minute out... If I set the lighting period to come on at 15:00 it comes on at 15:01, and set to off at 15:05 it goes of 15:06, and I don't get anything displayed on the LCD
    Here's the code that turns the lights on or off:
        IF ProgON THEN
        LCDOut $FE, $94+9,"Light 2 ON"
        if Lights1 = 1 and Lights2 = 1 then
         Endif
    then there's the checking routine:
    CheckTimes:
    AlwaysOFF:
    And finally the section where the time is set:
    Lighting:
    Lighton:
    Lcdout $FE,2
    pause 200
    If S_butt = 0 then
    pause 250
    fn = fn +1
    viv = viv+1
    hours = 0
    minutes = 0
    If fn > 1 then
    LCDOUT $FE,1
    viv=1
    fn=0
    goto lightoff
    goto lighton
    lightoff:
    Lcdout $FE,2
    pause 200
    If !S_butt then
    pause 250
    fn = fn +1
    viv = viv +1
    hours = 0
    minutes = 0
    If fn >=2 then
    LCDOUT $FE,1
    goto mainmenu
    goto lightoff
    The subs for inc hrs or mins:
    IncHours:
        Hours = Hours + 1
        IF Hours = 24 THEN Hours = 0
        pause 250
    IncMinutes:
        Minutes = Minutes + 1
        IF Minutes = 60 THEN Minutes = 0
        pause 250
    Any ideas....??
    Malcolm,
    In the original CheckTimes: routine, the Seconds test had a >=.
    That way it's TRUE when the exact second rolls around.
    Modified for Minutes as the smallest period, I think the Minutes test now needs the >=
    CheckTimes:
         (timeH=lightsetHR[fn] AND timeM >= lightsetMN[fn])then PastStart=1
         (timeH=lightoffHR[fn] AND timeM >= lightoffMN[fn])then PastStop=1
    AlwaysOFF:
    P.S. There's still an Array index in your NextDay flag.
    malc-c's Avatar
    malc-c Guest
    Thanks Darrel,
    I'll give it a try in the morning
    malc-c's Avatar
    malc-c Guest
    Darrel,
    Changed the code and it's still not functioning right.
    If I set the on time as 15:00 and off time as 15:01 the led comes on at 15:01 and stays on... well past the programmed stop time... any ideas ?
    CheckTimes:
    AlwaysOFF:
    malc-c's Avatar
    malc-c Guest
    Default back to the drawing board
    OK something has really got screwed up....
    Here's the menu routine which is used to set the times for the lighting
    Lighting:
    Lighton:
    Lcdout $FE,2
    pause 200
    If S_butt = 0 then
    pause 250
    fn = fn +1
    viv = viv+1
    hours = 0
    minutes = 0
    If fn > 1 then
    LCDOUT $FE,1
    viv=1
    fn=0
    goto lightoff
    goto lighton
    lightoff:
    Lcdout $FE,2
    pause 200
    If !S_butt then
    pause 250
    fn = fn +1
    viv = viv +1
    hours = 0
    minutes = 0
    If fn >=2 then
    LCDOUT $FE,1
    goto mainmenu
    goto lightoff
    so I added the following lines to display the times on the LCD when the program is running
    lcdout $FE,$D4+8,#lightsetHR[fn] DIG 1,#lightsetHR[fn] DIG 0,":",#lightsetMN[fn] DIG 1,#lightsetMN[fn] DIG 0
    lcdout $FE,$D4+14,#lightoffHR[fn] DIG 1,#lightoffHR[fn] DIG 0,":",#lightoffMN[fn] DIG 1,#lightoffMN[fn] DIG 0
    setting the time on to 00:00 and the off time to 00:01 the LCD displays 00:50 and 01:00 respectively. So obviously DT's routine will never match the times set..... I don't know why this has happened because in the original code it matched perfectly....
    malc-c's Avatar
    malc-c Guest
    Default pulling my hair out
    OK as I couldn't figure the above out I started from scratch (again) and tried this:
    For fn = 0 to 1
    If lightsetHR[fn]<timeH or lightsetHR[fn]>timeH and lightsetMN[fn]<timeM or lightsetMN[fn]>timeM and lightoffHR[fn]<timeH OR lightoffHR[fn]>timeH and lightoffMN[fn]<timeM OR lightoffMN[fn]>timeM Then
    next
    fOR fn=0 to 3
    If StartHour[fn]<timeH or StartHour[fn]>timeH and StartMin[fn]<timeM or StartMin[fn]>timeM and StopHour[fn]<timeH OR StopHour[fn]>timeH and StopMin[fn]<timeM OR StopMin[fn]>timeM then          'compare value of each start time to current time and if matches
       LCDOut $FE, $94,"       "
       SetPoints[fn]=normtemp[fn]
    If StartHour[fn]=timeH and StartMin[fn]=timeM then         'compare value of each start time to current time and if matches
       SetPoints[fn]=Droptemp[fn]                              'change the corresponding set point to the drop temperature
       LCDOut $FE, $94,"Night"
    if StopHour[fn]=timeH and StopMin[fn]=timeM then           'compare value of each stop time to current time and if matches
       LCDOut $FE, $94,"       "
       SetPoints[fn]=normtemp[fn]                             'change value back to normal temperature
    Endif
    next fn
    Which works, apart from the original problem, in that at midnight the lights come on and stay on, and the temperatures drop to the default drop temperature. My guess is that as both start times and stop times = 00:00 this is what's causing the issue.
    Anyone able to help come up with a suitable working snippet of code, or tell me why it doesn't work correctly when using DTs code ?
    If everything is working except midnight add a
    if midnight skip
    this
    that
    and the other thing
    Back to the drawing board??
    I don't know Malc.
    In post #14, you found out that the Start and Stop times were not being stored correctly from your button input routines, or they are getting changed somewhere else in the program.
    And I agree, the routines I showed won't work if the preset times are wrong.
    So why did you scrap the CheckTimes routine?
    That isn't changing your start/stop times.
    The latest code you showed would not compile.
    Missing = signs for one (lightsetHR[fn]timeH).
    malc-c's Avatar
    malc-c Guest
    Default thanks
    Guys,
    Thanks for the replies... I should be resting (been unwell recently) and not really spending all day on this ! maybe that's why my brain hurts !! - but I think I've found what is causing the problem...
    On the easyPIC5 board, I noticed that when the time reached 00:00, LEDs on B5 - B7 seemed to strobe, and then stop at 00:01 - this was also observed on the version in the prototype, as the lights flashed at midnight today ! - this seems to put the PIC in some limbo / reset state... ?
    I've managed to get something working that sets the night time drops and turns on the lights if set before the activation time... I'm going to look at either Daves suggestion of a skip midnight routine, or take a fresh look at Darrel's routines and see if I can get that working... would love to know why the PIC is behaving so strange at midnight
    Malcolm,
    I missed this part in your conversion last time.
    It should be testing the Stop time instead of the Current time.
    Here's the updated code.
    CheckTimes:
      if (lightsetHR[fn]=lightoffHR[fn]) AND _
         (lightsetMN[fn]=lightoffMN[fn]) then AlwaysOFF
    AlwaysOFF:
    I've run it in the simulator and it works perfectly.
    malc-c's Avatar
    malc-c Guest
    Thanks guys,
    Darrel, I'll give that a whirl later this morning.... and will report back if I have any issues
    Love the look of that simulator.... nice layout
    Thanks for the support
    Edit - Just tried it by setting the current time to 8:15 and then setting the lighting to come on at 8:09 and off at 8:20 and when run it works fine - have also tried it with the clock set to 23:58 and a lighting period of 23:59 to 00:01 and that works too - Thanks DT
    However.....
    I can't get the display to show when the lights are on...
           IF Lights1 = 1 LCDOut $FE, $94+9,"Light 1 ON"
           IF Lights1 = 0 LCDOut $FE, $94+9,"          "
        IF ProgON THEN
         Endif
    The value for Lights1 or Lights2 changes from 0 to 1 as the corresponding LED on the development board lights up or turns off according to the value, but the IF Lights1 = 1 LCDOut $FE, $94+9,"Light 1 ON" or IF Lights1 = 1 THEN LCDOut $FE, $94+9,"Light 1 ON" seems to be ignored
    Last edited by malc-c; - 28th July 2010 at 09:17. Reason: update - feedback on performance
