Software Reliability
Results 1 to 4 of 4
    Default Software reliability
    I build data loggers that must run unattended for a year plus. There are several aspects to reliability.
    The first is electrical interference. This can be cosmic rays hitting a memory cell, static discharge or nearby lightning coming in via an I/O port, dirty power supply, etc, etc. A precaution against this is to refresh all registers every time through the main loop. Something like.
    code:
    '************************* Initialise ******************************
    Initialise:
    ADCON0 = %00000000 ' ADC turned OFF until needed
    ADCON1 = %00001001 ' Configures 6 analog - balance digital
    CMCON = %00000111 ' Comparators OFF
    CVRCON = %00000000 ' Voltage Rev OFF
    TRISA = %11111111 ' ECG, Accels input
    PORTA = %00000000 '
    TRISB = %10000010 '
    TRISC = %11111111 ' temporary low power
    TRISD = %01000000 ' TFU on D.6 ensure it is set as an input
    PortD = %00000000 ' temporary low power
    TRISE = %00000000
    PortE = %00000000
    OSCCON = %01101111 ' 4 MHz
    endcode
    The second problem is software integrity. Watchdog timer, error trapping, housekeeping checks, etc. Things like looking for A < B or A > B rather than A = B. This only matters with floating point code where what you expect to be an equality might turn out to have a small rounding error that defeats the A = B test.
    The third is to have a second party go through your code looking for logical errors and ways to break it. I know of one software company working in mission critical real time 24/7 process control systems that has as many people in the test team as they have writing the code.
    The fourth is good documentation. Give your code to a colleague and ask if they understand it and could maintain it.
    A fifth is the hardware. Clean all flux off the board, or use an approved no-clean flux, don't stress your capacitors, no parts running hot, quality connectors with plating appropriate to the environment your box must work in. Don't let the box boil in direct sunlight or freeze overnight, etc.
    HTH
    BrianT
    Sep 2005
    Campbell, CA
    I have a couple more:
    Learn all the ins and outs of Read-Modify-Write.
    Be very careful when you use GOTOs and GOSUBs. Don't use one when you mean to use the other.
    Put timeouts in EVERYTHING (hserin, for example), so that the code never waits forever for a state change or user input.
    Actually use the watchdog timer. If you are careful, it can be done.
    Always use 4 layer PCBs (at least) with solid power and GND planes.
    Put several capacitors right next to the chip power pins (I like 2 X 22uF and
    2 X .01uF ceramics).
    Put the crystal close to the PIC.
    Keep the MCLR line short. Use a 4.7K pull up to Vcc.
    Design the hardware such that the circuit (or machine) behaves properly if the PIC is reset with power ON to everything else.
    Charles Linquist
