A2D question
Results 1 to 11 of 11
Thread: A2D question
    Sep 2007
    USA, CA
    Quote Originally Posted by dbodenheimer View Post
    1. Is there a better way to send serial; data than the way I'm doing it? Anyone have a routine that they think works better?
    For certain, Al's method is the preferred way if you are going to send ascii. However, in most situations you can send the actual data instead of the ascii representation of it. Doing so makes it MUCH faster and MUCH smaller code, because you are sending half the data and doing do it without ascii conversions.
    Instead of
    dim TxBuf[4] as byte 'var declaration
    HSEROUT[STR txbuf \ 4] 'sending data
    dim TxBuf as word 'new var declaration
    HSEROUT[TxBuf] 'new sending data
    now your pic will send two bytes, low byte first.
    Side Note: As a personal preference, I like to make the first letter of a variable the first letter of the type. So I would make it wTxBuf, since it is a word. This makes it a lot easier to find type mismatch errors.
    Jul 2010
    Want to thank everyone for their help on this! I'm posting my code as of right now for review and comments.
    Al, Even with the multiple collections, sorting and averaging routines put in, I'm still getting a wider variance of data than I think I should ]. Do I have the code right? If so, could my voltage divider be the wrong value?
    Also, I tried to increase the baudrate to 9600 and it seemed to stop transmitting, does my serial setup code look OK? I am using a 4 mhz crystal.
    Thanks again Everyone!
    ' Read and write hardware USART
    B1      var     byte
    Done    var     byte
    TxBuf   var     byte[3]
    SendBuf var     byte[6]
    STX     var     byte
    ETX     var     byte
    Period  var     byte
    i       var     byte
    tmpval var     byte
    A       var     byte        'for for next loop
    DatAvg  var     word
        CounterA var Word
        DataA var Word
        RawData var Word [16]
    ' Initialize USART
            TRISC = %10111111       ' Set TX (PortC.6) to out, rest in
            ' Set receive register to receiver enabled
            DEFINE HSER_RCSTA 90h
            ' Set transmit register to transmitter enabled
            DEFINE HSER_TXSTA 20h
            ' Set baud rate
            DEFINE HSER_BAUD 2400
            DEFINE HSER_SPBRG 25 'Hser spbrg init
    ' Define ADCIN parameters
    Define	ADC_BITS	10	     ' Set number of bits in result
    Define	ADC_CLOCK	3	     ' Set clock source (3=rc)
    Define	ADC_SAMPLEUS	50	 ' Set sampling time in uS
    adval	var	word		' Create adval to store result
    	TRISA = %11111111	' Set PORTA to all input
    	ADCON1 = %10000010	' Set PORTA analog and right justify result
    	Pause 500		' Wait .5 second
    ' Echo received characters in infinite loop
    STX = 2
    ETX = 3
    Period = 46
    TxBuf[1] = 51
    TxBuf[2] = 54
    TxBuf[3] = 56
    mainloop:
    'Collect 17 AD samples
    for A = 0 to 16
            ADCIN 0, RawData[A] 	' Read channel 0 to array
    Next A
    'Now Lets sort the array
    Gosub SortArray
    'Now Sum the middle 8 values
    for A = 4 to 11                    ' pick out middle 8 readings
     DatAvg = DatAvg + RawData[A]
    NEXT A
    'Now Divide by 8 (by shifting) too get an average
    DatAvg = DatAvg >>3
    'Now put data in TxBuf
            For A=0 to 3
                txbuf[A]= DatAvg DIG (3-A)
            next A
            for A = 0 to 3
                TxBuf[A] = TxBuf[A] + 48
            next  A
    'Send it!
            Gosub SendString         ' Send character to serial output
            pause 500               ' Wait half second
            Goto mainloop           ' Do it forever
            '    Sort Array
    SortArray:
        CounterA=0
    SortLoop:
        If RawData(CounterA+1) < RawData(CounterA) then
            DataA=RawData(CounterA)
            RawData(CounterA)=RawData(CounterA+1)
            RawData(CounterA+1+0)=DataA
            If CounterA > 0 then CounterA=CounterA-2
        CounterA=CounterA+1
        If CounterA < 15 then goto SortLoop
    ' Subroutine to send a character string to USART transmitter
    'First Send STX (02)  then 2 digits, then period (46), then 1 digit, then ETX (03)
    SendString:
        'Build Buffer
        SendBuf[0] = STX
        SendBuf[1] = TxBuf[0]
        SendBuf[2] = TxBuf[1]
        SendBuf[3] = TxBuf[2]
        SendBuf[4] = Period
        SendBuf[5] = TxBuf[3]
        SendBuf[6] = ETX
        'Now Send it
           HSEROUT[STR SendBuf \ 7]
    Return                  ' Go back to caller
    May 2008
    Italy
    B1      var     byte
    Done    var     byte
    TxBuf   var     byte[3]
    SendBuf var     byte[6]
    STX     var     byte
    ETX     var     byte
    Period  var     byte
    i       var     byte
    tmpval var     byte
    DatAvg  var     word
        CounterA var Word
        DataA var Word
    ' Initialize USART
            ' Set baud rate
    Define	ADC_CLOCK	1	     ' Set clock source to 1.6 us Tad @ Fosc/8 (xtal = 4 MHz)
    STX = 2
    ETX = 3
    Period = 46
    TxBuf[1] = 51
    TxBuf[2] = 54
    TxBuf[3] = 56
    mainloop:
    for A = 0 to 15
    Next A
    Gosub SortArray
    DatAvg = 0  ' set DatAvg to zero
    NEXT A
    DatAvg = DatAvg >>3
            For A=0 to 3
            next A
            for A = 0 to 3
            next  A
    'Send it!
            '    Sort Array
    SortArray:
        CounterA=0
    SortLoop:
        CounterA=CounterA+1
    SendString:
        'Build Buffer
        SendBuf[0] = STX
        SendBuf[4] = Period
        SendBuf[6] = ETX
        'Now Send it
    I found three errors in your code (corrected in red) .
    The ADC clock source must be set the closesest possible to 1.6 us Tad.
    Very likely the fact you didn't reset DatAvg to zero was responsible for the non stable reading.
    As far as the baud rate is concerned you can use 4800 as the maximum baud rate with your 4 MHz oscillator.
    Tray and see you should have rock stable reading now, good luck.
    Al.
