Reading Array values into variables
Results 1 to 20 of 20
    Smile
    Have a look to that thread :
    http://www.picbasic.co.uk/forum/showthread.php?t=1217
    here you have the solution to put your 24 bits into something usable ... just divide them as soon to reduce it to less than 16 bits ...
    and that's all !!!
    Question
    And the answers to my questions are ...... ? Can't help if i don't know.
    /Ingvar
    Feb 2005
    Bellevue
    Oh- yes, sorry.
    We are at about 300ft. Should be reading about 100meters or so. The GPS alt data 'wanders' so tenths of meters is a little silly, yes, but that is what is output.
    The full range would want to support over 100,000ft in altitude.
    TOm
    Post
    Ok, you're building a spaceship, 100000 ft is high. I'd love to see this baby fly
    First i think you need to look over your inputdata, methinks it's not properly extracted. I can't see any correlation between your data and 100(ish) metres, unless ofcourse it's already in tenths of ft(000D0Dhex=3341dec 3341*0,3048=1018.34 which would be close to your 100m).
    Are you getting the data from a NMEA sentence($GPGGA) or is it a binary protocol? If it's NMEA you need to know that the data is separated by "," characters, they're not at a fixed position in the string. Atleast not towards the end of the string. This makes it difficult to extract and convert the data.
    When you have your data properly extracted, the conversion would look something like this(pseudocode) ....
        R0.HIGHBYTE = 0        'Prepare system variables for DIV32
        R0.LOWBYTE = alt[2]
        R2.HIGHBYTE = alt[1]
        R2.LOWBYTE = alt[0]
        AltMetres = DIV32 10
        Alt10Ft = AltMetres ** 21501  '21501/65536=0.32808
        SEROUT blah..,blah..,["Altitude :",dec Alt10Ft, "0 ft",13,10]
    ..... you could increase the resolution when "alt[2]" = 0 ......
        AltMetres.HIGHBYTE = alt[1]
        AltMetres.LOWBYTE = alt[0]
        AltFt = AltMetres ** 21501  '21501/65536=0.32808
        SEROUT blah..,blah..,["Altitude :",dec AltFt, " ft",13,10]
    .... you could ofcourse combine them .....
    IF alt[2] = 0 THEN
        R0.LOWBYTE = alt[2]
        R2.LOWBYTE = alt[0]
    /Ingvar
    Feb 2005
    Bellevue
    Thanks much!!
    Apparently it is important for the system to report over 100k...
    The data is binary, not NMEA. The 3 bytes are the altitude, and it is in tenths of a meter. (binary value in tenths of meters)
    My challenge is that I have THREE bytes.. each with values that together equal the value I need.
    Value is sent in these 3 bytes as LSB first, then NMSB, then MSB.
    Does that help?
    TG
    Post
    The code i posted handles your THREE bytes, alt[0] to alt[2], when needed. Alt[0] = LSB, alt[2] = MSB. At high resolution(1ft) it will go to 21500ft, low res(10ft) will go to 215000ft.
  1. Simple Array Demo
    By Archangel in forum Code Examples
    Last Post: - 15th February 2010, 05:46
  2. Array values changing
    By MyBuddy in forum mel PIC BASIC Pro
    Last Post: - 30th October 2009, 00:13
  3. Funny PULSIN values: what is going on???
    Last Post: - 30th April 2008, 09:02
  4. Seeting array variables in For-Next loop
    By bcd in forum mel PIC BASIC Pro
    Last Post: - 28th October 2007, 08:01
  5. Putting values into an array
    By Vince in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2003, 08:22
