Timer interrupt 16F1827
Results 1 to 14 of 14
    Interrupts on these are easier than older 16F parts with the auto restore feature, but you need to make sure you're flipping the right bits to set everything up properly....
    Try this.
      __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
      __config _CONFIG2, _PLLEN_OFF & _LVP_OFF & _STVREN_OFF
      DEFINE OSC 8
      DEFINE INTHAND Tmr1Int
      OSCCON= %01110000
      GOTO Init  ' jump over interrupt routine
    Tmr1Int
      ; retfie auto-restores w, status, bsr, fsr and pclath
      bcf   T1CON,TMR1ON ; stop timer 1
      bcf   PIR1,TMR1IF  ; clear over flow flag
      movlw 0xBF         ; load timer for 16,535 * 8 prescaler interrupt on 16 bit timer
      movwf TMR1H        ; load high byte
      movlw 0x69
      movwf TMR1L        ; load low byte
      bsf   T1CON,TMR1ON ; re-enable timer 1
      movlw 0x01
      xorwf PORTB,f      ; toggle RB0
      retfie             ; Return from interrupt
    Init:
      PORTB = 0
      TRISB = 0
      CM1CON0.7=0
      CM2CON0.7=0
      ANSELA = 0           ' all digital. A/D disabled
      ANSELB = 0
      PIR1 = 0             ' clear TMR1 int flag
      PIE1 = %00000001     ' TMR1 int enabled
      INTCON = %11000000   ' global & peripheral ints enabled
      T1CON = %00110001    ' TMR1 1:8 prescale, timer1 on
      HIGH 1
      PAUSE 1000
      LOW 1
      PAUSE 1000
      GOTO Main
    Then check out DT_INTS-14 v1.00
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Question
    Hello Bruce, Darrel,
    Thanks for your help! I read in the data sheet that the context saving is done automatically. So unlike
    the 16F877A where a context saving routine example is featured, the 16F1827 does not have any
    such routine listed in the data sheet. Just a few lines that mention automatic context saving.
    So, using PBP do I need to use context saving using the ASM ISR ?
    Nick
    Nope. If you're using the 16F1827 you don't need to save w, status, bsr, fsr or pclath. It does this for you automagically...
    -Bruce
    tech at rentron.com
    OOPs, there's no FAST option on RETFIE with those chips.
    It always restores them.
    My Bad!
