Using LOOKUP
Results 1 to 2 of 2
Thread: Using LOOKUP
    Jul 2010
    Default Using LOOKUP
    My project is to read in a string of 19 characters from a GPS's serial port using HSERIN. Then using
    LOOKUP to parse the 10th and 11th characters in the TIME string and act upon the results.
    I have the HSERIN working at 9600baud and can display the received string on the LCD. But, I
    can't seem to get the LOOKUP syntax correct. Even the examples in the MicroCode Studio and PBP
    manual do not compile correctly and it is very frustrating.
    Here is my program:
    DEFINE HSER_TXSTA 24H
    DEFINE HSER_RCSTA 90H
    DEFINE HSER_BAUD 9600
    DEFINE HSER_SPBRG 25
    TIME VAR BYTE(19)
    PAUSE 2000 'FOR LCD
    LCDOUT $FE,$1 'CLEAR LCD
    PAUSE 200
    LCDOUT "TEST HSERIN" 'DISPLAY "TEST HSERIN" ON LCD LINE 1
    PAUSE 1000
    GOSUB CURHOME2 'MOVE LCD CURSOR TO LINE 2
    MOREHSER:
    HSERIN [WAIT("C708")] ' WAIT FOR "C708"
    HSERIN [STR TIME\19]
    LOOKUP 10,[TIME],B1 ' FIND 10TH CHARACTER IN THE 'TIME' STRING
    LCDOUT B1 ' DISPLAY 10TH CHARACTER ON LCD
    LCDOUT STR TIME\19
    GOSUB CURHOME2 'LINE 2
    GOTO MOREHSER
    CURHOME2:
    LCDOUT $FE, $C0
    Jul 2010
    Quote Originally Posted by N6VMO_ View Post
    Here is my program:
    TIME VAR BYTE(19)
    PAUSE 2000 'FOR LCD
    PAUSE 200
    PAUSE 1000
    MOREHSER:
    LCDOUT STR TIME\19
    GOTO MOREHSER
    CURHOME2:
    LCDOUT $FE, $C0
    I just answered my own question by...READING THE BOOK!
    LOOKUP can't be used to parse arrays with a variable. ARRAYREAD works better.
