Loops in assembly
Results 1 to 3 of 3
    Jun 2007
    Mansfield, UK
    Default Loops in assembly
    Hi, i was wondering if its possible to create a loop in assembly. I already know how to use GOTO to create a runtime loop but im looking to create a loop that is executed while the code is compiling and results in multiple lines of assembly being output.
    Example:
    for x=0 to 5
        MOVFF var+x, var2+x
    next
    And the actual assembly code i would expect is:
    MOVFF var+0, var2+0
    MOVFF var+1, var2+1
    MOVFF var+2, var2+2
    MOVFF var+3, var2+3
    MOVFF var+4, var2+4
    MOVFF var+5, var2+5
    Bombay, India
    Have you seen this thread? Might have the answer to your question.
    http://www.picbasic.co.uk/forum/show...t=delay+cycles
    Jun 2007
    Mansfield, UK
    I read through that thread and found while/endw. That does the job perfectly. Thanks
