Optimizing IR range
Results 1 to 13 of 13
    Feb 2005
    Dave, thanks for the link. I had stumbled upon that site, and used the information there to be the basis for my own design. The guy uses an Atmel, which was another incentive for designing my own around a pic. But of course, the detail timings table he's given helped a lot.
    Anand, can you post the part of the code where you encode the trigger for the Canon, I would like to add it to the timelapse remote I'm building. Thanks!!
    Pablo
    Hi Pablo,
    Thats a nice idea; a sort of semi-universal (Pentax/Nikon/Canon) time lapse trigger.
    The Canon trigger is perhaps the simplest to encode. I'm pasting my code, of which you could delete the delayed-trigger related lines. These a re used on the remote to trigger the shutter 2 seconds after the signal is sent.
        NAP 0                           ; Reduce consumption in standby from 900uA to 116uA (cost of 18ms delay)
        IF SW1 = 0 THEN GOSUB NO_DLAY
        IF SW2 = 0 THEN GOSUB DLAY
        GOTO MAIN
        NO_DLAY:
        HIGH LED
        CYCLES = 16                     ; COUNTER HAS TO BE RESET TO DEFAULT!
        Gosub Pulse
        PAUSEUS 7300
        GOSUB PULSE
        PAUSE 50                       ; Prevent inadvertant double triggerPAUSE 500
        LOW LED
        PAUSE 500
        DLAY:
        HIGH LED
        Gosub Pulse
        PAUSEUS 5300
        GOSUB PULSE
        LOW LED
        PAUSE 500
        Pulse:          ' THIS GENERATES "Cycles" number of 40kHz pulses (if total delays are 25)
                        ' So, for Canon, 16 Cycles of 31 uS (32.6 KHz) => Demodulated pulse of 0.496 mS
       bsf IRTX,PIN     ; 1uS, LED=on
       goto $+1         ; + 2uS = 3uS
       goto $+1         ; + 2uS = 5uS
       goto $+1         ; + 2uS = 7uS
       goto $+1         ; + 2uS = 9uS
       goto $+1         ; + 2uS = 11uS
       goto $+1         ; + 2uS = 13uS
       goto $+1         ; + 2uS = 15uS
       goto $+1         ; + 2uS = 17uS
       bcf IRTX,PIN     ; 1uS, LED=off
       decfsz _Cycles,f ; + 1uS = 12S           ; This decrements in a loop till 0; then goes to next line
       goto _Pulse      ; + 2uS = 14uS
       return           ; Return to caller
    Would be nice to have your feedback on the finished product.
    BTW, in your schematic you have a pullup on the switch input; cant you just enable the internal pullup?
    Anand
    Last edited by ScaleRobotics; - 12th January 2011 at 09:20. Reason: added code tags
