Optimizing IR range
Results 1 to 13 of 13
    Dec 2005
    Anand,
    I've used 20-25% duty cycle. In the application I mentioned, my card was powered by the PDA. I've never found a capacitor was necessary but most of my transmitter apps were RF which takes less power. I prefer BR type batteries as they maintain their charge better than most other types. Panasonic has some discharge curves comparing BR to CR. A Google search on "Panasonic BR" will likely find them.
    I understood that the receiver was in the camera. I should have been more clear that I was generalizing. Still, it will help if you can find out (from the manufacturer?) what wavelength IR the receiver is designed for. Since it is intended for outdoor use, it is likely that they've used a narrow bandwidth receiver.
    This might be helpful - although I think its points have been covered here by me and Bruce.
    http://davehouston.org/ir-rf_fundamentals.htm
    Dec 2005
    Anand,
    I found a page from someone who reverse engineered a Canon remote.
    Dave, thanks for the link. I had stumbled upon that site, and used the information there to be the basis for my own design. The guy uses an Atmel, which was another incentive for designing my own around a pic. But of course, the detail timings table he's given helped a lot.
    In the page you pointed out, the writer uses a switch to control the Vdd itself; when I tried that my signal burst was not very clean. So my version has Vdd always connected to the battery and 2 separate momentary contact switches for the 2 functions.
    My version is now working very well, functionally, so am now in the process of reducing the current consumption. Shutting off the watchdog, configuring the I/Os and using a nap in the loop has now reduced it to around 40 uA; I guess that means a single CR2032 should last for well over half a year of average use!
    Again, thank you so much for the inputs.
    Anand
    Sorry, my mistake, that has to be kept on.
    Okay folks, with all the help from you guys, I have this working pretty well now.
    For the benefit of others designing an IR transmitter powered from a typical coin battery, I would like to share this point. Once you have the basic thing working, probably the one single factor to increase the range significantly would be a large capacitor (100uf plus) across the battery.
    I dont know how this would impact the battery life though.
    Anand
    Feb 2005
    Anand, can you post the part of the code where you encode the trigger for the Canon, I would like to add it to the timelapse remote I'm building. Thanks!!
    Pablo
    Hi Pablo,
    Thats a nice idea; a sort of semi-universal (Pentax/Nikon/Canon) time lapse trigger.
    The Canon trigger is perhaps the simplest to encode. I'm pasting my code, of which you could delete the delayed-trigger related lines. These a re used on the remote to trigger the shutter 2 seconds after the signal is sent.
        NAP 0                           ; Reduce consumption in standby from 900uA to 116uA (cost of 18ms delay)
        IF SW1 = 0 THEN GOSUB NO_DLAY
        IF SW2 = 0 THEN GOSUB DLAY
        GOTO MAIN
        NO_DLAY:
        HIGH LED
        CYCLES = 16                     ; COUNTER HAS TO BE RESET TO DEFAULT!
        Gosub Pulse
        PAUSEUS 7300
        GOSUB PULSE
        PAUSE 50                       ; Prevent inadvertant double triggerPAUSE 500
        LOW LED
        PAUSE 500
        DLAY:
        HIGH LED
        Gosub Pulse
        PAUSEUS 5300
        GOSUB PULSE
        LOW LED
        PAUSE 500
        Pulse:          ' THIS GENERATES "Cycles" number of 40kHz pulses (if total delays are 25)
                        ' So, for Canon, 16 Cycles of 31 uS (32.6 KHz) => Demodulated pulse of 0.496 mS
       bsf IRTX,PIN     ; 1uS, LED=on
       goto $+1         ; + 2uS = 3uS
       goto $+1         ; + 2uS = 5uS
       goto $+1         ; + 2uS = 7uS
       goto $+1         ; + 2uS = 9uS
       goto $+1         ; + 2uS = 11uS
       goto $+1         ; + 2uS = 13uS
       goto $+1         ; + 2uS = 15uS
       goto $+1         ; + 2uS = 17uS
       bcf IRTX,PIN     ; 1uS, LED=off
       decfsz _Cycles,f ; + 1uS = 12S           ; This decrements in a loop till 0; then goes to next line
       goto _Pulse      ; + 2uS = 14uS
       return           ; Return to caller
    Would be nice to have your feedback on the finished product.
    BTW, in your schematic you have a pullup on the switch input; cant you just enable the internal pullup?
    Anand
    Last edited by ScaleRobotics; - 12th January 2011 at 09:20. Reason: added code tags
