16F690 HWPM - outputting PWM on a different HPWM port/pin - brainache!
Results 1 to 6 of 6
    Mar 2009
    Thanks guys ...hey ho, looks like I'm stuck with Pin 5 then - sheesh, hardware schmardware (I do need 20Khz - but that a useful 'solution' to tuck away though)
    Default HPWM limited to 255, how do you get 350?
    You show a command HPWM 1,350,20000 which implies you have 9 or 10 bit HPWM.
    Is the 350 a typo or have you got something special in your HPWM command?
    Cheers
    Brian
    Mar 2009
    Quote Originally Posted by BrianT View Post
    Cheers
    Brian
    Hi Brian,
    Good spot - it was a typo - I didn't cut/paste from my program buy I just hastily typed it in to the post. (as it goes, I use 10 bit PWM, which might account for me getting carried away with the numbers for the duty cycle!)
