One of the problems with using hardware is you can not change things around.
For a single PWM output you are stuck with P1A being modulated.
Maybe you could set it up as a half or full bridge and not use P1a but I do not know what problems that will cause.
I will bet a jumper on the PCB will be easier to deal with![]()
