Hey Robert,
Can you give some example code for how the square wave method would work?
Say you have something like the sliding door app.
Green = full open
Red = closed
OFF = inbetween
Yellow = moving
Mackrackit,
I'm going to order this part and test it to see if it works. The square wave is just a simple 50% duty cycle wave. By using the circuit provided by Scalerobotics, then if the square wave is low the red lights up and if the square wave is high then the green lights up.
A rapid changing of colors red -> green -> red -> green -> .... would appear to be yellow. It is just an optical illusion. Remember that I talking about a red-green LED with both colors in the same LED casing. Still, I would need to test it to see if it works.
Looking forward to see your results, it would be very useful.
Mackrackit,
I tested this idea with a red-green 10 LED bargraph and yes it works. The setup is different from what we have been discussing in this thread, but the idea of getting a new color (yellow) is the same.
First, I applied a square wave to the circuit with a period of 1.2 seconds and you can see how the color changes between red and green. Next, I applied a square wave with a period of 2 milliseconds per cycle (50% duty cycle) and all you see is a yellow color. Also, If you change the percentage of the duty cycle you get different tones of yellow. This would be very useful for a project like the sliding doors.
COOOL!!!!!
I can think of several places where that will come in handy.
Looks like it would make a good article for the wiki. Add a bit of code and schematic for basic use....
Tried this on my Breadboard, works a treat.
Hmmm....have to work out how to ad a JPG to this...
BRB
Ah, there it is, I hope. I know it means 2 extra LEDs, but that's gotta be cheaper than changing the PIC or messing around with the power supply.
With the pin as an input, the 5 volt rail is not enough to turn on any of the leds, but setting the pin Hi or Lo the voltage is enough to turn on 2 of them. Also no current drawn during the Input stage.
Peter Moritz.
Up the bush, Western Plains,
New South Wales,
Australia.
Ok.
I attached the schematics to this post. The code is pretty simple. It uses only one pin in the PIC to create four states in the red-green LED. You can get Red, Green, Yellow, or the Off state in the LED using only one pin. Of course, for getting the last state (Off) all the credit goes to mackrackit. He figured that one out.
Code:START: HIGH PORTB.0 'Turn on red light PAUSE 2000 LOW PORTB.0 'Turn on green light PAUSE 2000 FOR I = 1 TO 2000 'Obtain a yellow light TOGGLE PORTB.0 PAUSE 1 NEXT I TRISB.0 = 1 'Turn off LED PAUSE 2000 GOTO START![]()
