2 LEDs and one pin left
Results 1 to 40 of 54
    Jan 2006
    Istanbul
    Talking
    RED and BLUE = ON
    The only way I can think of is to connect them in parallel. (if serial, 3.3V will not go through)
    Miami, Florida USA
    Quote Originally Posted by sayzer View Post
    RED and BLUE = ON
    No, that's not what I meant.
    If you apply a square wave to this red-green LED, the colors will change so quickly that it will look like it is yellow. I haven't tried it yet, but I'm pretty sure it will look yellow to your eyes.
    Hey Robert,
    Can you give some example code for how the square wave method would work?
    Say you have something like the sliding door app.
    Green = full open
    Red = closed
    OFF = inbetween
    Yellow = moving
    Miami, Florida USA
    Hey Robert,
    Green = full open
    Red = closed
    OFF = inbetween
    Yellow = moving
    Mackrackit,
    I'm going to order this part and test it to see if it works. The square wave is just a simple 50% duty cycle wave. By using the circuit provided by Scalerobotics, then if the square wave is low the red lights up and if the square wave is high then the green lights up.
    A rapid changing of colors red -> green -> red -> green -> .... would appear to be yellow. It is just an optical illusion. Remember that I talking about a red-green LED with both colors in the same LED casing. Still, I would need to test it to see if it works.
    Looking forward to see your results, it would be very useful.
    Miami, Florida USA
    Mackrackit,
    I tested this idea with a red-green 10 LED bargraph and yes it works. The setup is different from what we have been discussing in this thread, but the idea of getting a new color (yellow) is the same.
    First, I applied a square wave to the circuit with a period of 1.2 seconds and you can see how the color changes between red and green. Next, I applied a square wave with a period of 2 milliseconds per cycle (50% duty cycle) and all you see is a yellow color. Also, If you change the percentage of the duty cycle you get different tones of yellow. This would be very useful for a project like the sliding doors.
    COOOL!!!!!
    I can think of several places where that will come in handy.
    Looks like it would make a good article for the wiki. Add a bit of code and schematic for basic use....
