2 LEDs and one pin left
Page 1 of 2 12 LastLast
Results 1 to 40 of 54
    Mar 2006
    China
    Default 2 LEDs and one pin left
    Hi All,
    I have one red LED and one GREEN led and a few resistors and only ONE pin left on my MCU. It would be nice if there is a way to turn on green or red or have them both off.
    Since the pin has 3 states it might be possible but today my brain just can't see how. Current goes in .. one LED is on... Current goes out.. the other one is on. But it is possible to have them both turned off without haveing any leaking current when the pin is in tri-state?
    I never plan to have them on at the same time... just both off or one or the other on.
    thanks!
    Output HIGH
    Output LOW
    Input
    Maybe
    Mar 2006
    China
    Default doh
    and what makes the current not flow thru any of them when the pin is in INPUT?
    From a data sheet.
    Setting a
    TRISA bit (= 1) will make the corresponding PORTA pin
    an input (i.e., put the corresponding output driver in a
    Hi-Impedance mode)
    http://en.wikipedia.org/wiki/High_impedance
    Jan 2006
    Istanbul
    0,1
    0,0
    LEDs on these states won't be possible by one pin.
    Instead, use 4017 with one pin.
    I have an example here:
    http://www.picbasic.co.uk/forum/showthread.php?t=6548&
    Can't you?
    My turn to say DOH!!!
    No matter how you connect two LEDs without extra hardware there will be feed back between the two.
    A couple transistors or sayzer's solution are in order for this one.
    How many DOHs are allowed in one day???
    DUH code
    BLINK:
         HIGH PORTG.4
         PAUSE 250
         LOW PORTG.4
         PAUSE 250
         TRISG.4 = 1
         PAUSE 2000
         GOTO BLINK
    And
    Mar 2006
    China
    Default well
    Then we have the problem with the idle current.... 2 resistors in serie between Vdd and Vss is going to drain the battery. I like the idea! but the idle current will be almost half of what the LED uses when it is turned on (sssuming 5V Vdd and 2V voltagedrop over the led)
    I dont have my lab stuff here.. does anyone think the idle current might be lower in the circuit i have attached.. or will smoke come out :-)
    Sure there are many ways to solve the problem by adding more things but I am still hoping this will work...
    or it will be DOOH and an other design.
    Thank you!
    Miami, Florida USA
    Jumper,
    You can use "one LED" only like the one in the link below. This is pretty much two LEDs put together. It is a red-green 3mm LED.
    http://futurlec.com/LED/LED3RG.shtml
    Quote Originally Posted by sayzer View Post
    1,0
    0,1
    0,0
    However, the bad news is that Sayzer is right. You can't get three states "0,0", "0,1", and "1,0" with only one MCU pin.
    Really? Because I am using Dave's code on a 18F26J50 (3.3 volt) with no resistors, and it works like a charm. Red, Blue, off
    BLINK:
         HIGH PORTA.0
         PAUSE 250
         LOW PORTA.0
         PAUSE 250
         TRISA.0 = 1
         PAUSE 2000
         GOTO BLINK
    Miami, Florida USA
    BLINK:
         HIGH PORTA.0
         PAUSE 2500
         LOW PORTA.0
         PAUSE 2500
         TRISA.0 = 1
         PAUSE 20000
         GOTO BLINK
    DOH,
    The trick is in the TRISA.0 = 1 to get both off (the 0,0 state). Nice!
    I think this page explains what Walter is doing pretty well ...
    http://www.batsocks.co.uk/readme/p_tut_led16.htm
    Simplest coding would be to generate a square wave signal on the pin, and then set the TRIS based on state of each LED. TRIS would have to be set every time you change the state of the pin in the square wave generating code. That way the LEDs will always be the same brightness. Of course the square wave signal would have to be interrupt driven off of a timer in order to have both LEDs on at the same time.
    Tim Barr
    Square wave sounds more difficult than Dave's code, and any square wave will light up both LED's on a two led with 1 output scenario. And Jumper just wants one, or none to light at a time.
    Jan 2006
    Istanbul
    Attachment 4604
    BLINK:
         HIGH PORTA.0
         PAUSE 250
         LOW PORTA.0
         PAUSE 250
         TRISA.0 = 1
         PAUSE 2000
         GOTO BLINK
    Nice trick indeed.
    How about RED and BLUE = ON ?
    (without ".....Of course the square wave signal would have to be interrupt driven off of a timer in order to have both LEDs on at the same time. " )
    Nice trick indeed.
    Nice one Sayzer! I guess that is four states for one pin!
    Miami, Florida USA
    Yes, the four states can be obtaind with only one pin. Very nice!
    Now, if you use the red-green LED that I mentioned above a cool project can be made.
    Since red + green = yellow, then with only one pin in the MCU we can obtain four different states in the LED: off, red, green, or yellow. Also, by varying the percentage duty cycle of the square wave different shades of yellow can be obtained. I haven't tried this yet but it might be a cool project.
    Jan 2006
    Istanbul
    Talking
    RED and BLUE = ON
    The only way I can think of is to connect them in parallel. (if serial, 3.3V will not go through)
    Miami, Florida USA
    RED and BLUE = ON
    No, that's not what I meant.
    If you apply a square wave to this red-green LED, the colors will change so quickly that it will look like it is yellow. I haven't tried it yet, but I'm pretty sure it will look yellow to your eyes.
    Hey Robert,
    Can you give some example code for how the square wave method would work?
    Say you have something like the sliding door app.
    Green = full open
    Red = closed
    OFF = inbetween
    Yellow = moving
    Miami, Florida USA
    Hey Robert,
    Green = full open
    Red = closed
    OFF = inbetween
    Yellow = moving
    Mackrackit,
    I'm going to order this part and test it to see if it works. The square wave is just a simple 50% duty cycle wave. By using the circuit provided by Scalerobotics, then if the square wave is low the red lights up and if the square wave is high then the green lights up.
    A rapid changing of colors red -> green -> red -> green -> .... would appear to be yellow. It is just an optical illusion. Remember that I talking about a red-green LED with both colors in the same LED casing. Still, I would need to test it to see if it works.
    Looking forward to see your results, it would be very useful.
    Miami, Florida USA
    Mackrackit,
    I tested this idea with a red-green 10 LED bargraph and yes it works. The setup is different from what we have been discussing in this thread, but the idea of getting a new color (yellow) is the same.
    First, I applied a square wave to the circuit with a period of 1.2 seconds and you can see how the color changes between red and green. Next, I applied a square wave with a period of 2 milliseconds per cycle (50% duty cycle) and all you see is a yellow color. Also, If you change the percentage of the duty cycle you get different tones of yellow. This would be very useful for a project like the sliding doors.
    COOOL!!!!!
    I can think of several places where that will come in handy.
    Looks like it would make a good article for the wiki. Add a bit of code and schematic for basic use....
    Jun 2005
    Up the bush, Western Plains, NSW Au
    Default 2 leds 1 pin
    Tried this on my Breadboard, works a treat.
    Hmmm....have to work out how to ad a JPG to this...
    BRB
    Ah, there it is, I hope. I know it means 2 extra LEDs, but that's gotta be cheaper than changing the PIC or messing around with the power supply.
    With the pin as an input, the 5 volt rail is not enough to turn on any of the leds, but setting the pin Hi or Lo the voltage is enough to turn on 2 of them. Also no current drawn during the Input stage.
    Peter Moritz.
    New South Wales,
    Australia.
    Aug 2005
    Michigan, USA
    Jumper,
    What does the rest of your circuit look like?
    Regards, Mike
    Miami, Florida USA
    Ok.
    I attached the schematics to this post. The code is pretty simple. It uses only one pin in the PIC to create four states in the red-green LED. You can get Red, Green, Yellow, or the Off state in the LED using only one pin. Of course, for getting the last state (Off) all the credit goes to mackrackit. He figured that one out .
    START:
    HIGH PORTB.0                 'Turn on red light
    PAUSE 2000
    LOW PORTB.0                  'Turn on green light
    PAUSE 2000
    FOR I = 1 TO 2000            'Obtain a yellow light
       TOGGLE PORTB.0
       PAUSE 1
    NEXT I
    TRISB.0 = 1                  'Turn off LED
    PAUSE 2000
    GOTO START
    I vote for Muddy0409's except, I would put a resistor in series with the processor output lead to limit the output current. This is exactly what I would have proposed except I would have used a couple of zeners instead of the extra led in each leg... If you have an extra inverter available you could modulate one side of a bidirectional led (red/green) and connect the other side thru a resistor to the processor output pin and then place it either high or low and finally to an input state to shut it off.....
    Aug 2010
    Maryland, USA
    Referring to the attachment 2 posts above,
    Am I just missing something? by my calcs, assuming 2V drop for the LED's the current would be 3/10000 = .3mA.
    Will this be enough to light the LED? By my calcs, I would think 150-200 ohms would be more suitable. Any help to clear this up for me?
    -Bert
    I don't think the attachment 2 posts above will do any good with 10k resistors.
    I had actually started making a flash demo for this when it first started, but with so many options it got too complicated.
    I really think the correct theory is in the link from post #13 though. The link is also in the flash below ... under the title. (batsocks.co.uk/ ....)
    I only made it through simulating +5V. Things are clickable in the image below ... try it.
    At +5V the resistor is 100 ohms (with 2 diodes).
    But if your situation is different, perhaps I can add to it. ...
    <OBJECT CLASSID="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" CODEBASE="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,40,0" WIDTH="723" HEIGHT="800" ><PARAM NAME="MOVIE" VALUE="http://www.pbpgroup.com/files/2LED/2LEDS_1PIN.swf"><PARAM NAME="PLAY" VALUE="true"><PARAM NAME="LOOP" VALUE="truSe"><PARAM NAME="QUALITY" VALUE="high"><EMBED SRC="http://www.pbpgroup.com/files/2LED/2LEDS_1PIN.swf" WIDTH="723" HEIGHT="800" PLAY="true" LOOP="true" WMODE="opaque" QUALITY="high" TYPE="application/x-shockwave-flash" PLUGINSPAGE="http://www.macromedia.com/go/getflashplayer"></EMBED></OBJECT>
    Oh, it says I attached the .dsn file ... I didn't, cause it wasn't done.
    But if you have Proteus, I will make it work for all conditions ...
    Aug 2010
    Maryland, USA
    Default Wow!!
    Thanks Darrel. That is an awesome gadget. Is there any way to get you to replace d2 and d3 with variable resistors (or fixed if need be) and bypass the 200 ohm on the pin? This way it will be closer to the other circuit. I would love to test it (and yes, I am trying to use your sim instead of my breadboard) I think a more approiate value would be 0-1000 ohms. If not, its all good.
    -Bert
    Well, the problem with that ... is that the variable resistors would only control current.
    But the correct operation of the LED's depends on the voltage.
    If the total forward voltage of the LED's is less than VDD, both LED's will be ON no matter what the resistor values are. The only difference will be their brightness.
    Given a specific VDD voltage, LED color (V forward) and foward current, the correct configuration can be found.
    And to add 2 variable resistors to the flash demo, would increase the frames from ~50 to more than 500,000. I'm affraid that will take a few years to create, and you probably won't wait the 2 weeks to download it.
    I suppose it could be done more efficiently.
    But again, if you have Proteus, it's a "Piece of Cake".
    Aug 2010
    Maryland, USA
    thanks darrel, once again, it seems a case of I know not what I ask. Don't worry about the demo then. As for the actual circuit, I will have to mull over why the 2 resistors in series with the led's doesn't create a voltage divider.
    I would just LOVE to have proteus. I tried looking it up 1 time, seems it was in the 4 digits, just a little much for me
    -Bert
    Actually, I'd rather know your conditions and do the math.
    What is it you need to do with your LED's?
    VDD, LED Forward Voltage / Forward Current?
    See if the theory works?
    ... As for the actual circuit, I will have to mull over why the 2 resistors in series with the led's doesn't create a voltage divider.
    Because the voltages across the resistors are changed by the voltage drops that are controlled by the LED's.
    I would just LOVE to haave proteus. I tried looking it up 1 time, seems it was in the triple digits, just a little much for me
    That's what I thought too at first.
    But they have a $250 "starter version" that gives you a 12F, 16F and an 18F.
    Of course it comes with all the other logic chips, analog stuff and test instruments.
    Even if it's not the exact chip you target, the "Family" is usually close enough to know your program has a chance.
    Beware:
    Once you get used to it ...
    You probably will spend $1000 for the full PIC version.
    Aug 2010
    Maryland, USA
    The LED's will be board level indicators, showing drive enables, disabled, or in a fault
    red is 2Vf @ 10-20ma green is 2.2Vf @ 10-20ma
    Vcc 5V
    Now I could use 3.3Vsupply for the LED's But was trying not to add that.
    $250 I could deal with, its the beware I am listing too!
    -Bert
    Miami, Florida USA
    Yes, after I posted that attachment I realized it was wrong. The correct value for the resistors should be between 100 and 330 ohms depending on the brightness that you want. I'm sorry for the confusion.
    Anonymous
    Jan 2006
    Istanbul
    I am using this technique with 6K8 resistors on 3.1V/1500mcd LEDs.
    Vdd is 5.0V.
    I am using one pin to simulate TX and RX transmission with two LEDs inside Hserin and Hserout routines.
    The light level is more than good enough for the purpose.
    I am %100 satisfied with the result.
    __________________________
    Aug 2010
    Maryland, USA
    Default did some tests today
    here was the setup:
    5Vdc->R1->2.2vF LED->1.9vF LED->R2->GND
    R1=R2
    first tried 240 ohm, Great brightness for each, pretty bright with no input
    next up 1K, simular results just dimmer
    last 4.7K, No real output for off, bright enough to see with input, but not really enough for an indicator in this app.
    So my opinion is everybody in this thread is correct in some respect.
    I feel like the best solution is to use a 3.3V supply. that way there is NO way to light both, and each can be nice and bright. Now, question for the masses: can we use a voltage divider to get this 3.3 from 5? This seems to me to be the least costly answer. Just 2 resistors and off we go. Hang a resistor inline with the signal pin and life is good. My perticular application will have 6 sets of LED's so if 1 from each set were on at once, could be 120mA.droping 1.7 volts, that would be 1.7*.12=.2W. That part doesn't seem too bad. Of course they could be strobed so there would never be more than 1 on at a time, then it would be 1.7*.02=.034W
    -Bert
    And run the whole thing? Nope.
    Using 5 volts with 470 resistors the thing I posted works fine.
