I2C eeprom read write
Results 1 to 7 of 7
Threaded View
  1. #6
    Further testing reveals the codes are being stored correctly in the eeprom and can be read back and displayed with this code.
    This writes the codes correctly to the eeprom
    VarA = 0
    I2CWRITE Scdeeprom,Sckeeprom,AT24C512B,VarA,[STR I2C1\8,STR I2C2\8]	'Load data into I2c eeprom
    This check works even after powering on/off so the data is in the eeprom ok and can be read back.
    For VarA = 0 to 15               'Load I2C1 data from eeprom
    I2CREAD Scdeeprom,Sckeeprom,AT24C512B,VarA,[VarB1]	'Read data from I2c eeprom
    DEBUG HEX2 VarB1
    Next VarA
    However trying to put the codes back into the array variables with this code.
    VarA = 0
    I2CREAD Scdeeprom,Sckeeprom,AT24C512B,VarA,[STR I2C1\8,STR I2C2\8]	'Read data from I2c eeprom
    Appears to work correctly but the first byte of I2C1 array is always corrupted? Could someone try and replicate the fault please.
