I double checked everything with my Flukemy rows are on Portb. 1,Portb.2,and Portb.3 my columns are on Portb.4 - 7. I had everything setup like the orginal example on Bruce's site and it worked great but I wanted to use Portb.0 for my interrupt, thats when I moved everthing over one bit. It works, about eight functions work correctly but now I can send on two different buttons things like two decimal 7's or 5's , etc. instead of decimal 1-12. When I break the code down on paper to calculate what the output would be it concurs the same thing so thats why I was wondering how I could adjust the code, as far as I can see it has to do with the line "for row = 1 to 3" thats why I asked if 1 to 3 does refer to bit 1-3 in the variable row, and if so how can I compensate for three rows that are now shifted by one bit. I tried to see if ((row >> 1) *3) + (ncd (col ^$fe)) but about the same results.
Thanks again.
