4D uOLED display lag
Results 1 to 4 of 4
    Feb 2010
    Albuquerque
    Default Speed
    I used a 20 mhz oscillator so the baud rate is at 48k. I dont think the baud rate is the issue.
    Feb 2010
    Albuquerque
    Default serin command
    I put a 20mhz xtal so the pic is running at 5x speed. the baud rate is now 48k. I can display a message but I am having trouble receiving the acknowledge bit. I have a feeling it is the serin command. The datasheet on the uOLED says after the command has been run, the display sends and acknowledge byte ($06) back so the pic can send another command. I am having trouble with the code. please help.
    DEFINe CHAR_PACING 0
    define OSC 4
    baud con 2
    ANSEL = %00000000
    counter var word
    RX var byte
    pause 10000
    serout GPIO.2, baud, [$55]
    'Displays James Richards! then holds for 2 seconds
    serout GPIO.2, baud, [$73, 6, 3, 2, $f8, $00, "James", $00]
    serout GPIO.2, baud, [$73, 4, 4, 2, $f8, $00, "Richards!", $00]
    pause 10000
    'Clears screen
    serout GPIO.2, baud, [$45]
    pause 200
    for counter = 0 to 99
        serout GPIO.2, baud, [$53, 5, 5, 0, $ff, $ff, 5, 5, #counter, $00]
        serout GPIO.2, baud, [$53, 5, 5, 0, $00, $00, 5, 5, #counter, $00]
               pause 200
    next counter
    getack:
    serin GPIO.0, baud, [RX]
    if (RX = $06) then
    RX = 0
