lcd problem
Results 1 to 15 of 15
Thread: lcd problem
    Miami, Florida USA
    Malcolm,
    Double check the voltage on Vo (contrast adjustment). Go all the way from the minimum to the maximum on the potentiometer.
    malc-c's Avatar
    malc-c Guest
    Malcolm,
    Robert, thanks for the input - voltage range = 0.00 to 4.46v
    Bombay, India
    Malcolm
    Please post the code you're using. I suspect the code is re-starting after printing the message.
    Jerson
    malc-c's Avatar
    malc-c Guest
    Personally I don't think it's the code - this has been running fine in the development board (see the 4ch thermostat post under the code section), and the PIC seems to be running OK when used on the stripboard as the LEDs indicate the PID routines work when the temperature detected by the probes are increased / decreased. My hunch is that it has to be something with the stripboard, I might try re-soldering the wires as it could be something as simple as a dry joint ?
    malc-c's Avatar
    malc-c Guest
    Quote Originally Posted by malc-c View Post
    Uhmm... well I just belled out each wire pin fo pin and it all checks out.
    Bombay, India
    Could be even simpler - decoupling caps 0.1uF? since you mentioned using strip board
    malc-c's Avatar
    malc-c Guest
    Yep, have one fitted across the supply lines next to the pic - might put a few more in
    I've just breadboarded the pic (pic, xtal, caps and the lcd) and it's running fine... must be a fault somewhere on the board...
    Thanks guys for all your inputs
    May 2008
    Italy
    DEFINE LCD_LINES 4               ' number of lines on LCD
    Your define is for a 4 lines LCD while you are using a two lines display (as per picture in your post #1)
    Al.
    malc-c's Avatar
    malc-c Guest
    Quote Originally Posted by aratti View Post
    Al.
    Sorry, but misleading as that was taken from the EasyPIC manual, I'm actually using a 4 x 20 as stated in my 1st post.
