help with PIC16F628 conditional program
Results 1 to 13 of 13
    Apr 2009
    here
    direct link:
    http://dc187.2shared.com/download/D7...42736-ef003566
    if the direct link doesn't work, here:
    http://www.2shared.com/file/D7VAeRiX/ecu.html
    thanks
    Hi, Joseph
    Definitly a simulator issue ... ( one MORE for Proteus ... )
    Just run your program in MPSIM ( MPLAB Simulator ) in step by step mode, and you won't see any change for the output ...
    I did told you Sims are toys ... , forget about them !!!
    BTW, Correct code is:
     IF ( FWD ^^ REVS ) AND NOT NEUT THEN
            forward = FWD : revers = NOT forward
            forward = 0 : revers = 0
    Doesn't change anything ... but brain satisfying !!! ( it's a logical EXOR, and not a bitwise one )
    Joseph,
    Add some resistors in series with the LED's that are being overdriven.
    It will stop blinking.
    Proteus Rules.
    MPSIM is Lame.
    Talking
    Joseph,
    Proteus Rules.
    MPSIM is Lame.
    Hi, Darrel ...
    did you try to close Forward, then the two other switches ( or/and ) ...
    you said " lame " ??? ... funny ...
    Judge of peace: my EasyPic5 ... Proteus is OUT !!!
    Apr 2009
    Joseph,
    Proteus Rules.
    MPSIM is Lame.
    whoa it seems that proteus simulates the overload protection, it worked
    thanks Darrel, thanks Alain
    i will try to complete the code. i'l update this thread soon
