help with PIC16F628 conditional program
Results 1 to 13 of 13
    Apr 2009
    Question help with PIC16F628 conditional program
    i'm having problem working with a conditional program,
    @ DEVICE PIC16F628A, INTRC_OSC_NOCLKOUT, WDT_OFF, PWRT_OFF, MCLR_OFF,PROTECT_ON,CPD_ON, BOD_OFF, LVP_OFF
    CMCON = 7
    VRCON = 0
    TRISA = 95
    TRISB = 0
    PORTB = 0
    GS1  var PORTA.0
    GS2  var PORTA.1
    TEMP var PORTA.2
    FWD  VAR PORTA.3
    REvs VAR PORTA.4
    Neut var PORTA.7
    forward  var PORTB.0
    revers   var PORTB.1
    one      var PORTB.2
    two      var PORTB.3
    three    var PORTB.4
    starterd var PORTB.5
    start: IF Neut = 1 then
            low forward
            low revers
            if (FWD = 1) and (REvs = 0) then
            low revers
            high forward
            low revers
            low forward
            if (FWD = 0) AND (REvs = 1) then
            low forward
            high revers
    goto start
    i need to monitor all the possible conditions in my input then ouput the right combination following this table.
    ------ INPUTS-------|-----OUTPUTS-----
    FWD---Neut--REvs-|---forward---revers
    --0-------0------1---|------0-----------1
    --1-------0------0---|------1-----------0
    --0-------1------0---|------0-----------0
    --0-------1------1---|------0-----------0
    --1-------1------0---|------0-----------0
    also i have problem on making PORTA.7 work as an input
    i plan to add more functions when this part worked
    TIA.
    Quote Originally Posted by joseph View Post
    TIA.
    Hi, joseph
    @ first ...
    your motor must be powered only if ( FWD ^ REVS = 1 ) AND ( NEUT = 0 ) ... ELSE outputs OFF
    after that
    forward = FWD and reverse = NOT forward ...
    what gives us ...
    IF ( FWD ^ REVS ) AND NOT NEUT THEN
      forward = FWD : reverse = NOT forward
      forward = 0 : reverse = 0
    Instead of writing :
    TRISA = 95
    Write
    TRISA = %  01011111 ' 95 in binary
    And you see instantly ... you've set Porta.7 as an output ...
    Apr 2009
    sir i tried to compile this
    CMCON = 7
    VRCON = 0
    TRISA = %01011111
    TRISB = 0
    PORTB = 0
    GS1  var PORTA.0
    GS2  var PORTA.1
    TEMP var PORTA.2
    FWD  VAR PORTA.3
    REvs VAR PORTA.4
    Neut var PORTA.7
    forward  var PORTB.0
    revers   var PORTB.1
    one      var PORTB.2
    two      var PORTB.3
    three    var PORTB.4
    start: IF ( FWD ^ REVS ) AND NOT NEUT THEN
            forward = FWD : revers = NOT forward
            forward = 0 : revers = 0
    goto start
    it compiles but does not work
    this part is not clear to me:
    thanks for the reply
    Apr 2009
    IF ( FWD ^ REVS ) AND NOT NEUT THEN <---- do this mean, if FWD and REVS are opposite and NEUT is low then
    forward = FWD : revers = NOT forward <---- forward is equal to what is FWD and revers is equal to opposite of forward else
    forward = 0 : revers = 0 <---- turn the outputs low
    Apr 2009
    RA7 won't be an input until i independently configured it as an input so i placed this line
    INPUT neut
    CMCON = 7
    pause 1
    VRCON = 0
    pause 1
    TRISA = 95
    TRISB = 0
    PORTB = 0
    GS1  var PORTA.0
    GS2  var PORTA.1
    TEMP var PORTA.2
    FWD  VAR PORTA.3
    REvs VAR PORTA.4
    Neut var PORTA.7
    forward  var PORTB.0
    revers   var PORTB.1
    one      var PORTB.2
    two      var PORTB.3
    three    var PORTB.4
    input neut
    start: IF ( FWD ^ REVS ) and not neut THEN
    goto start
    this works, but for some reason instead of revers/portb.0 going steady high when the input condition rules i got some oscillations, the led connected on this on my simulation blinks
    thanks
    INPUT neut
    Did you notice IF you want Porta.7 as an input ... the TRIS value must be > 127 ???
    here you have 95 ... tadaaaa ...
    no reason for that ... simulators are just toys , so do not believe what they say ...
    may be you could add some debouncing to your inputs ... but simulation won't show anything.
