All PIC pins outputting low voltage
Results 1 to 9 of 9
    Jun 2007
    Mansfield, UK
    Default All PIC pins outputting low voltage
    Hi, This is a bit of a weird problem. Ive made a circuit using a PIC18F2420. 16 of the pins connect to transistors and LEDs through seperate resistors. 2 pins connect to a tri-color LED and 4 pins are used to connect to an RS485 chip. When i turn the circuit on all of the LEDs light up feintly. When the PIC turns an output on then the LED glows as normal. Its definately the PIC thats causing it because when i remove the PIC all the LEDs go off completely.
    Ive tried eliminating possible causes. There is a huge transformer next to the chip so i tried removing it and running from another power source. Ive tried removing the RS485 chip, swapping the PIC and ive been over and over the PCB layout and i cant see anything wrong.
    Are there any special configuration registers i might have missed? Ive disabled the analog stuff already. I dont have a schematic at the moment but ill make one up tomorrow just incase it is a design fault.
    Code????
    Maybe?
    TRIS
    sinoteq's Avatar
    sinoteq Guest
    Hi
    What kind of transistor do you use? Part number? Please post schematics because this smells HW problem. Do you use MOSFET transistors perhaps without any pulldown restistors to the "Base"?
    Jun 2007
    Mansfield, UK
    The tris registers are set correctly.
    The transistors are MPSA13. I dont use a pulldown resistor on them but i did try adding one and it had no effect. Even the outputs that dont connect to a transistor have this problem too.
    Im just going to start the schematic now. It should be done soon
    Jun 2007
    Mansfield, UK
    Ive finished the schematic. Its not very good but hopefully youll be able to understand it
    Jun 2007
    Mansfield, UK
    Ive tried removing the PIC from the PCB and putting it in a breadboard. Ive connected wires for power, crystal and just 1 LED and i get the same problem. I even tried one of the LEDs that isnt also connected to a transistor.
