If you're using v2.6 you may want to switch to SERIN2 or DEBUGIN. SERIN has known timing issues: http://melabs.com/support/pbpissues.htm
Yes. DEBUGIN should work fine. I would disable interrupts too. At least until you can get your serial input working.
> Serin PortB.7, N2400,["D33",get0]
With that statement, get0 is a qualifier.
I think you wanted that to be the variable that receives the data.
So it should be outside of the square brackets.
Serin PortB.7, N2400,["D33"],get0
