How can I establish what RAM I need...and therefore which PIC.
Results 1 to 24 of 24
    Hello,
    DEBUG is a bit-banged serial routine that uses software loops to achieve the correct timing. If you're using interrupts they will mess with that timing.
    If the interrupts aren't very critical timing wise you can disable (mask) them while executing the debug statement. If an interrupt occurs while the debug statement is executing its interrupt request flag will get set and the ISR will fire as soon as you enable the interrupt again.
    The 16F690 however has a EUSART, are you using it or its pin for something else? If not you can switch to HSEROUT instead of DEBUG, that way all the baudrate generating stuff are handled by in hardware.
    Mar 2009
    Hello,
    Thanks Henrik, looks like HSEROUT is the way to go - It looks like the 16f690 'TX' pin is pin 10 (RB7) & as luck would have it, that pin is still free in my setup - presumably I can feed the HSEROUT serial data from the PIC RB7 direct into the pickit2 & still use the Pickit2 Uart tool? (ie by feeding RB7 into Pickit2 pin 4, 'RX' pin). I'd rather go this way, as this will save me any extra wiring (I already have a switch installed to switch the Pickit2's RX pin4 back & forward between to my present nominated debug port/pin & back to pin 19 - ICSPDAT - on the 16f690 where it needs to go to program the PIC up)
    Mar 2009
    At the risk of talking to myself, yes HSEROUT, can be 'switched' to pin4 (RX) of the Pickit2 - and characters sent via that manner displays fine on the Pickit2 Uart 2 (no garbled data anymore!)
    For anyone with a 16f690, who want the settings I'm using to get HSEROUT, here you go...
    @ __CONFIG _FCMEN_OFF & _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF & _IESO_OFF & _BOR_OFF & _PWRTE_OFF
    Include "modedefs.bas"
    DEFINE HSER_SPBRG 25
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_CLROERR 1
    ANSELH=0
    ANSEL=0
    CM1CON0 =0
    CM2CON0 =0
    CM2CON1 =0
    adcon1=0
    TRISB.7 = 0
    rcsta.7=1    'this one switches 16f690's Pin 10 from RB7 (general IO) to USART TX usage- it caught me out!
    loop:
    hserout ["Hello ", 13, 10]
    goto loop
    Set your Pickit2 UArt tool baud setting to 9600 - away you go!
    Mar 2009
    Default Re: How can I establish what RAM I need...and therefore which PIC.
    Now I'm sure this is going to be embarrasingly obvious/simple, *but*
    I'm using a 16F1824, the spec says the following...
    "Up to 8 Kbytes Linear Program Memory"
    however, when I compile my program & goes above 4096 (as shown in microcode studio) I get an error "ARGUMENT OUT OF RANGE" ....if I strip some code out, to take it below 4096...then all is well again.
    So where has the extra 4k of programming space gone?!! ie how can I can take advantage of it?!
    Miami, Florida USA
    Microcode Studio shows that number, the 4096, in words (2 bytes) for the 16F series. However, for the 18F series Microcode Studio shows that number in bytes. Don't ask me why.....
    Anonymous
