Conditional Defines?
Results 1 to 11 of 11
    When there are no DEFINE's, and an hserout in your program, PBP defaults to 2400 baud in standard USART mode.
    But 2400 baud is too slow at 48Mhz in standard mode.
    When it tries to initialize the USART at the beginning of the program, the value for SPBRG is larger than 255 and gives the "out of range" warning.
    If you use DEFINE's that will work at 48mhz, then the warning will go away and you can manually set the EUSART registers in Enhanced mode whenever needed, like you are doing.
    DEFINE HSER_BAUD 19200
    Or, you can start with enhanced defines that specify SPBRG, then PBP doesn't try to calculate it.
    DEFINE HSER_SPBRG 225 ' 2400 Baud @ 48MHz, 0.0%
    SPBRGH = 4
    BAUDCON.3 = 1 ' Enable 16 bit baudrate generator
