How to swap a variable?
Results 1 to 6 of 6
    jessey's Avatar
    jessey Guest
    Default How to swap a variable?
    Hello Everyone,
    I'm trying to swap Radiator_temp and Block_temp into a temp variable before reading the temperature of two DS1820 in the code below and can't seem to get it right. I've only included 2 subroutines below that are part of a bigger program to make it easier to read and I compiled the code below as it is and I get the same results.
    I have 2 DS1820's and am reading one at a time in each pass through the mainloop to speed up using my push buttons. I try and use: Sensor_Select = Radiator_Sensor : Radiator_temp = temp : GOSUB Check_Temperature
    Then on the next pass through the mainloop I use: Sensor_Select = Block_Sensor : Block_temp = temp : GOSUB Check_Temperature
    With that code then I warm up the Block_Sensor it shows the temperature rise to the Radiator_Sensor on my Lcd but if I mix it up a bit and write the code like this: Sensor_Select = Block_Sensor : Radiator_temp = temp : GOSUB Check_Temperature and the same with the Radiator_Sensor then it displays properly?
    Anyone have any idea of what's going on here, it's working ok but the logic is very confusing to say the least. Any help with this would be very much appreciated.
    Thanks In Advance
    jessey
    '* Name     : Two Ds1820 18F452.bas                                            *
    '* Author   : Jessey Montgomery                                                *
    '* Includes : STRINGS.PBP By Darrel Taylor                                     *
    '* Notice   : Copyright (c) 2004                                               *
    '*          : All Rights Reserved                                              *
    '* Date     : 22/10/2005                                                       *
    '* Version  : Using PicBasic Pro Ver 2.50, MPASM Ver 5.20, Using MicroCode     *
    '*          : Studio 3.0.0.5, PICkit 2 programmer - Application Version        *
    '*          : 2.50.02 - Device File Version 1.5100 - OS Firmware Version       *
    '*          : 2.30.01. Using a PIC18f452-20/P                                  *
    '                                |   18F452   |
    '               MCLR/Vpp ------> |1         40| <-----> RB7/PGD
    '                RA0/AN0 <-----> |2         39| <-----> RB6/PGC
    '                RA1/AN1 <-----> |3         38| <-----> RB5/PGM
    '          RA2/AN2/Vref- <-----> |4         37| <-----> RB4
    '          RA3/AN3/Vref+ <-----> |5         36| <-----> RB3/CCP2*
    '              RA4/TOCK1 <-----> |6         35| <-----> RB2/INT2
    '       RA5/AN5/SS/LVDIN <-----> |7         34| <-----> RB1/INT1
    '             RE0/RD/AN5 <-----> |8         33| <-----> RB0/INT0
    '             RE1/WR/AN6 <-----> |9         32| <-----  Vdd
    '             RE2/CS/AN7 <-----> |10        31| <-----  Vss
    '                    Vdd  -----> |11        30| <-----> RD7/PSP7
    '                    VSS  -----> |12        29| <-----> RD6/PSP6
    '              OSC1/CLK1  -----> |13        28| <-----> RD5/PSP5
    '          OSC2/CLKO/RA6 <------ |14        27| <-----> RD4/PSP4
    '        RC0/T1OSO/TICK1 <-----> |15        26| <-----> RC7/RX/DT
    '        RC1/T1OSI/CCP2* <-----> |16        25| <-----> RC6/TX/CK
    '               RC2/CPP1 <-----> |17        24| <-----> RC5/SDO
    '            RC3/SCK/SCL <-----> |18        23| <-----> RC4/SD1/SDA
    '               RD0/PSP0 <-----> |19        22| <-----> RD3/PSP3
    '               RD1/PSP1 <-----> |20        21| <-----> RD2/PSP2
    '-- Clear All The Variables And Each Port Before Setting The TRIS Registers ---'
    Clear    'Set all ram registers to zero
    PORTA = 0
    PORTB = 0
    PORTC = 0
    PORTD = 0
    PORTE = 0
    '--------------------------- VSS VDD MCLR Ect. Pins ---------------------------'
    'MCLR        (Pin 1)
    'VDD         (Pin 11)
    'VSS         (Pin 12)
    'OSC/CLKIN   (Pin 13)
    'OSC2/CLKOUT (Pin 14)
    'VSS         (Pin 31)
    'Vdd         (Pin 32)
    '((OPTION_REG=127 ' ENABLE WEAK PULL UP RESISTORS ON PORTB))
    'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX'
    'XXXXXXXXXXXXXXXXXXXXXXXXXX Set The TRIS In/Out Pins XXXXXXXXXXXXXXXXXXXXXXXXXX'
    'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX BELOW XXX'
    '-------------------- PORTA PINS --------------------'
    TRISA.0 = 1  '(pin 2) ........................Adj_Dn_Button VAR PORTA.0  ' pin 2
    TRISA.1 = 1  '(pin 3) ........................Adj_Up_Button VAR PORTA.1  ' pin 3
    TRISA.2 = 1  '(pin 4) .......................Adj_Dn_Button2 VAR PORTA.2  ' pin 4
    TRISA.3 = 1  '(pin 5) .......................Adj_Up_Button2 VAR PORTA.3  ' pin 5
    TRISA.4 = 1  '(pin 6) NOT USED
    TRISA.5 = 1  '(pin 7) NOT USED
    '-------------------- PORTB PINS --------------------'
    TRISB.0 = 1  '(pin 33) ........................................DS1820 Rad_Sensor
    TRISB.1 = 1  '(pin 34) NOT USED VAR PORTB.1 'pin 34
    TRISB.2 = 1  '(pin 35) NOT USED VAR PORTB.2 'pin 35
    TRISB.3 = 0  '(pin 36) ..............................The_Led VAR PORTB.3 'pin 36
    TRISB.4 = 1  '(pin 37) NOT USED VAR PORTB.4 'pin 37
    TRISB.5 = 1  '(pin 38) NOT USED VAR PORTB.5 'pin 38
    TRISB.6 = 1  '(pin 39) NOT USED VAR PORTB.6 'pin 39
    TRISB.7 = 1  '(pin 40) NOT USED VAR PORTB.7 'pin 40
    '-------------------- PORTC PINS --------------------'
    TRISC.0 = 1  '(pin 15) ......................................DS1820 Block_Sensor
    TRISC.1 = 1  '(pin 16) ...................Change_Mode_Button VAR PORTC.1 'pin 16
    TRISC.2 = 1  '(pin 17) ....................Block_Code_Button VAR PORTC.2 'pin 17
    TRISC.3 = 1  '(pin 18) NOT USED VAR PORTC.3 'pin 18
    TRISC.4 = 1  '(pin 23) NOT USED VAR PORTC.4 'pin 23
    TRISC.5 = 1  '(pin 24) NOT USED VAR PORTC.5 'pin 24
    TRISC.6 = 1  '(pin 25) NOT USED VAR PORTC.6 'pin 25
    TRISC.7 = 1  '(pin 26) NOT USED VAR PORTC.7 'pin 26
    '-------------------- PORTD PINS --------------------'
    TRISD.0 = 1 '(pin 19) NOT USED VAR PORTD.0 'pin 19
    TRISD.1 = 0 '(pin 20) ................................Buzzer VAR PORTD.1 'pin 15
    TRISD.2 = 0 '(pin 21) ...............................The_Fan VAR PORTD.2 'pin 21
    TRISD.3 = 1 '(pin 22) NOT USED VAR PORTD.3 'pin 22
    TRISD.4 = 0 '(pin 27) ...........................Lcd out for Data bit 4
    TRISD.5 = 0 '(pin 28) ...........................Lcd out for Data bit 5
    TRISD.6 = 0 '(pin 29) ...........................Lcd out for Data bit 6
    TRISD.7 = 0 '(pin 30) ...........................Lcd out for Data bit 7
    '-------------------- PORTE PINS --------------------'
    TRISE.0 = 0 '(pin 8)  ...........................LCD Register/Select
    TRISE.1 = 0 '(pin 9)  ...........................LCD Enable
    TRISE.2 = 1 '(pin 10) NOT USED PORTE.2
    ;@ __CONFIG _CONFIG1H, _OSCS_ON_1H & _XT_OSC_1H ' use this one for 4 mhz and
                                                    ' also declare the osc as 4mhz
    @ __CONFIG _CONFIG1H, _OSCS_OFF_1H & _HSPLL_OSC_1H ; use this one for 16 mhz
    @ __CONFIG _CONFIG2L, _BOR_OFF_2L & _BORV_20_2L & _PWRT_ON_2L
    @ __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_128_2H
    @ __CONFIG _CONFIG3H, _CCP2MX_OFF_3H
    @ __CONFIG _CONFIG4L, _STVR_OFF_4L & _LVP_OFF_4L & _DEBUG_OFF_4L
    @ __CONFIG _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L & _CP2_OFF_5L & _CP3_OFF_5L
    @ __CONFIG _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
    @ __CONFIG _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L & _WRT2_OFF_6L & _WRT3_OFF_6L
    @ __CONFIG _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_OFF_6H
    @ __CONFIG _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L & _EBTR2_OFF_7L & _EBTR3_OFF_7L
    @ __CONFIG _CONFIG7H, _EBTRB_OFF_7H
     DEFINE OSC 16     ' using HSPLL X 4 gives us OSC 16
    @ errorlevel -306 ; turn off the Crossing page boundary warnings
     Define LCD_DREG   PORTD
     Define LCD_DBIT   4
     Define LCD_RSREG  PORTE
     Define LCD_RSBIT  0
     Define LCD_EREG   PORTE
     Define LCD_EBIT   1
     ADCON1 = 7  ' Set to Digital
     'used for temperature'
     count_remain VAR BYTE  ' Count remaining
     count_per_c VAR	BYTE  ' Count per degree C
     Sensor_Select VAR Byte ' this var allows 2 sensors to be read
     Radiator_Sensor con 8  ' Sensor on PortC.0 One-wire data pin (pin 15)
     Block_Sensor con 0     ' Sensor on PortB.0 One-wire data pin (pin 33)
     temp Var Word          ' temporary storage for Block_temp & Radiator_temp
     Block_temp Var Word    ' Temperature storage
     Radiator_temp Var Word ' Temperature storage
     INCLUDE "EE_Vars.PBP"
     'Declare The EE Variable' 'Load A Default Setting For The EE Variable'
          Temp_Mode VAR  BYTE : @  EE_var  _Temp_Mode, BYTE,1
     ' Allocate variables '
     a var byte             ' Enables if..then statements to execute without
     a = 0                  ' using GOTO's, a always equals 0
     b Var Word             ' counter to detect a sensor malfunction
     I Var Byte             ' This variable speeds up button presses by only
     I = 0                  ' reading one sensor at a time then displaying.
    'Pushbuttons Variables '
     Block_Code_Button VAR PORTC.2 ' pin 17
    'Port pins Variables '
     Buzzer VAR PORTD.1     ' pin 20
     The_Fan VAR PORTD.2    ' pin 21
     Fahrenheit con 1
     Celsius CON 0
     Is_On CON 1
     Is_Off CON 0
     Is_Pressed CON 0
     Is_Not_Pressed CON 1
     LCDOUT  254,64,28,20,28,0,0,0,0,0        ' Cust Char #0, Temp degree sign
     Pause 1000' wait for Lcd to initialize
        LCDOut $fe, 1, "Taurus Controler"
      LCDOut $fe, $c0, "Jessy Montgomery"
      PAUSE 2000
      If a = 0 Then mainloop' Skip subroutines
    Check_Temperature:
      OWOut Sensor_Select, 1, [$CC, $44] ' Start the Temp conversion
     waitloop:
       If count_remain = 0 Then b = b + 1''''''''
       If b >= 20000 then                       '
      Loop_5:                                   '
         If Sensor_Select = Block_Sensor then   '
            LCDOut $fe, 1, "Block Sensor Has"   '
         Else  ' If it's Radiator_Sensor        ' This detects a sensor malfunction
            LCDOut $fe, 1, " Rad Sensor Has "   ' in 2.5 seconds.
         Endif                                  '
          LCDOut $fe, $c0, "!Malfunctioned! "   ' Rad sensor will sound the alarm if
          PWM  Buzzer,255,100                   ' the positive or the 4.7K resistor
          The_Fan = Is_On                       ' is dissconnected from the DS1820
          Pause 100                             '
          IF Block_Code_Button = Is_Pressed THEN' Block sensor will only sound the
            While Block_Code_Button = Is_Pressed' alarm if the 4.7K resistor is
            Wend                                ' dissconnected?
            Pause 150                           '
            If a = 0 then Return                '
          Endif                                 '
      If a = 0 then Loop_5                      '
       Endif'''''''''''''''''''''''''''''''''''''
         OWIn Sensor_Select, 4, [count_remain]'  Check for still busy converting
    	 IF count_remain = 0 THEN waitloop
         OWOut Sensor_Select, 1, [$CC, $BE]	  '  Read the Temp
         OWIn Sensor_Select, 0, [temp.LOWBYTE, temp.HIGHBYTE, _
                            Skip 4, count_remain, count_per_c]
        ' Calculate temp in degrees Celsius to 2 decimal places
         temp = ((ABS(temp) >> 1) * 100)
         temp = temp - 25 + (((count_per_c - count_remain) * 100) / count_per_c)
         IF Temp_Mode = Celsius then RETURN' If Mode is Fahrenheit then continue
        ' Convert Celsius to Fahrenheit before returning
         temp = (ABS(temp) */ 461)
         temp = temp + 3200
    Select_A_Sensor_To_Read:
       If I = 0 then'' This code here speeds up button presses
          I = 1      ' by only reading one sensor then displaying
       else          ' the results instead of reading two sensors
          I = 0      ' before displaying the results.
       Endif''''''''''
       If I = 0 Then''''''''''''''''''''
        Sensor_Select = Radiator_Sensor' This is a little convoluted to say the
       'SWAP temp, Radiator_temp       ' least but it works, how and why I have no
       'Radiator_temp = temp           ' idea. If I uncomment the commented out code
        Block_temp = temp              ' lines and use them the way you would think
        GOSUB Check_Temperature        ' it should work then the program switches
       Endif                           ' sensors around i.e. instead of reading the
                                       ' Radiator_Sensor on pin 15 it then reads
       If I = 1 Then                   ' the sensor on 33 even though it's declared
        Sensor_Select = Block_Sensor   ' on pin 15 and vice versa for the
       'SWAP temp, Block_temp          ' DS1820 Block_Sensor. So it switches the
       'Block_temp = temp              ' two sensors, very confusing! It must be in
        Radiator_temp = temp           ' way I'm swaping Rad & Block_temp into the
        GOSUB Check_Temperature        ' temp variable but I also tried SWAP with
       Endif                           ' the same results.
    Return''''''''''''''''''''''''''''''
    mainloop:
      Gosub Select_A_Sensor_To_Read
      b = 0
      If Temp_Mode = Fahrenheit Then
         LCDOut $FE, 1, "Radiator = ", DEC Radiator_temp / 100,0,"F"
         LCDOut $fe, $c0, " Block   = ", DEC Block_temp / 100,0,"F"
      Else ' If Temp_Mode = Celsius
         LCDOut $FE, 1, "Rad Temp = ", DEC Radiator_temp / 100,0,"C"
         LCDOut $fe, $c0, " Block   = ", DEC Block_temp / 100,0,"C"
      Endif
      Pause 100
    If a = 0 then mainloop
    Hello,
    Not sure if this will help you. The receiving variable is always on the left side
    In this statement you are moving the contents of temp into Block_temp
    Block_temp = temp
    The way I read your question you wanted to store or move the contents of Block_temp into
    temp?
    temp = Block_temp
    Mark
    jessey's Avatar
    jessey Guest
    Quote Originally Posted by mark_s View Post
    In this statement you are moving the contents of temp into Block_temp - Block_temp = temp
    Hi Mark,
    Yes that's correct, I want to move the contents of temp into Radiator_temp on the first pass in the mainloop so I can see the temperature on the first line of my Lcd then on the second pass I change the Sensor_Select to be the Block_Sensor and then want to load temp into Block_temp so I can see it on the second line of the Lcd. I've tried many different combinations and just can't seem to get that to work. It does work and display properly if I mix it up like my code shows above, but it's a puzzler for me and I can't figure why that works and if it'll be reliable.
    jessey
    Hi Jessey,
    I noticed in your 1st subroutine "Select_A_Sensor_To_Read:" you are swapping your variables before the gosub to "Check_Temperature:" . What happens if you read the temperature first
    right before the swap statement. The last sensor reading will now be in the temp variable. It can now be stored in Radiator_Temp or Block_temp. The way you have it now it reads the temperature to temp and exits the subroutine.
    Try this
    Add a new variable Old_temp
    SWAP Old_temp, Radiator_temp ' least but it works, how and why I have no
    SWAP Old_temp, Block_temp ' DS1820 Block_Sensor. So it switches the
    Endif
    jessey's Avatar
    jessey Guest
    What happens if you read the temperature first right before the swap statement. The last sensor reading will now be in the temp variable. It can now be stored in Radiator_Temp or Block_temp. The way you have it now it reads the temperature to temp and exits the subroutine.
    Thanks Mark,
    That's all it took, I changed it like you suggested and it works perfectly now. Thanks for your help I really appreciate it.
    Thanks Again
    jessey
       If I = 0 Then
       Endif
       If I = 1 Then
        Block_temp = temp
       Endif
    Jessey,
    Glad to hear it's working!
    How are you attaching or making contact with the DS1820's to your engine? I have a
    generator that I would like to experiment with a temp read out and overheat cut off.
    Thanks Mark
