Need little help with maths - Timer based application
Results 1 to 3 of 3
    Default Need little help with maths - Timer based application
    Hi, I am trying to create a timer application which tracks 30minutes, 1Hr, 1h30min, 2H, 2H30min. It does not need to be very precise, variation of upto a 2 seconds is fine.
    I am using 16f676 & using 16bit timer1 for this.
    PIC-timer calculator says interrupts are generated 524.295mSec @4Mhz & 1:8 prescaler.
    I have a word variable which works as a counter for interrupts & tells me that certain time has elapsed.
    My problem is that I am not sure if I have calculated the delayset values right as calculator disagrees with me.
    Code looks like this:
    delay var word
    delaystop var word
    redled var porta.0
    ;---------INTERRUPTS DECLARED HERE------------------------------
            INT_Handler    TMR1_INT,  _delaystop,   PBP,  yes
    T1CON=$31
    ;-------------INTERRUPTS ENABLED HERE-----------------------------
    @   INT_ENABLE   TMR1_INT     ; Enable external (INT) interrupts
    while 1
    if button1 then
    delay=0 : delayset=2060 ; 30 minutes
    if button2 then
    delay=0 : delayset=4120 ; 1Hour
    if button3 then
    delay=0 : delayset=6180 ; 1Hr 30 minutes
    if button4 then
    delay=0 : delayset=8240 ; 2 Hours
    if button5 then
    delay=0 : delayset=10300 ; 2Hrs 30 minutes
    wend
    delaystop:
    delay=delay+1
    if delay=delaystop then
          redled=1
    @ INT_RETURN
    ___________________
    WHY things get boring when they work just fine?
    30 minutes = 1,800 seconds:
    1800 / 0.524295 = 3433
    1 hour = 3,600 seconds:
    3600 / 0.524295 = 6866
    1.5 hours = 10299
    2 hours = 13732
    And maybe it's somewhere else in the program that wasn't posted, but ..
    It looks like you are adjusting the value in delayset according to the buttons.
    Then comparing the delay time against delaystop in the handler.
    Oh, and delaystop is both a variable and the Label to the Interrupt handler.
    hth,
    Got that!
    It is my typing mistake to put delay=delaystop in ISR, though it actually is delay=delayset
    ___________________
