Hi Mark,
Yes that's correct, I want to move the contents of temp into Radiator_temp on the first pass in the mainloop so I can see the temperature on the first line of my Lcd then on the second pass I change the Sensor_Select to be the Block_Sensor and then want to load temp into Block_temp so I can see it on the second line of the Lcd. I've tried many different combinations and just can't seem to get that to work. It does work and display properly if I mix it up like my code shows above, but it's a puzzler for me and I can't figure why that works and if it'll be reliable.
jessey
