Encrypted bootloader.
Results 1 to 11 of 11
    Default Encrypted bootloader.
    Hi eveyone,
    I'm looking for pointers towards an encrypted serial (not USB) bootloader that will work with PBP. I've found the one from Brush Electronics which seems to be what I'm looking for at a reasonable price ($150) but it says it's meant to be used with the CCS PCH compiler.
    Has anyone seen anything simmilar for use with PBP?
    Thanks!
    First off, I don't have any experience with this one. But it looks like it encodes/decodes with an XTEA algorithm. Key is a 16 byte code. Here is some info on it from their readme file. And best of all, it is free.
    I would think that hex is hex, and whether it is PBP, CCS, etc, the hex would not look any different to a bootloader.
    http://www.diolan.com/pic/bootloader_dwn.html
    XTEA Encoder/Decoder
    XTEA Algorithm backgrounds
    The XTEA encoder/decoder input byte stream is separated into 8 byte chunks
        [ b0 b1 b2 b3 b4 b5 b6 b7 ], [ b8 b9 ........... ], ...
    Chunk is treated as two 32 bit little endian integers x1 and x2.
        For chunk0:
            x1 = (b3<<24) + (b2<<16) + (b1<<8) + b0
            x2 = (b4<<24) + (b5<<16) + (b6<<8) + b7
    Encoding/Decoding is performed for every single chunk.
    KEY is a 16 bytes string treated as key[4], where key[i] is
        KEY k0 k1 k2 k3 k4 ..... k15
            key[0] = (k3<<24) + (k2<<16) + (k1<<8) + k0
    DELTA is 32 bit integer constant
        DELTA = 0x9E3779B9
    Chunk Encoding:
        sum=0;
        for( i=0; i<XTEA_ITER; i++ )
                x1 += (((x2<<4) ^ (x2>>5)) + x2) ^ (sum + key[sum&0x03]);
            sum+= DELTA;
            x2 += (((x1<<4) ^ (x1>>5)) + x1) ^ (sum + $KEY[(sum>>11)&0x03]);
    Chunk Decoding:
        sum = DELTA* XTEA_ITER;
            x2 -= (((x1<<4) ^ (x1>>5)) + x1) ^ (sum + key[(sum>>11)&0x03]);
            sum-= DELTA;
                x1 -= (((x2<<4) ^ (x2>>5)) + x2) ^ (sum + key[sum&0x03]);
    XTEA Encoder/Decoder configuration
    You can change following parameters to configure XTEA encoder/decoder
    - XTEA encoder/decoder KEY
    File        : xtea.asm
    Identifier    : XTEA_KEY
    - XTEA encoder/decoder number of iterations
    File        : xtea.asm
    Identifier    : XTEA_ITERATIONS and DELTA_ITER
    The number of iterations defines level of security. The 16 iterations are
    quite enough for bootloader. Default value is 64 iterations.
    If you change number of iterations do not forget to change DELTA_ITER,
    that is precalculated value of DELTA*XTEA_ITERATIONS used by decoder
    Example:
            XTEA_ITERATIONS    equ     0x40            ; Number of iterations on x1,x2
        DELTA_ITER      db      0x40,0x6e,0xde,0x8d     ; Delta*XTEA_ITERATIONS
    Code Protection
    Following Configuration Registers settings are recomended to secure
    FW from anauthorised access and protect bootloader section from undesired
    changes by external or internall agent. This setting will allow proper
    operation of bootloader but will not let any external access to FW.
    Config Register  Value  Description
    0x300006.bit7    1
                Background Debug         Disabled
    0x300008        0x08
                Code Protect 0x0800-0x1FFF  Enabled
                Code Protect 0x2000-0x3FFF  Enabled
                Code Protect 0x4000-0x5FFF  Enabled
    0x300009    0x80
                Data EE Read Protect        Disabled
                Code Protect Boot        Enabled
    0x30000A    0x0F
                Table Write Protect 0x0800-0x1FFF  Disabled
                Table Write Protect 0x2000-0x3FFF  Disabled
                Table Write Protect 0x4000-0x5FFF  Disabled
    0x30000B    0x80
                Data EE Write Protect       Disabled
                Table Write Protect Boot    Enabled
                Config Write Protect        Enabled
    0x30000C    0x0F
                Table Read  Protect 0x0800-0x1FFF  Disabled
                Table Read  Protect 0x2000-0x3FFF  Disabled
                Table Read  Protect 0x4000-0x5FFF  Disabled
    0x30000D    0x00
                Table Read Protect Boot        Enabled
    Yes, I've seen that one too. The "problem" is it's USB and I don't have a USB enabled chip in this project. Usin XTEA however seems like the common way to handle the encryption as the one from Brush Electronics uses that as well. I guess I COULD have a go at writing one but I really don't need another project so I went looking for an of the shelf product at a reasonable price.
    Agreed, problem is that the actual boorloader code on the PIC needs to be customised, ie. oscillator frequency, baudrate, CONFIGs and the "key" etc which means that I must have the compiler for which the bootloader source was written - which is why I'd like to find one for PBP.
    Still looking....
    Dec 2007
    Paris
    Looking into encrypted USB bootloaders too, it seems that diolan's is the only one available (free or not, though diolan has the big advantage of being free!). Though, it uses the extended PIC18 instruction set which is not compatible with PBP compiled code... There's probably no chance to make it work as is.
    Microchip's HID bootloader does work with the standard instruction set, but does not support encryption.
    Any idea if there's such thing available?
    Quote Originally Posted by aberco View Post
    You could do something similar to what these guys did, and turn off the extended instruction bit before you code: http://www.sfcompiler.co.uk/forum/vi...082c05cc975a5a
    Maybe an assembly version of run-time config: http://www.picbasic.co.uk/forum/cont...un-Time-Config
    Walter
    http://www.scalerobotics.com
    Dec 2007
    Paris
    Haha!!! I just found the same solution in another forum as well
    Will quote it here:
    Some of the newer PIC18s (e.g. 2480, 2580, 4550 etc) support the 'Extended Instruction Set', which enables them to do the offset indexed addressing. However, that's not how mikroC (or any of the MikroE's compilers) has been designed to do. The explanation from Microchip's datasheets for relevant PICs says: When the extended set is disabled, addresses embedded in opcodes are treated as literal memory locations: either as a location in the Access Bank (a = 0), or in a GPR bank designated by the BSR (a = 1). When the extended instruction set is enabled and a = 0, however, a file register argument of 5Fh or less is interpreted as an offset from the pointer value in FSR2 and not as a literal address. For practical purposes, this means that all instructions that use the Access RAM bit as an argument – that is, all byte-oriented and bit-oriented instructions, or almost half of the core PIC18 instructions – may behave differently when the extended instruction set is enabled.
    This 'problem' can be solved in two ways:
    1. Disable the extended instruction set (e.g. for PIC18F2480, it's in the 4th config word - _CONFIG_4L: _XINST_OFF_4L); it can be done either from the compiler itself (<Project>-><Edit Project>), or in the PICFLASH tool.
    2. Leave the extended set enabled, but set the FSR2L and FSR2H to 0's at the beginning of your code; this will make the offset from the location 0x000000, which is the actual address stated. In this case you lose the FSR2 register pair.
    I've also seen that config registers can be changed as you said, and thought about disabling extended instructions before running PBP code. It's just a matter of knowing if that can be done within a running program, without messing it up.
    First I have to succeed running the bootloader code, and then I'll try these tricks to see if I can get PBP code running smoothly.
    Will update progress here, thanks!
    A commercial serial bootloader that has encryption. The price looks to be the only issue ..... well, that and it only works with 3 chips.
    (Please be seated, I don't want anyone getting hurt)
    http://www.auelectronics.com/Software-BTLD_RS232.htm
    $1,999.00
    Thanks guys!
    Walter, I'm afraid it ain't goin' to happen' at that price..... ;-)
    The one from Brush Electronics is priced reasonably at $150 but seems it's not meant to be used with PBP and I'd really prefer something that works instead of me trying to hack something together.
    Well, I'll keep my eyes and ears open, thank you both!
