Copying one array to another
Results 1 to 5 of 5
    Sep 2010
    Default Copying one array to another
    Maybe a dumb question, but here goes anyway:
    Is there a way to copy bit one array to another?
    I know this method:
    g VAR bit[8]
    h VAR bit[8]
    for i=0 to 7
    h(i)=g(i)
    next i
    I looked at the ARRAYWRITE command, but it says from one byte array to another.
    What would be the result of: h=g ?
    I tried the h=g method in my code, but I don't think it is working. If anyone can help...Thanks.
    May 2008
    Italy
    Since your bit array is a byte long use the byte instead.
    G VAR BYTE
    H VAR BYTE
    G = H
    Byte H now is equal to Byte G and you can extract the bits indexing the byte
    G bit 0 = G.0
    G bit 1 = G.1
    G bit 7 = G.7
    Naturally the same apply to byte H.
    Cheers
    Al.
    Sep 2010
    Al,
    That's how I started, and then I changed to the bit array so that I could do the following:
    for i=0 to 7
    out_sig=g(i)
    pauseus 450
    out_sig=g(i+1)
    pauseus 50
    next i
    not sure how to do the same with a byte array, since when using the byte array I can't use a variable to reference the bits .... g.0-g.7 can't be expressed as g.(i)...
    Thoughts? Thanks for the reply!
    G VAR BYTE
    i VAR BYTE
    For i = 0 to 7
    out_sig = G.0[i]
    NEXT
    I think that should do it.
    Sep 2010
    Looks like that works!
    Da VAR BYTE
    Ea VAR BYTE
    i VAR BYTE
    Da=%10011100
    Ea=Da
    FOR i=0 to 6 STEP 2
    out_sig=Ea.0(i)
    PAUSEUS 100
    out_sig=Ea.0(i+1)
    pauseus 100
    NEXT i
    Thanks for you help!
