How can I sort an array? In case anyone wants one way of doing it here's a ready to run example...
CounterA var BYTE
DataTemp var WORD
MyData var WORD[12]
SortArray subroutine sorts the example 12 element MyData array in sequence placing the smallest value into MyData[0] and the largest value into MyData[11]...
SortArray:
CounterA=0
SortArrayLoop:
If MyData[CounterA+1] < MyData[CounterA] then
DataTemp=MyData[CounterA]
MyData[CounterA]=MyData[CounterA+1]
MyData[CounterA+1]=DataTemp
If CounterA>0 then CounterA=CounterA-2
CounterA=CounterA+1
If CounterA<11 then goto SortArrayLoop
By changing the <11 in the line above, you can sort whatever size of array you've got. The value is arraysize-1, so <24 will sort a 25 element array. Just redefine WORDS to BYTES if you want an 8-bit sort routine.
A routine like this could be much simplified if MeLabs could get SWAP to work on variable index arrays... perhaps a future suggestion.
Melanie
