Adcon1
Results 1 to 5 of 5
Thread: Adcon1
    Sep 2005
    Default Adcon1
    I am using a PIC 18F242 with 20mhz. I want to assign PinA.0 as an ADC input and all other Port A pins as digital inputs. I am currently using TrisaA = %11111111 and ADCON1 = %1001111. The digital input on PortA.2 does not appear to be working, and I assume there is a problem with the way I am reading the ADCON chart. Is ADCON1 = %1001111 correct?
    Not surprising ...
    IF you use external Vref + and Vref - ... ... A2 and A3 are the Vref+/- inputs ...
    IF NOT just try
    ADCON1 = %01001110 ; ADCON1 is 8 Bits... not 7 !!!
    Sep 2005
    Using ADCON1 = %01001110 corrects my digital input problem, but now PortA.0 does not work as an analog input for ADC. Where can I find some more information on how ADCON1 works?
    Quote Originally Posted by Armadus View Post
    Ok, I see ...
    You can try to open the 18F242 datasheet, ADC section ( $ 17 , I think )
    you also could post the code you've written here, I'm sure it will save lots of time to you ...
    Sep 2005
    Thanks for your help. I must have misread the table that I was looking at. The correct setting
    is ADCON1 = %10001110.
